Question about Campbell Hausfeld Welding Tools
Campbell hausfeld pro wirefeed welder model wf2000 makes tiny beads but will not adhere
  • 92 Answers
Check inside the WFU, a switch with CC or CV will be seen, alternate between these two setting, CC=Constant current and CA=Constant Voltage.
On the back of the WFU you will see a plate which indicates the maximum amprage (input) that the WFU can accept and set the main power source to that amprage,
Posted on Oct 09, 2009
110 volt welder the wire stays energized even when the feeder stops and your off the trigger. Campbell Hausfeld flux 80. Any ideas?
That could be 2 things. Either the switch in feed assembly is bad or the relay inside the unit is sticking.
Nov 16, 2015 | Campbell Hausfeld Welding Tools
Parts and service manual for a campbell hausfeld welder auto stike 85
http://www.chpower.com/manualsearch/
They need the model number. They do not have their search set up to handle the model name unlike other manufacturers.
It will be on the ID label.
Jan 06, 2012 | Campbell Hausfeld Welding Tools
I have a 115V CH mig/flux welder. I can not get any *********** at all. Has worked fine in past. Am getting gas to the nozzle. Bead looks nice but even with the lightest gage metal, bead just flakes...
Hi:
Sounds like you have the wrong polarity or wrong gas.
For solid wire: use a gas mix of 75/254 argon/CO2 and ground clamp must be on the negative terminal /pole.
For core wire: No gas is needed but the polarity must be: ground clamp on positive terminal side.
Hope this help.
Sep 05, 2011 | Campbell Hausfeld Welding Tools
Got a Campbell Hausfeld gasless 80amp welder. The
Check the tension on the drive wheel, you also might need a liner, they are fairly inexpensive
Aug 07, 2009 | Campbell Hausfeld MIG / Flux Core Wire...
Welder work OK with flux wire, cannot get penatration in MIG mode
Are you using combination argon/co2 gas? You need a flow regulator and should have it set for about 10cfm. Note that this is different than a pressure regulator. The problem you note is a result of inadequate or improper gas.
Mar 10, 2009 | Campbell Hausfeld WG2060 Mig/Flux Versa -...
I have a Campbell Hausfeld MIG Welder 80, The wire will not feed,
Here's a link to the Campbell Hausfeld web page. Look under "Service Center" for "Find a Part." I hope this has what you need.
http://www.chpower.com/webapp/wcs/stores/servlet/chHome_10051_10001_-1
Feb 22, 2009 | Campbell Hausfeld RBWG202000 NA 70 Amp....
Manual for a Cambell Husfeld welder Model WF2000
You can download PDF versions of the manuals for CH welders at the Campbell Hausfeld website.
Look on the left under the Service Center heading for a link to manuals.
Rank this answer if you found it useful,
Carl
Sep 20, 2008 | Welding Tools
Welding Tools Logo
675 people viewed this question
Top Campbell Hausfeld Welding Tools Experts
rjivaro
Joseph Mueller
Joseph Mueller
ray gallant
Are you a Campbell Hausfeld Welding Tool Expert? Answer questions, earn points and help others
