Question about Toshiba 43A10 43" Rear Projection Television
Screen flipping &double vision - Toshiba 43A10 43" Rear Projection Television
Tmtmail.co.ukmy samsung projection tv has double vision and i dont know how to amend the lens can yu please help thank you
double vision in a rear projection tv has several reasons. one is convergence magnets are out of tune. u need to tune them which is back side of picture tubes. u please observe that which color is producing the double vision. the lens are firmly fixed & therefore need not to adjust. other option is to adjust the convergence of tv by going to service mode by remote.
Sep 13, 2011 | Samsung Televison & Video
Blue streak now double vision on outside.
coversion amp ic have died you need to call al tech to replace them parts are cheap but labor is going to get ya
Sep 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
I have a 53inch RCA big screen tv, we have double vision
Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if the option has disappeared or not and I can asssist you with how to fix it.
Jun 14, 2009 | RCA D52W23 52" HDTV CRT TV
The only issue with it is it has a double vision screen (The colors are kinda messed up)
JUST GET MAGNET AND TRY TO PASS IT BY THE SCREEN, OR GET IT CLOSE TO THE MESSED UP COLORS, I HOPE IT WILL HELP, LET ME KNOW IF IT WORKS
May 13, 2009 | Samsung PCH521R 52" Rear Projection...
Double Vision (Mainly around the edges of the screen)
Look for your Convergence amps and check the solder connections on them....you may only have to resolder the amps...and if they fail in a couple weeks, then replace them...
If you don't beat up the convergence amps for WEEKS operating them with the bad connections, they can survive...
Jan 29, 2009 | Toshiba 50HDX82 50" Rear Projection...
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
any repair shop can re converge the tv for you.id do some calling arond and get a few quotes to see what it would cost to have them come to you
Oct 09, 2008 | Mitsubishi WS-55513 55" Rear Projection...
3D like view on my screen
you ned to replace both convergence ICs they are STK392-570 you can get replacement ICs at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Aug 21, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mounting
rosen do a double stepped mounting bracket which fits in place off the rear air con controls, these controls fit into this new spacer and the screen then fits onto this spacer
Jun 04, 2008 | XO Vision 12.1 Flip-Down Monitor w IR"
Double vision
Rebuild convergence amp circuit.......use kit # X480293......
follow kit instructions.................T.
Apr 19, 2008 | Hitachi 43F300 43" Rear Projection...
Double vision On JVC AV-56WP74 56
You have an convergence problem, There are 2 IC's that go bad and a few resisters that can change value. If you flip the board with the Chips inspect the pins for cold solder joints. The IC's can be purchased from matelectronics
Jun 17, 2007 | JVC AV-56WP74 56" Rear Projection...
Toshiba 43A10 43" Rear Projection Television Logo
20 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
