Question about Canon PowerShot S51S Digital Camera
How do i change the resolution for taking video
  • 3 Answers
Press Func button - icon for resolution/frame rate is second up from bottom.
Posted on Oct 04, 2009
Auto adjustment for resolution won't stay at recommended setting
Linda
hello, for some monitors, when change resolutions take seconds to change, automatic, others have to save them. or your signal if analog, HDMI, or digital try to compesate the screen signals,
when use automatic adjustment, the monitor set for the scale designated in your video adapter.(video card)
Carl
Dec 05, 2015 | Gateway HX2000 20" Monitor
Widen the screen on Westinghouse tv
Screens are controlled by ASPECT RATIO.
Monitors can have 4:3 16:9 and 16:10 ratios.
You are doing 1 of 3 things.
  1. You have a regular monitor and the tv and are duplicating the screen.
  2. You have a regular monitor and the TV and are extending the screen.
  3. You have just the tv connected.
Your video card has to have a screen resolution that meets the tv's ratio to have the tv take the full screen.
If your configuration is 1. the tv will only match the monitor resolution, so if you change the screen resolution, you may get bars on the monitor, and the tv will go wide screen.
if your configuration is 2. the tv is controlled independently and you can select it to change its resolution to an appropriate aspect resolution. *this requires that your video card gives you the correct screen resolution for your tv. not all displays will work.
If your configuration is 3. the tv is the only resolution that is being pushed and just adjust the resolution til the screen is filled in.
To adjust the screen resolution, right click on the desktop where there isnt an icon and select either Properties (windows xp) or Screen Resolution (windows vista, 7 and 8).
if you have 2 screens press the identify button and it will put a number on each screen. click the appropriate screen and go to the resolution dropdown below. Change, apply and if it doesn't look right, revert and try a different setting. if you try them all and it won't take up the full screen, then the video card can't push the video resolution your monitor wants.
Sep 30, 2014 | Computers & Internet
I cannot change my screen resolution
Boot up in safe mode and see if you can change the screen resolution. If not you are being limited by your graphics card (video card) and driver.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. See if you can change the screen's resolution.
If you can't change the screen resolution, try downloading and reinstalling the video driver.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Video drivers.
May 24, 2012 | Dell Computers & Internet
High pitch noise is coming when resolution is changedyahoo.com
By the picture Ii take is CRT monitor. This Chirp sound when changing video resolutions is like a normal thing because at different resolutions takes different voltage. What you hear will be the flyback transformer discharge of its thousand volts to the new setting as needed.
Feb 13, 2011 | LG Studioworks 700S 17" CRT Monitor
How can i change the resolution on my hp laptop's cam.
You can't change the webcam resolution, but you can change the recording resolution in some programs. I use Debut for recording webcam pictures and videos and it allows me to change resolutions. Video chat services don't let you change it as they limit the resolution to save on bandwidth.
Apr 25, 2010 | Logitech Webcam
Videos are now a small picture and when expanded are POOR quality
It seems that you have reduced the resolution of the vedio capturing format. In format settings change it to maximum avaialbe resolution such as 1024x900, etc ( maximum among available). Also for increasing the still photo resolution, select the maximum mega pixel such as 3.2/5/etc.. Usually the mega pixels can be changed using any short cut keys.
Aug 11, 2009 | Canon PowerShot A470 Digital Camera
Changing Screem Res to 1024x720
Hi LSmitten,
So your brother has laptop, and you can't change the screen resolution, I will take a guess that most likely the screen resolution right now is 800x600 or 640x480 which most games won't work with. The most likely culprit why you are not able to adjust the video resolution is that he hasn't installed the video driver of the laptop yet. You should install the video card driver for your laptop in other for you to change the resolution of your desktop. I suggest that you download the latest video driver from the computer manufacturer's website.
Also if he is using a older laptop, the LCD screen on a laptop has a set maximum resolution that you can use only. Older model laptops can only go as high as 800x600 upto 1024x768. Most of the new laptop nowadays have a minimum LCD panel of 1280x800 widescreen. Check the PC manual to see the max resolution the LCD can handle.
Hope this helps!
Peace! :)
Oct 20, 2008 | Computers & Internet
Have windos XP Home , not able to change resolution, is there a download that will help or advise on how to change solution currently at 640 X 480 would like 1024 X 728
It's not Windows XP that is blocking you from changing the resolution, it's you Video Graphics capability. Look on Microsoft Update to see if there is a video driver update, it there isn't, you may need to look into a seperate video card either PCI or AGP depending on what your computer will take.
Mar 20, 2008 | Sharp LL193A 19" LCD Monitor - (LL-193A)
CHANGING THE PIXEL RESOLUTION
One user manual covers the DCR-DVD905 and the DCR-DVD505.
Go to
http://www.sonystyle.com/webapp/wcs/stores/servlet/SYCustomerCare?storeId=10151&catalogId=10551&langId=-1
click on 'Manuals/Specs & Warranty' in the Technical Support section, thn on the subsequent page, in option 2, enter DCR-DVD505 as the model number. This will take you to a page where you can download the operating guide.
Good Luck.
Mar 10, 2008 | Video Cameras
Canon PowerShot S51S Digital Camera Logo
43 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
