Question about NetGear WGR614 Wireless Router
Router won't do ethernet to set it up---previously set up in another apartment, now when i go to set it up here it jumps straight to wireless but wireless isn't working.
    Problem Solver:
  • 5 Answers
  1. Disable the Wireless Adapter on your computer.
  2. Hold the "Reset" button on the pack of the WGR614 for 20 seconds(might need to use a paper clip/small pen)
  3. Connect an ethernet cable from one of the numbered ports on the Netgear and connect it to your PC
  4. Click on "Start", "Control Panel", "Network and Internet", "Network Connections" (or on Vista, "Network and Sharing Center", then "Manage Network Connection")
  5. Double-click on the "Local Area Connection"
  6. Click on the "Support" tab (or "Details" on Vista)
  7. Make sure an IP address and Gateway are listed. With netgear it should be 192.168.1.1 or some models are 192.168.0.1 for Gateway. If you get 169.x.x the network cable is probably faulty.
  8. Open web browser
  9. Type in the address of the default gateway(probably http://192.168.1.1) (Default user: admin, default pass: password)
You can re-enable the wireless adapter once you've configured the router. Make sure to pick a Unique SSID. (Unless you already are familiar with where to locate the saved wireless profiles on your computer so you can delete the old profile when the settings do not match)
Posted on Oct 04, 2009
My computer has internet connection through the port on the back, but not through the router for wireless networking. All the connections from the modem to the router and further to the computer are...
So, just to confirm:
PC via ethernet has internet connection OK?
The router IP is 192.168.1.1
The PC ethernet IP is 192.168.1.n (n is not 1)
If you unplug the ethernet cable, you no longer have a connection.
If these are correct, did you previously have wireless internet working? If so, just reboot the router (unplug its power).
If not, you'll need to check the wireless settings in the router with those of your wireless network card, making sure you are using matching security settings (WPA-PSK, AES256, matching 'key').
To access the router, browse to http://192.168.1.1 (ensure your ethernet is plugged in). If you haven't changed from the default login details, you'll find them in the router manual.
May 16, 2010 | Linksys WRT120N Wireless Router
Securing Wireless Network Access with Belkin 54g Router
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
May 02, 2010 | Belkin (F5D7230-4) Router (587009)
Laptop cant connect to internet
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Apr 06, 2010 | Linksys Wireless-G Broadband Router
Set up wireless security, now no ethernet connection with router
first try to repair your connectivity under network settings.If this doesn't work unplug both the power supply and router for a minute, plug them both back in and restart your pc. Let me know if this works.
Dec 26, 2009 | Linksys Wireless-G WRT54G Router
Connecting My Cable TV Modem To Wireless Router
yes you can. you simply plug the modem into the input port on the wireless router and then plug which ever device you want to hardwire into the back of the wireless router. that's all :)
Nov 16, 2009 | Computers & Internet
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I changed the name of my wireless router and can't connect now
delite your previous saved network and network settings
Feb 03, 2009 | Linksys Wireless-G WRT54G Router
Configuring nbg334w router
To configure the wireless router it is recommended the it is connected directly to router.
Please follow these steps to fix your issue
1. Reset the router using reset button on the back of the NBG334W router
2. Configure or change the laptop ehternet adaptor setting to "Obtain IP address automatically.
3 connect laptop and router using ethernet cable. check the ip address using ipconfig command in DOS prompt. If IP address is 0.0.0.0 or 169.X..X..X run command
ipconfig /release
ipconfig/ renew
best way restart the computer
4. if you still have issue in getting ip address double check ethernet cable and try reseting the router again.
5. Still problem persist install new firmware on the router. you can download router firmware from
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906164737&ModelIndexflags=0,420070320142921
Please vote if this information is helpful in resolving your issue
Dec 27, 2008 | Zyxel Prestige 334 Router
Will it work
hello!
yes, the router will work with your pc and xbox 360.
You have to set the internet connection first between you modem, router and pc before you configure the xbox 360. try this and see if it will work with your network
you may try this and see if this help solve your problem
to set up your modem and router:
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
to set up your xbox 360:
Step 1: Power down the Xbox and connect a regular straight thru Ethernet cable from one of the numbered ports on the router and plug the other end of the cable into the Xbox™’s Ethernet port.
Step 2: Power on the Xbox without a CD in the tray and the Xbox Dashboard should appear.
Step 3: Select Settings and press A on the controller.
Step 4: When the Xbox screen appears, select Network Settings and press A on the controller.
Step 5: When the Network Settings screen appears, select IP Addresses and press A.
Step 6: Under Configuration, select Automatic and press A on the controller. Take note that the IP Address being shown will be the Xbox’s IP Address. Press B to return to the previous screen.
Step 7: When the Network Settings screen appears, select DNS Servers and press A.
Step 8: Under Configuration, select Automatic and press A on the controller to save the changes. Press B to return to the previous screen.
Step 9: When the Network Settings screen appears, select PPPoE Settings and press A.
Step 10: Under Configuration, select Off and press A on the controller to save the changes. Press B to return to the previous screen.
Step 11: Once the Network Settings appears, select Connect and press A to test the connection.
Apr 26, 2008 | D-Link DI 514 Wireless Router (DI-514)
NetGear WGR614 Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
