Question about Compaq Presario 5WV280 (202553-003) PC Desktop
AHave a problem in device manager with an ethernet driver. Cannot find one that will work.
  • r3jar Oct 04, 2009
    I have already tried tat drive ande it did not work. so I am not impressed with your service.
  • 3,940 Answers
This is the WIndows 2000 NIC driver http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=33486&lc=en&dlc=en&cc=us〈=en&os=181&product=93925 If you are using Windows XP it MAY work but from what I see, the NIC driver should be native to XP. But you can give it a try. Since the Network Card is an Expansion Card, it is also possible it has been replaced already with a different model. If this driver doesn't work, you might consider replacing the NIC as they are generally under $20
Posted on Oct 04, 2009
  • IQUIT Oct 05, 2009
    #1 You didn't mention what you tried.
    #2 As I already pointed out, the Network Card that shipped in that model, has XP native support, so if that card is still in the system, it is likely non-Functional (Hence the device manager error)
    #3 Since updating the driver did not resolve, the most likely solution is to replace the card (Again, mentioned in previous response)
    Here is a decent card at a good price:
    http://www.newegg.com/Product/Product.as...
Ethernet device not working
Is the driver installed? Check to make sure the driver is install in the device manager under the Control Panel. Click Start/Control Panel then look for System or System and Performance. Open it and look for the device manager. Check under Network for the ethernet or Local network connection and make sure it is working.
Look at where the ethernet cable goes into the computer and you should see it light up. If there is no light, then either the port on the computer is bad or the cable is bad.
To download the ethernet driver try the steps below.
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Network drivers.
May 04, 2012 | Computers & Internet
Motherboard P4i65GV ASROCK. Installed WIN XP service pack 2 , ethernet controller is not installed shows exclamation mark in device manager.Unable to connect to net.
you must ethernet controller driver first
goto device manager, right click at exclamation mark, then chose update driver, follow instuction step by step, if it ask for cd driver insert motherboard cd driver, if you did not have cd driver download ethernet controller here
http://www.asrock.com/MB/download.asp?Model=P4i65GV&o=XP
wait until process finish and exclamation mark at device manager disappear, and try to connect your computer to internet
i hope this helpful
thank you for using fixya
Feb 02, 2011 | Asrock P4i65GV Motherboard
I get no sound nor ethernet reception
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
as for ethernet
if your modem has an ethernet connection the drivers should be on the disk provided by the internet provider
control panel admistrive tools,computer management,device manager scroll down network adapters +expand Ethernet driver right click update driver,disable,uninstall or select properties general you can trobleshoot or driver to update,rollback or uninstall
hope this helps
Nov 23, 2010 | Gateway M305CRV Notebook
My ethernet port do not work I think my pc missing dell gx60 ethernet controller drivers
Verify if the driver is installed properly for the ethernet card using the device manager. If the device is not shown in the devoce manager, make sure the wiring for the card is done properly and there is no loose connection. If the problem continues, try replacing the ethernet card. If that too fails, there is some problem with your computer mother board
Hoe this helps. Feel free to reply if you have any doubts.
Regards
Sherbaz
Aug 06, 2010 | Dell OptiPlex GX60 (SFFDELL-C2G) PC...
Ethernet is not working. Enabled in BIOS. Device Manager says it is working. Known good cable and connection. No lights at ethernet port.
try updating the driver for it,iv run into this problem before and the device manager still would say its ok.Go to the tashiba web site and download the driver from there.
May 14, 2010 | Toshiba Portege 2000 Notebook
Ethernet controller didn't work
Have you checked your drivers?
Go to control panel - system - device manager
Or control panel - type in device manager (depending on your os)
If there is a question mark beside your ethernet controller than you need to update the driver. If you have the disc pop it in the computer and then right click the ethernet controller and click update driver and then follow the wizard through and that should fix it if the driver isn't there.
If you haven't got the disc you will need to download the driver from the manufacturers site.
Feb 05, 2010 | Dell Latitude D600 Notebook
Ethernet connection has just stopped working. 80072ee7 error. However, device manager says adapter working properly, orange green lights working/flashing. cable checked to another comptuer without...
Try going into the control panel and then into the device manager. Find the ethernet device and remove it. Then re-boot the computer and the OS should re-detect the card and re-install the drivers. Hopefully this will get the card working again. Let me know if this helps.
Nov 18, 2009 | SMC Realtek 10/100TX PCI Fast Ethernet...
The ethernet port doesnt work or doent recognize
install the right driver for your ethernet.
check your hardware device manager if your network card is present..if there are unknown devices that might be your ethernet. install the right driver
Mar 20, 2009 | Compaq Computers & Internet
Ethernet not working after format and xp reinstall
Right-click the My Computer icon and select Manage, then go to the Device Manager in the list on the left and find the Network Adapter from the list on the right, right-click Network Adapter and select Uninstall. When you reboot, XP should find the Adapter and reinstall it automatically. Another reboot may be required.
If it still will not connect, go to the NIC Manufacturer's website and download the driver to removable media. The Driver Update option can be accessed in the Device Manager, but this time select Properties when you right-click the Network Adapter, and go to the Driver tab.
Dec 22, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Ethernet
You may try this: Click Start > Right click on "My Computer" > Select "Properties" > Hardware Tab > "Device Manager" button > Click the "+" next to "Network adapters" > Right click on your Ethernet adapter > select "Properties" > select Driver tab > select "Roll Back Driver" button (third button down on the left side). This will work if an updated driver is at fault.
If the above fails you could then try Right Clicking on your device in Device Manager and select "Uninstall", and after uninstalling reboot and let Windows New found Hardware Wizard pick up the device and try to correct the fault. Otherwise if the Adapter is integrated you can look for updated driver at Dell's Support site, and if added on (via PCI slot) check at the adapters Manufacturer's site for the proper driver.
If all else fails, replace the Network adapter.
Good luck.
May 24, 2008 | Dell Dimension 2400 PC Desktop
Compaq Presario 5WV280 (202553-003) PC Desktop Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
