Automatic wake up call
HI we have toshiba regza 32" LCD TV. We recently moved it to a bedroom and it seems to switch itself on for a minute or so at 3 a.m. The noise wakes us up. Can anyone tell me how to sort it?
  • 1 more comment
  • mitsmaz Dec 22, 2007
    Hi, thanks for prompt reply, the TV is a Toshiba Regza 26 inch 26WLT66 LCD, the alarm is set to zero and the automatic search facility is turned off and it still occurs. The factory reset sounds good. Thanks
    Hi, thanks for prompt reply,the alarm is set to zero and the automatic search facility is turned off and it still occurs.
    Thanks
  • Anonymous Mar 23, 2014
    the tv switches itself off and now it does not come back on
    President:
  • 1,944 Answers
Could you please tell me your exact model name of your TV? I am not aware of any 32 inch Toshiba model that supports an alarm auto on feature. When you press sleep on your remote...is there an option for alarm? Nevertheless, a reset factory defaults should solve the problem.
Posted on Dec 22, 2007
    Scholar:
  • 54 Answers
I dont know the model of the lcd but i will try help, click the menu button on the lcd or the remote , look for something that say's Timer, Wake up , Alarm , Auto on , Auto power , Auto Switch , if you find any of these option's play around with the setting's there should be a clock type thing to change and a off / on , tab to select , it also maybe under the time/clock options , otherwise on the remote look for a button that when u press, on the screen you will see something like 5 hours, 6 hours, or any time /clock looking display that comes up on the screen, and keep pressing it till it says off or -- , or zero ,
Good Luck
  • Geoff Smith
    Geoff Smith Dec 22, 2007
    more than likely one of the buttons on the remote was pressed , so its just a matter of finding that button ,
Hi. I have a 42"
The best solution to this problem is to call Toshiba directly and ask for assistance. Any TV repair company/shop will probably charge you an automatic fee to assess the problem, and then tell you it's a very expensive fix. With just the model and serial number of your TV, an easy 5 minutes will get you the answer you are looking for.
May 03, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
TV saya Toshiba Regza 32 " flat, suatu hari
Hallo,
Setahu saya , penggantian transistor pada model-model LCD atau plasma jarang di lakukan, karena beresiko kerusakan komponen yang lain. Jika memang mau melakukan penggantian part , sebaiknya di pastikan dulu kerusakan penyebab rusaknya transistor tsb. jika yakin tidak ada yang rusak, transistor seperti model apa yang kamu cari bisa di cari di internet.
Atau tulis no part nya , mungkin saya bisa bantu.
Terima kasih.
Mar 21, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Recently I purchased Toshiba REGZA 47 XL 700 E is LED. Is this TV LED ?
Yes and NO your tv is a LED. To be exact it is a LED Backlight LCD TV. An LED-backlight LCD television is an LCD TV that uses LED backlighting instead of the CCFLs used in traditional LCD televisions. It is not a true LED display but is called "LED TV" by some manufacturers.[1] The use of LED backlighting has a dramatic impact, resulting in a thinner panel, less power consumption and heat dissipation, and a brighter display with better contrast levels. You can go to http://www.regza-asia.com/pdf/LEDTV/XL700/47XL700SPEC.pdf and look at the complete specs for your tv
Mar 07, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Hi I have a Toshiba Regza 37" LCD it seems to have developed a fault ie it keeps swapping to the scart channels as if someone is pressing the remote constantly, it seems to do it intermiterly? I have...
Hi i have the exact same problem and have done for about a month now, If you find a solution please could you email me.
smcglinchey4@hotmail.co.uk
Starting to get a bit bored of no TV now!!
Many Thanks, Stuart
Jul 02, 2010 | Toshiba Regza 32LV67U 32 in. LCD HDTV
32'' Toshiba Regza difficuut to switch on from plug & standby
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 22, 2017 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
May 28, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Cracked screen
The LCD screen itself often cost more then the tv set itself. If you have accidental insurance you might see if they cover this, otherwise this will make a nice lava lamp like art display for a bedroom wall.......
Apr 22, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba Regza 32"
I would return it, sounds like the bulb died.
Feb 22, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Televison & Video Logo
169 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
