Question about Belkin N Wireless Modem-Router F5D8633au4A
Belkin wireless n route only puts out 54mbps
How do I increase my wireless speed? My Belkin N wireless router is only sending out a signal of 54mbps. Or my networked pcs are only utilizing 54mbps. How do I increse that?
  • 466 Answers
The reasons you only get 54mbps could be: one, your networked PCs don't support N-mode and broadcast in G-mode, so that the router falls back to 54mbps.
Two, the signal strength is too low or the radio noise level is too high to allow N-mode operation at full speed.
So, after checking with the manuals and vendor brochures, you should try connecting the router with a single PC close by - say, ten feet in the same room - and check connection speed. If you can connect at 108 or 125 depending on which N mode you have (N, N+, N1...), the problem is likely to be distance, walls or noisy equipment.
If you still can't connect, double-check the configuration of both router and PC (wifi board "Advanced Properties" in Hardware Management) to check whether N mode is enabled at BOTH ends, especially "Wireless Mode" in the PC.
If it still doesn't work, I'd test it with a Belkin N USB key, for example, just to check that when router and client vendors say, "802.11N", they do indeed refer to the same thing. That's not so cut and dried a thing as one would expect. The N-mode standard was not completely defined from the start, so that many vendors jumped the gun and implemented their own "N-modes" which are often NOT compatible with each other. If you had a US Robotics router and a Yuwasa (and outdated SparkLANs, IIRC) wifi board, you'd discover that you could only attain 11 mbps - and if the USR router was set for "G only" or "G and N" instead of "B, G and N", you would get no connection at all.
Posted on Oct 04, 2009
  • 32 Answers
You can go into the router setting by http://192.168.1.1/in the address bar.got to wireless settings>>advanced settings.Then enable n type wireless protocol setting for maximum speed.Normally the best wireless protocol is automatically selected by the router.Most probably the wireless card in your system only allows a maximum speed of 54mbps.that is it works on a/g wireless protocol
TM-G5240 router is slow
Is it the wireless device or your ISP? Location the same on wireless device? Computer same place? Channel the same? Antenna the same? Cables the same? You will never get what is advertised. That would under perfect conditions and the Max it will work. Figure the miles of cables and equipment between you and the ISP and all the places it could degrade a signal. Try a High location for the device, change channels.
Jan 02, 2013 | D-Link Tmobile Hotspot Tmg5240 Wireless...
My belkin wireless g router is working on my laptop but not on my smartphone
Open the wireless setting on phone select your wireless, or make discoverable, put in password.
Dec 22, 2012 | Belkin F5D72344 Wireless G Router 54Mbps...
Belkin Router Signal Weak
Wireless configurations are tempermental over larger distances. Some routers do have the ability to increase the signal strength to over come this, but a good location is key.
The more obsticals in the way the slower the connection will become. Closed doors, being buried under books, underneath desks, can all cause the signal to come through a slower speeds to compensate.
Make sure your router is in an elevated location to help with a less blocked signal.
Are you using a Wireless-N adapter on your computer? If not, you might need an extender because Wireless-G does not have the same range as -N.
With the model number of your Belkin router I might be able to assist more.
Jan 20, 2010 | Linksys Wireless-G Broadband Router
My laptop isnt picking up the internet signal from the router. The light on the router that tells you if the wireless internet is working doesnt want to turn on. i've already tried unplugging the rout
Hello, I give advise & support on using a computer. If you need basic computer skills and advise, I will help you. You can get support from me, via Msn live chat, if you purchase a $4 one hour online session. If you want to find out more, please send an email to shane213@live.com
Apr 15, 2009 | NetGear WGR614 54Mbps Wireless Router...
Problem with Pre n Router
54mbps is what the Belkin routers wireless signal transmits at! This cannot be altered and is working correctly regardless of other wireless card speeds.
Jul 10, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
Signal strength very low. Belkin ADSL2 modem with wireless g router F 507632-4
signal is bouncing off doors and walls to get to your comp
move comp closer to modem if it increases and your signal strength increases then you know youll have to be close to modem
other problem someone taped your signal and it working off of it call your provider to come out test the wireless signal strength and or password your wireless router settings so some one cant interfere with signal
i dont like wireless myself in the home i go straight cable with ether net cord this always has strenght and cannot be tapped
May 09, 2008 | Computers & Internet
Belkin g+wireless mimo router
make sure your router is set at the correct transfer speed eg 54MBPS as your pc may only have a wireless adapter that supports 54MBPS as some run at 108MBPS. You may also need to check that the routers DHCP setting is enabled so as to give your pc an automatic ip address and also check your wireless adapter or card properties and on the TCP/IP line click properties again select obtain ip address automatically.
Sep 04, 2007 | Belkin (F5D7231-4) Wireless Router
WIRELESS ROUTER
If you mean by the roadrunner that you are connect via a cable, the reason why the signal may fail and stop you from watching streamed video is that wireless is only 54mbps and not the best speed for streaming, but wired streams at 100mbps and is constant speed whereas wireless doesnt give a constant true speed of 54mbps it can reduce considerably.
Aug 05, 2007 | Belkin (F5D5231V4-SN-PD) Router...
Belkin N Wireless Modem-Router F5D8633au4A Logo
1,102 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
