Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
Ice dumps before freezing - Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
    President:
  • 1,304 Answers
Pop the cover off you ice machine you should see a set screw, with a plus and minus turn it one 1/2 turn
check the ice,,,
if it still needs more time give in 1/2 turn increments'
untill your happy
Posted on Oct 04, 2009
Model CME256AS-1D will not go back into freeze cycle and will eventually stop, requiring the unit to be reset.
So is the unit going into a harvest and not going back to a freeze cycle? dose it dump a batch of ice but wont go back into a freeze cycle? before you reset it have you pulled the front cover to see what code it is giving? any time you have to reset it that means it locked its self out on a fault. if unit freezes and go's into a harvest and dumps the ice but dose not go back into freeze cycle check the door switch when the ice dumps the deflector door opens a magnetic switch which tells the board the harvest has finished and then the freeze cycle begins. Now if there is no ice falling off the plate to open the door then the board will time out and try 3 more times to make ice before it locks it out. the same go's for the harvest.
Jan 08, 2014 | Scotsman Cooled Modular Contour Cuber Air...
2 problems one water escaping to the drain freeze cycle short
first, freeze cycle too short because you are loosing water. Water may be leaking thru the dump valve. Look at drain while machine is running and see of alot of water is draining. The dump valve spring may be week or there is trash in the dump valve preventing it from seating properly. drain water first before pulling dump valve apart.
Aug 29, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
May 24, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
No ice
Pour about 1/2 cup of water into icemaker . If it freezes and dumps , the water valve is bad ( where the wall water line connects to the fridge ) . If it freezes and does not dump and the ice stays in the icemaker , replace the icemaker . Also check the fill tube ( the tube going from the freezer wall to the icemaker itself ) to see if it has frozen closed . If it has , the water valve is not closing completely , and letting a drop thru and freezing in the tube . Also an indication of a bad water valve .
Aug 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a kenmore 106.53593200 fridge the ice maker not making ice but i can feel its running
As long as your freezer will freeze water, your ice maker will make ice. All the ice maker does is supply the water, then dump the ice after it freezes.
So, that narrows it down to: 1) Either the ice cubicles are not filling with water, or 2) The ice is not dumping into the bin after it freezes.
To check for #1, you should be able to look into the ice cubicles to see if they're filled with water (or ice). If they are, go to #2. If not, you've probably got a defective water valve.
If the cubicles are full of ice or water, but don't dump out, the most likely culprit is the cubicle heater, which slightly heats the walls of the cubicles so that the ice can be more easily ejected into the bin. Unless you're VERY mechanically inclined, this is a job best left for an appliance repairman.
Jun 27, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
88 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
