Question about Amana Refrigerators
My freezer ice maker was leaking water on my food and then freezing. I removed the tray and thawed the block of ice that had formed and then turned the knob at the bottom of the fridge. the knob seemed to be some kind of timer. now the fridge will not cool.
    President:
  • 1,304 Answers
Thats a deffost timer,
it should tun back on in 15 20 mins all will be normal
check the ice maker fill tube sounds like its leaking
Posted on Oct 04, 2009
My ice maker in my side by side refrig/freezer leaks water so that a solid block of ice is formed in the tray maker. This prevents dispensing of cubes. What can I do?.
The cause of that is the water inlet valve is not fully closing but instaed its staying open a little and seeping water through it all the time which is dripping into the storage bin for the icemaker and freezing all the ice into one huge block. To repair that the water inlet valve on the back of the ref. where the house water supply line attaches to would need to be replaced.
GENE
Sep 22, 2011 | Amana Refrigerators
Water is accumulating & freezing @ bottom of freezer ice maker has been removed water to fridge has been turned off still, water coming from somewhere & freezing
This is what it sounds like to me. There is a drain hole for the defrost water to drain down to the "drip pan" If that hole in the drain pan is clogged. Then when the defrost system melts away the frost in the cooling coils. Every 6 or 8 hours. The water will accumulate in the bottom of the freezer compartment and turn into ice. This is a very common problem.
The solution.
Put the food in the freezer and fridge into coolers and pack with Ice. Get the 99 cent coolers at the supermarket and buy some Ice there too.
Shut the fridge down and open the freezer door. chop out the Ice in the bottom of the freezer compartment, but not in the drain area directly below the coils. that will be hard to get to and you may damage the fridge if you just chop away.
To speed up the process, get some hot water in a glass and pour it into the area below the coils
(that should be a solid block of Ice as well). If you cant get to this easily, just wait for the fridge to thaw out naturally.
After it has thawed out, you should be able to locate the drain tube in the bottom of the small tray
below the coils. Stick a flexible piece of wire, or pipe cleaner or something of the sort into it to completely unclog it. So when you pour water into that tray, it immediately drains out completely.
into the "drain pan" located below the freezer compartment in the base of the fridge.
I hope this helps,
Best Regards,
Mark
Dec 30, 2010 | Maytag MSD2756GES Side by Side...
Ice on the food
why did you stop the ice maker? was it not working properly? was it over flowing or leaking? do you have a sheet of ice forming in the ice maker tray? if your ice maker was leaking then your water valve is not shutting off completely and could be leaking down on the food. if this is the case - you need to shut the water line off coming into the refrigerator and replace your water valve.
if it is frost that is forming on your food instead of ice then you should check to see if the refrigerator is defrosting properly. if the refrigerator is not defrosting properly you would also first notice that the refrigerator is not cold enough and then later that the food in the freezer eventually thawing.
May 28, 2010 | GE GSS20IEP Side by Side Refrigerator
Water dripping from freezer into refrigerator area and frozen water in freezer
The defrost cycle is melting ice that will not go down the drain tube in the rear of the freezer. This can be a clogged tube due to debris, organic growths or ice blocking flow. What doesn't end up dripping into the fridge ends up freezing in the freezer compartment. Make sure the fridge is level or tilted back slightly.
Unplug the fridge from power. Remove the contents of the freezer and remove the ice maker, back wall plate and floor plate in the freezer section. Remove ice build up on the floor and tray in the freezer by thawing and soaking up water. Flush hot water (use a turkey baster to get at it) at the opening of the drain hose that is connected to the tray to thaw any ice.. once flowing to the evapraor tray under the fridge, mix up 1/2 oz of bleach and 4 oz of water and pour down the tube to kill any bacteria.
Reassemble and restock the freezer. Monitor the temperature of the fresh food (34 deg) and freezer (0 deg) compartments. If you notice the temperatures start to climb, there may be a problem with the defrost timer, terminator, etc. and may require a pro's help.
Mar 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
The water is leaking from the Ice dispenser and the food is thawing
Seems like the freezer is not getting cold enough. If the ice maker was leaking the water would freeze. It would not cause the food to thaw.
Oct 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
Turned ice maker off prior to a ten day vacation. Upon return, it would make thin shelled ice cubes and finally stopped altogether. Could the water line be frozen How does one de-ice?
Fastest way is to remove the ice maker tray so that you have an open area where the ice maker filling tube is, then cover your food with a towel or something to help prevent it from thawing while you let refrigerator defrost for about 20 to 30 minutes with a hair drier on warm or a small fan blowing directly on ice maker where the water fill tube or opening is. I does not need to be right next to the ice maker just an unrestricted open area to let it warm sufficiently to thaw it out without thawing out your food in the freezer. A small piece of ice can stop the valve from opening and this can happen if it is not used regularly.
Oct 08, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
Ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Aug 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
Thaw's. Turn-off for period of time it would freeze as normal
Make sure nothing is inhibiting air flow. I don't think it is advisable to store food in an ice machine however that is not likely the problem unless the food itself is inhibiting air flow. Most ice machine manufacturers recommend against storing any food in an ice machine. If there is a freezer component in you model the check to see if the evaporator coils are frosting up and the frost is blocking airflow causing the ice storage chamber to get warm. High humidity can cause frosting. Leaving a door to the ice maker open too long can cause frosting. A low refrigerant charge can do this although it seems logically like it should not. With a very slightly low charge one end of the evaporator gets super cold and the other end is not cold enough. Frosts starts collecting on the super cold end and accumulates across the evaporator coil to the other end eventually blocking all air flow. With too much humidity from open doors frost accumulates over the entire evaporator evenly but still blocks. You shut the unit down. It thaws out and works OK on restart until frost again builds up. If its not a frosting problem but it just stops making ice then the ice may not be releasing. Check the water supply and change any filters to insure good water flow. A good water supply is required for proper release and harvest of the ice in many ice machines. If the ice doesn't release it takes a shut down and thaw to clear the suspended ice out. Check for these things and write back if you need further assistance and can provide me with more details.
Jan 19, 2009 | Hoshizaki Freezer Commercial Ice Machines...
I have a AMA IC6 ice maker and the ice is stuck together form water running over into the catch tray.i have removed the ice maker and let it thaw then reinstalled and the same thing happened. any...
Having problemAMA IC6 Icemaker. Water leaking into tray as it is making cubes causing previous cubes to freeze together and to the bottom of the container. Trying to defrost to see if that helps. Any suggestions appreciated.
Jun 09, 2008 | Amana Refrigerators
Freezer compartment leaking water and icing up inside
Solution #3 fixed it.
Pulled everything out of the freezer, found where the drain was, it was blocked with ice, hot water and then a flexible straw, the kind that comes from an ammusment park kids container, shoved it down the opening after the hot water and it cleared whatever was blocking the drain.
Thank you very much - Mark
sdsu1985@yahoo.com
Sep 25, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
97 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
