Question about Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
Magneto wires on 49cc
It took all of the wires off. to bypass old ignition. I just want to connect the magneto and spark plug wires. Where do the two wires coming from the magneto go to pull start? One is green and the other is red with a black stripe
How do I fix my 49cc 2 stroke pocket quad it has
If you have replaced the spark plug then the possibilities are the ignition coil is weak or the starter mechanism is faulty.
See this site for details of parts.
Mini Atv Quad Parts 47cc 49cc Stock Replacement
Sep 15, 2014 | Quad 47 cc / 49 cc Pocket Mini Bike...
Replaced coil on 49cc will not fire
u got spark put a dime in the plug that's the gap u need hope this helps or just a bit of gas into the head where the plug goes good luck
Jan 05, 2014 | RTO 47cc / 49cc Pocket Dirt Bike Atv...
Model 917.275670 wil turn over but not start
There could be several problems. (1) Is it getting fuel to the carburetor? If not check fuel filter. (2) There is also,a fuel solenoid that controls fuel going to the carburetor,when the ignition switch is off the the solenoid closes a valve,stopping fuel to the carb. When the ignition switch is on the solenoid opens the valve,allowing fuel to the carb. You will know it is functioning,when you hear a small click,when you turn on the ignition switch. If you don't,then this solenoid is bad. (3) Is the spark plug fouled up with carbon deposits,if it is,clean with a wire brush. Replace plug wire,turn on ignition switch,rotate motor until you see a spark,if you see a spark,is it weak looking? If so,replace plug with a new plug. Any time you remove a spark plug,check the spark plug gap, should be .030" for a Briggs& Stratton motor. Use your Owners's Manual,for the correct gap,for your motor. Now,if you haven't,seen a spark at the plug it could be a bad plug wire. Replace the plug wire and run your test again,if you still not see a spark,then the magneto,it self is bad,these seldom go bad. More likely the fly wheel and the magneto has corroded (rust) on both parts. This breaks the magnetic field,thus no current to the spark plug. Take a look at the small electrical wires attached to the magneto,are they broken or corroded at the connectors. These wires lead to the ignition system. If corroded,clean the ends or if the wires are broken splice wire or replace the magneto. You should,take a good visual look,at the carburetor,is it dirty? Is the air filter(s) dirty? It they are dirty,clean by using compressed air or wash and let dry. Remember this,the motor has to have three items to start and run.(1) Air (air filter),(2) Fuel (carburetor& fuel filter) (3) Igniter (Spark Plug). These have to be cleaned or replaced often,these are the most problem(s) of a "No Start" situation. I hope this helps. Sincerely,Brad Locke DTD 12/04/15
Apr 10, 2013 | Sears Garden
Gentron pro2 6000p has no spark
With small engines, ignition is magneto. Four things can cause a lack of spark: (1) Faulty plug - try a new plug; (2) Bad, shorting, or disconnected spark plug wire - check for high voltage from ignition coil; (3) Bad ignition coil - check for low voltage at the coil input wires; (4) Magneto failure - the pickup coils next to the flywheel may be shorted, loose, or disconnected, OR the magnets on the flywheel may have lost their field or come out. I would troubleshoot this problem by checking and eliminating each of these possibilities in the above order. If all of the first three check out good; I'd have a mechanic check the magneto because this requires at least partial disassembly of the motor.
Nov 17, 2012 | Gentron 6000 Watt Propane Generator with...
My little 25'' Toro riding mower has no spark
did you put a little gas on the plug before you put it back on and make sure the spark plug is gagged correctly. And with the plug out and connected to the wire holding it with a tool you should be able to see sparks. If not it could be a faulty wire.
Jul 12, 2012 | Toro Lawn Mower With Toro Power Tools
I have a cs 4000 ser 00135 series that I am unable to get a spark... I replaced the coil, magneto, plug, flywheel is good... is there a ground somewhere that I am missing?
The ignition switch or it's wire to the magneto might be worth looking at. Remove the switch connection from the magneto to see if you can get spark. The switch grounds the magneto circuit when it is set to 'off'. Good luck!
Sep 11, 2010 | Echo Garden
I have a Briggs & Stratton 18.5 HP Twin Cylinder engine that has no spark. How can I check the magneto? And, there is a wire that goes to the magneto. Should there be 12v to that wire? If I replace the...
It all depends on the model of engine. If it is a twin engine doesn't it have two magnetos.Very unusual for both to go bad It will depend on the type of ignition(points or solid state) The wire going to the magneto could be the kill switch (kills when grounded) Disconnect it and see if you get spark. IF so then it is in your safety/ignition circuit. If you replace magneto usually the gap is .008-.012
Aug 18, 2010 | Garden
Wiring on an old 5hp Briggs and Stratton engine
The "heavy wire" connects to the spark plug. It should have a plug connector attached. There are 2 small wires. One of them grounds to the engine block (probably through one of the screws that holds the magneto in place). The other wire goes to the condensor/capacitor.
Nov 30, 2009 | Air Tools & Compressors
WONT START
Not so many reasons she won't start. 4-Strokes are Simple!
Here they are:
Motor:
Fuel Tank-> Fuel Line-> Fuel Filter-> Carb-> Intake (Valve)-> Piston-> Exhaust (Valve)-> Muffler
Carb (Old Style):
Fuel Side:
Fuel Bowl-> Float-> Needle Seat-> Fuel Ports (Venturi)
Air Side:
Air Filter-> Carb Air Intake-> Butterflies (2)
(Clean 'em ALL!)
Hardware (Motor):
Rotor (Magnets)-> Magneto (Ignition Coil)-> Spark Plug Wire-> Spark Plug-> Cylinder Head (Spark Plug Ground)
Ignition:
Kill Switches (Seat, Clutch, etc.)-> Spark Plug/Ignition Coil-> Ground
Key Ignition-> Battery->Starter/Generator
If one of those fail.......= Non-Starting 4-Stroke!
Fixes-
Fuel:
You are either getting too much, or too little. Too much = Carb.
Too little = Carb. Therefore, tear down the Carb (COMPLETELY-Careful!) and clean it up.
Electrical:
Grounding out the System (Kill Switches)
Battery-> Ignition-> Starter.
Magneto->Plug Wire->Plug (Check 'em all!)
May 28, 2009 | Mtd Garden
Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
302 people viewed this question
Top Quad Cycling Experts
shaun taylor
Eric Hidle
Level 1 Expert
Are you a Quad Cycling Expert? Answer questions, earn points and help others
