Hercules mk2 how do i connect my console to a power amp? i dont seem to get any output to my speakers. i have a behringer ep2500 amp and 2 900w speakers. do i need to go through another mixer or pre-amp first?
  • 31 Answers
Whats the type of your console's motherboard ?
Posted on Dec 23, 2007
When I plug-in my vp1220f floor monitors in to the monitor mix on the pmp 2000 i get no sound or little sounds
If you are referring to the "monitor" output , this is a Pre-amp output which connects to a power amp or speakers that have built-in power amps. The Monitor output is a high impedance output. This output will not drive speakers directly.
Jun 02, 2014 | Behringer PMP-2000 Powered Mixer
Accidently had peaker connect to A side while in bridge mode wud mixer be damaged
Hi, When an two channel (stereo) amplifier is connected in bridge mode the polarity of one channel is reversed, for this example say channel B. An identical (mono) signal is applied to both channel inputs.
The output is now connected between the two channel +ve outputs. As channel A's output goes +ve , channel B's output goes -ve, thus doubling the output voltage.
On this Behringer powered mixer, the bridge switch simply connects the power amp section inputs, the required way.
The bridged output is wired to the B output between pins 1+ and 2+ of the 4 pole Speakon connector. (Because usually pins 1+ and 1- are used, stereo operation is unaffected.)
So.... If you connect a speaker from the A output alone then I would expect it to work, BUT if there is already a speaker connected from the bridge output, then what happens will depend on the amplifier design.
At best the A channel will see too smaller impedance, and hopefully shutdown.
This is a Behringer, it has digital (class D) power amps, and it does Not claim any amplifier protection !!!
If the powered mixer works in normal stereo, then it is probably OK.
If it then does Not work in bridge mode it is likely to be the connector wiring.
All the best.
Apr 07, 2014 | Behringer Pmp4000 Europower 1600-watt...
I want to purchase a behringer 15 band graphic equaliser and connect it to a numark 5000fx mixer via skytec pro600 power amp can you help.
The signal path to follow is explained below:
*Audio Source(Cd/LapTop/Ipod)output to,
*Numark 5000FX Input, Then master/main outputs go to,
*Behringer FBQ1502 Inputs, then outputs go to,
*Pro600 Power Amplifier Inputs, then power amp outputs hooked up with a speaker each side.
Hope this helps.
Nov 06, 2013 | Behringer FBQ1502 Ultragraph Pro Dual...
Behringer cx2300
follow this instructions and fix it. God bless you
Instructions
    • 1
      Plug one end of a shielded input cable into the mixer's main output, and the other end into the crossover's input. The cable connectors will be dictated by your particular mixer and crossover, and will be either standard 1/4" or 3-pin XLR connectors. Consult the owner's manual of all components for specific details and recommendations.
    • 2
      Plug another shielded input cable into the crossover "high" frequency output, and the other into the crossover's "low" frequency output.
    • 3
      Plug the cable coming from the crossover "high" output into the channel one input on the stereo power amp, and the cable from the crossover "low" output into the channel two input of the power amplifier.
    • 4
      Plug one end of the unshielded speaker cable into the power amp channel one speaker output, and the other end into the horn tweeter.
    • 5
      Plug one end of the second unshielded speaker cable into the power amp channel two speaker output, and the other end into the woofer. The connections are now complete.
Jul 13, 2013 | Behringer cx2310 super-x pro crossover...
Having problems connecting speakers via a power amp in to my behringer x2222 usb mixing desk - im not getting the ins and outs correct :(
I had a like problem with a crown amp. I found it was in the amp settings , nothing to do with the mixer set up. We had it a mono setting. Take a look at your amp set up book, i'll almost bet thats where the problem is
Dec 06, 2012 | Behringer Xenyx X2222USB USB Audio Mixer
How would i connect a Behringer 1002B Xenyx to a hercules mk4 mixer
The main output jacks of the 1002 are PSUEDO balanced so you can use TS to RCA connections from the 1002 to the MK4. It is not hte best design, but it will work... with two cables go from the 1002 main outs to the stereo ins of the MK4.
Sep 19, 2011 | Behringer XENYX 1002B Mixer
How to connect mixer to a crown power base 2 amp and speakers
just use the main left and right outputs of the behringer to run xlr (3 prong balanced) to 1/4 inch (looks like a big headphone plug) cables into the inputs of the crown amp. the mixer has the xlr outputs and the amp has 1/4 inch inputrs, sop the cables will have to reflect that on both ends. run the outputs of the amp (rca outputs, i believe, you may have to get a rca plug to 1/4 inch jack adapter, and then use a 1/4 inch speaker cable) to the inputs of the speakers, again, the amp has rca outputs and the speakers will likely have 1/4 inputs, so you will have to address that wil an adapter. have each speaker in its own channel.
Nov 22, 2010 | Behringer *new* Behringer X1222 16-input...
How will i connect behringer 202 with hercules mp3 dj e2
how will i connect behringer 202 with hercules mp3 dj e2
Aug 04, 2010 | Behringer (UCA202) Sound Card
Speaker setup for hercules dj console rmx
Just buy any set of computer speakers (or personal portable speakers)
with an external power supply, these are available at any electronics
store such as Best Buy, Circuit city, Target etc. I would buy a two
speaker set that does not have a subwoofer (to remain portable) and is
of a decent quality, expect to pay $30 to $100. These all connect to
the headphone output, which is stereo and are suitably amplified for a
laptop output.
Aug 01, 2009 | Computers & Internet
Computers & Internet Logo
190 people viewed this question
Alun Cox
David Payne
David Payne
