Question about Kenwood KDC-519 CD Player
Problem with face plate.
My faceplate has lost all power to it, and it has no display at all. however the radio still works and plays cd's.
  • 111 Answers
Check the ribbon cable the one connects the face to the main board,ussually that's where the problem is.
You can get it from pacparts.com parts number is J84-0121-12
You need to have some soldering skills to replace it.
Good luck
Posted on Dec 22, 2007
My 9821 Alpine faceplate is scrambled. I cannot read the stations or the time. The radio and stereo play alright. Whats the problem with the faceplate? Ive bought other ones and have the same problem with...
had the same problem with my alpine, i was able to fix it once by, popping off the face plate and with fine grit sand paper (lightly) sand the connection point on the radio and the face plate, then put a little bit of dialectic grease on it. also doing a reset on the unit helped me from time to time...
May 01, 2010 | Alpine CDM-9821 CD Player
Unable to remove faceplate or eject cd on kenwood
remove the to of the unit, then the two in the actual cd player, pull out cd player, there will be two more screws,these hold the faceplate assembly in place, remove them. This will allow you to pull a small plastic hook down to let the face plate slide out. then remove the face plate from it's holder, slide it out. Remove the four screws on the back of the faceplate inside the there is a very small piece of plastic that has a hole at one end and squared at the other. This is the problem causing piece. I suggest super gluing this piece where it attaches to the inside of the faceplate. This should fix the problem.
Jan 17, 2010 | Kenwood KDC-516S CD Player
My Alpine CDA-9835 has a short in face plate, plays music but unable to change tracks, display goes black, and usually have to remove faceplate and re seat over and over till it comes back on usually...
most of the time you have to send the faceplate into the manufacters repair dept or a factory authorized repair center will most likely need the entire radio/ unit to repair the faceplate problems
Good Luck!!!
Larry Dillon
Aug 26, 2009 | Alpine CDA-9835 CD Player
Sometimes fce plate wont come on, but music still plays.
had the same problem with a pioneer i took a qtip and some rubbing alcohol and cleaned the gold colored connecters on the face and radio and worked ever sine.
Mar 01, 2009 | Pioneer DEH-P6600 CD Player
Error Message AO
I had the same issue, my battery was died due to headlight was ON and later player was showing AO. I am going to reset the unit and see if it will solve my problem.
Mar 09, 2008 | Pioneer DEH-1900MP CD Player
Keeps losing power
The faceplate may have a bent pin, or is not fully clicking into place.
Before getting all worked up, try pressing the release button to remove the face plate and carefully inspecting the areas where they click into the main unit, small pieces of debris may be stuck in the clips, if this is not the case, carefully re-insert the face plate, making sure to have aligned the guides before pressing the face plate back into place. You should hear a nice confirming click when the face plate is in place.
Bent pin or contact, can easily be spotted by grabbing a magnifying glass and looking at the allignment of each pin, take extra care when straightening the pin if this is the case.
**Tip**
Most solutions can come from closer inspection ...
ie: with a magnifying glass.
Jan 12, 2008 | Sony CDX-GT100 CD Player
Illumination not working when faceplate is open.
Wire braid out to the faceplate has got a parcially broken wire on it. Sony referes to it as a flexible circuit board. Part can be purchased from sony directly, an on a one to 10 scale to replace about a five.But it does involve taking your radio apart. So if you are handy at electronics. you can look it over. If you have doubts let a professional do it.
Jan 05, 2007 | Sony CDX-M8815X CD Player
Kenwood KDC-519 CD Player Logo
129 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
