Question about Remington Electric Chain Saw
I have Remington REM55PV heater. It starts just fine but when I take finger off ignition button, heater won't stay running.
Remington 35 portable forced air heater parts
Top cover is shorting out the spark plug wire.
Jan 10, 2014 | Heating & Cooling
My 1994 Jeep Grand Cherokee won't start. It turns over but won't ignite or stay running. It was running fine until I filled up with gas and was driving home. I've tried to reset the security system wi
The gas u put I'm the tank was high octain if it was it was making the engine fire to early replace the gas and it should wor properly
Feb 16, 2013 | Cars & Trucks
2000 gmc jimmy starts in AM fine won't start after sitting in sun all day
Can you jumper the fuel pump and make it start and continue to run ?
Have you checked to see if you are getting spark when it won't start ?
Could be a relay or coil, ignition module, or other component.
Aug 08, 2012 | 2000 GMC Jimmy
I have a 2002 yamaha r1 that won t stay running if i hole the starter button down it stays on but if i take my finger off it. the bike will turn off. i changed the plugs,oil,air filter,changed the...
Your starter button does two things . It turns off the head light first then it activates the starter solenoid. This design puts more power to the ignition and starter for easier starting. You will have to check your harness carefully. You may have two wires plugged in the wrong places. This is allowing the ignition to only operate when the starter button bypass is working. If you do not find a loose wire or crossed wires then you may be dealing with a dirty or shorting ignition switch that is not routing the power correctly.
Feb 17, 2011 | Yamaha YZF-R1 Motorcycles
Heater will not stay lite
Sounds as though your heater is a bit different than mune - I havwe no gas supply button, at least I don't think so. I just replaced my nozzle however at the recommedation of a recent contact to this site. It worked. The replacement packaging suggests annual replacement, so I think I was due - after ~12 years!
Jan 31, 2009 | Reddy Heater-30-55,000 BTU Variable
Heater will not stay running
Spark plug or hot surface ignitor?
Nov 18, 2008 | Reddy R60A Utility Heater
Remington Electric Chain Saw  Logo
159 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
