Question about Motorola Mobility RAZR V3i Cellular Phone
How to change motorola v3i keypad - only the silver thing
Kindly suggest , is it possible to change motorola v3i keypad alone
  • 324 Answers
You can change the Motorola keypad for that you need to contact the nearest Motorola service center for that
Posted on Oct 04, 2009
Motorola v3i
plase same lcd not working & mobile off lase help me
Nov 28, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Keypad
you can source one online or take it to another repair store to hvae it fix.
Oct 08, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Changing keypad on Motorola V3i
Motorola V3 Series & Variants
All pictures on this page have been kindly supplied by Munchie.
When dismantling any phone, great care should be taken to ensure that no damage is caused to any of the parts. Rough handling may result in severe damage of many parts, and if proper anti-static procedures are not followed, electrostatic damage may result in any electronic component.
Before commencing, it is recommended that the correct tools are purchased for the job in hand. At the very least, you will require a Torx T5 screwdriver. Do NOT attempt to use a small Allen key or filed down screwdriver, you will only damage the screws.
Step 1. Remove the battery cover.
Step 2. Remove the battery.
Step 3. Remove the SIM card.
Step 4. Remove the two Torx T5 screws shown below and store them safely.
Step 5. Use a thin plastic shim to release the four clips holding the back cover in place.
Step 6. Rotate the rear housing away from the front carefully as shown below. Carefully release the flex connector using your shim or a flat bladed screwdriver.
Step 7. Use tweezers to remove the two aerial grommets.
Step 8. Now use your shim to carefully remove the aerial assembly.
Step 9. The transceiver assembly can be simply lifted away.
Step 10. Remove the four screw caps shown below, and the four Torx T5 screws that they cover.
Step 11. Now use your shim to carefully release the front fascia.
Step 12. Remove the front fascia and the buttons to the side of the handset.
Step 13. Unlock the ZIF connector and remove the camera flex then use tweezers to remove the camera assembly from the chassis.
Step 14. Use your shim or a flat bladed screwdriver to release the display module flex.
Step 15. Now carefully lift one corner of the display module and lift the unit away from the handset.
Jan 07, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola RAZR v3i keypad problem
REMOVE THE MAIN MOTHERBORD AND CLEAN THE BOARD WITH A METHYLYTET SPIRIT USE A HAIRDRYER TO DRY THE PHONE ,ADVISE BY DOGGY
Dec 20, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Keypad problem
ok there might be some dust particle kind of thing would be under the keypad try to blow it out incase this is not the problem u can change the keypad.
Oct 17, 2007 | Motorola Mobility RAZR V3i Cellular Phone
V3i keypad problem
change flex cable(patta). Include keypad in flex cable so change It and enjoy your phone
Sep 23, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Black Screen
You need to replace the flexcable on the phone
Aug 04, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
99 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
