Question about NetGear DGN2000-100NAS Router
My netgear use to work very good, but now it is not working at high performance it is normally working at 54 mbps and my computer is very slow so how can i get my router to work at a high performance
    Guru:
  • 597 Answers
You can unplug the router, wait 2 minutes and plug it back in and let it reboot. Sometimes routers get a little crazy and a reboot should fix that unless it's bad. There is a chance the router could be bad but I'd bet the problem is from your Internet Service Provider (ISP). You should contact them and get their tech support to help you check out your system.
Posted on Oct 04, 2009
  • 32 Answers
You can log into the router config settings by typin http://192.168.1.1/. in the browser address bar.Then insid the config go to wireless settings>>advanced sttings enable the type of mode you require like a/b/g/n.Switch to b or n type for maximum speed.You may also enable turbo 54g mode .
    Sergeant:
  • 191 Answers
Reset it to factory and reconfig.some long not maintenanced routers have tendention to slow down untill they are reset to factory and reconfigured
Netgear N300 is slowing down my internet connection
The router limits the data speed to the wireless reception.
802.11 G speed (maximum) is 54Mbps.
Jul 17, 2013 | NetGear N300 Wireless Router
How do you install a 54 mbps wireless pc card (wg511) Netgear to a desktop computer?
You can use a cardbus/pcmcia to pci adapter card just like this one below:
Nov 03, 2010 | NetGear WG511 54 Mbps Wireless PC Card
54 mbps PCI Adapter Card limits my connection to 2 mbps
Wi if is the slowest form of connection and is shared with other devices. If you want good bandwidth you need to connect via ethernet cable directly to the router.
Examlpe... wi if 4 meg shared, Ethernet 100 meg..
good luck !
Mar 30, 2017 | NetGear WG311 (0060449028409) Wireless...
The Mbps is all over the place jumps from 54 to 11 to 18 to to 36...why is this. and the internet is slow when this is going on.
MBPS will vary with signal strength. You can usually help by placing router and laptop closer together, maximizing signal strength. If speed is jumping around then connection is not too good.
Mar 15, 2010 | NetGear WGR614 Wireless Router
WG111 54 Mbps Wireless USB 2.0 Adapter is not connecting with the third party adsl router when the computer is starting for the first time, why?
That is because your motherboard may have no native support for USB 2.0. Try connecting the adapter to another PC. If this works, then, there is your answer.
Nov 20, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Lost instruction
Lost instruction - NetGear
Nov 05, 2009 | NetGear WGR614 Wireless Router
My Computer is going toooooooo slow !!!!!!!!!!!!
theres a million things that can interfer with wireless...tin...cell phones, cordless phones and the like..but 11mbps is still really fast and chances are, your internet connection isnt even half that so your speed on the net shouldnt be effected...1mbps is usualy enough to load any website in seconds.
if your PC is slow, not jsut on the internet but in general (starting up, running apps) then its an issue with the pc and not the wireless.
but as a heads up, not trying to be mean, but netgear and belkin are cheap equipment.
Apr 26, 2009 | NetGear WGR614 Wireless Router
Netgear WPN824 wireless router
there is no reason why you shouldnt connect at 108 mpbs, so there are only a coulple of things you can try, the first is to change the channel that your router transmits on within the router settings, although this should automatically be done by the router when it comes up against any interference. Secondly try the adapter in a different usb port as USB 2.0 should be used and the port may not be recognised as a high speed port. Double check the router connection transmition speeds is set at 108 mbps; as it would also be able to transmit at a lower speed of 54 mbps so as to be backward compatable with 54 mbps adapters
Jun 30, 2007 | NetGear RangeMax WPN824 Router
Really see 54 Mbps with 54g?
As with any wireless protocol, 54g has overhead associated with it that limits performance. While signaling data rates of up to 54 Mbps may be achieved, like most shared media (e.g. Ethernet) throughput will be significantly less. There are two scenarios for 54g performance. In an environment with only 54g clients, throughput can exceed 24 Mbps. This performance is equivalent to that of 802.11a, although 54g is usually available over a greater range. The second scenario is where 802.11b clients are present. RTS/CTS flow control must be used to allow 802.11b clients to recognize and establish communications with 802.11g access points. This leads to delays in transmission and drops peak throughput to about 10 Mbps. 54g performance is still well in excess of the maximum measured speeds of 4-5 Mbps for 802.11b. The use of RTS/CTS is important because it provides determinism to the wireless network, ensuring a minimum bandwidth for each user. Like Ethernet, 802.11 LANs normally use a ג?œcarrier sense media accessג? mechanism to signal transmission without asking for permission from the network. As the network becomes highly loaded, collisions occur more frequently and the network can become saturated with packet retransmission attempts that eventually make it impossible for any data to get through. RTS/CTS provides a more formalized flow-control mechanism that avoids this problem.
Feb 16, 2006 | Belkin (F5D72304F5D7000) Router
NetGear DGN2000-100NAS Router Logo
220 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
