Question about Kenmore Ovens
How to set oven delay and start time
I can not figure out how to set the delay cook time on my oven.
4 Suggested Answers
  • 1214 Answers
SOURCE: Delay or time bake
You can find the manual at, and the instruction is on page 11.
You make sure the time is set correctly.
You press Bake, and set the temperature you want to bake.
You press Cook Time and enter the amount of time you want the oven to cook.
You press Delayed Start, and enter the clock time that you want the oven to start.
Posted on Jan 30, 2009
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
SOURCE: Oven does not start
This is an update from James758. When I pressed the temp sensor probe and wiggled it a bit, sometimes the oven would work, but then it failed permanently after a few days. Had to call a repairman who charged $325 to replace the entire electronic panel and the separate sensor, although the failed part was only a relay on the board according to him. He also found a pinched wire when he pulled the oven out (one new electronic board relay failed when he first replaced it). Don't know how the wire to the sensor got pinched since the oven worked for 8 years without us moving that hidden wire. By the way, buying the sensor at a parts store in town was $18 versus his cost to us of $49. I'm sure the electronic board would also be much cheaper online. My wife watched the repairman replace the parts; you can save a lot of money doing it yourself.
Posted on Dec 07, 2008
  • 50 Answers
SOURCE: how do i set the delay start option on my oven?
We need the model number to find the right manual. You could try looking it up yourself here:
On the right-hand side of the page, under "Owners Manuals", type in the info. If you don't find it there, then please tell us the model number and we can look some more.
Posted on Mar 16, 2009
0 characters
1 Points
How do i fix the timer for delayed start
Strangely in all of this, u don't tell the oven when to start - it works it out itself!
First u need to set the length of cooking time, eg 2hrs.
Press the cooktime button(2nd one along), THEN use the +/- buttons to set the display to 2.00.
THEN press the readytime button (3rd one), and use the +/- buttons to set the end 1730hrs
The display should then revert to the present time.
THEN turn the oven control to the required temperature.
The oven will switch on at 1530 hrs.
If u were to press the cooktime button ONCE WHILST the oven was on - it will display the cooktime remaining.
AT 1730, the oven will switch off and the alarm will sound
To switch off the alarm, press the minuteminder button - first one - looks like a bell, THEN
REMEMBER to cancel the programme by pressing buttons 2 and 3 TOGETHER, otherwise it will do it again tomorrow!
I would suggest first.trying it when you're at home all the time the oven is on.
Sep 08, 2014 | Belling XOU592 / XOU593 Electric Double...
I want to use top and bottom ovens but at different temps - how do I do this
To Set a Cook T ime:
1. On double oven models only, press UPPER OVEN or LOWER
OVEN for the one you want to set.
2. Press BAKE or CONVECT UPPER (on some models).
Press the number pads to enter a temperature other than the
one displayed.
3. Press COOK TIME.
4. Press the HR and MIN "up" or "down" arrow pads to enter
the length of time to cook.
The start time and stop time countdown will appear on the
oven display.
On double oven models only, when both upper and lower
ovens are being used at the same time, touch UPPER OVEN
or LOWER OVEN to display the respective cook time.
When the stop time is reached, the oven will shut off
automatically and "End" will appear on the oven display.
If enabled, end-of-cycle tones will sound, then reminder
tones will sound every minute.
Repeat the process by choosing the other option of UPPER or LOWER OVEN
Sep 04, 2011 | Whirlpool RBD305PD Electric Double Oven
What does the code 5ab or sab mean my cook top works but not the oven
amana oven reads SAb or 5Ab code? stove works, oven doesnt??? HELP
Aug 21, 2010 | Amana AOCS3040 Electric Single Oven
My oven will not move from SAb o 5A6 and buttons
You have inadvertently entered the Sabbath Mode.
Try holding the clock button for 5 seconds to clear it out.
Dec 12, 2009 | Jenn-Air JJW7530DDS Electric Single Oven
Dacor CPO230, can't get lock to engage for self cleaning. I follow step clean symbolcomes up door lock moves into locked position then beeping starts and the word door flashes and the lock opens up.
For some reason the oven thinks you have a door that is not shut all of the way. Check the locking slot to make sure that there are no obstructions. Make sure that you are only doing one oven at a time, and not trying to cook in the other. Make sure you have no racks in the oven. Try pushing lightly on the door when the lock engages. For some reason your lock isn't engaging fully and that's why door is flashing. Good Luck
Below is from the owners manual for your oven.
Oven does not self-clean Door not shut tight Check for obstructions. Close door tightly
Oven set for delay timed cleaning Oven will start to self-clean at preset time.
Press CANCEL/SECURE to return to
normal operation
Double ovens only: Other oven is on. Turn off other oven.
May 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
I have a turbochef C3 and it works fine. It heats up and stays hot, but i can't figure out how to program it to cook on a timer. The screen says "please wait - warming up - CC494*F IR 855*F" So...
the oven is not really able to cook on the fly,it is pre programmed so the times are set due to weight and mass.try to use the programs already set up and then trial and error will show which 1 to use,hope this helps
May 09, 2009 | TurboChef C3 Single Oven
Instructions for delay cook timer
Here's the link where you can get the owner's manual with instruction's,
Apr 05, 2009 | Maytag CWE4800A Electric Single Oven
Delay or time bake
Jan 30, 2009 | Kenmore 47772/47774/47779 Electric Double...
Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Jun 26, 2008 | Ovens
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
Ovens Logo
94 people viewed this question
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
Michael Thomas
Michael Thomas
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
