Question about Craftsman 25cc Gas Line Trimmer
How do i rewind a new line - Craftsman 25cc Gas Line Trimmer
String on Echo (with the 2 strips ) is stuck and cannot get it out on one side? How do I open the head up?
You mean the trimmer line...?
If so. It's run out. Need to rewind new line in.
Press the two tab on the side of the case and then pull the center out to (refill) new line. you should be good to go back in business like before.
Good luck
Mai
May 11, 2017 | Echo Garden
How do I replace line On an unidentified trimmer or edger?
unscrew bottom and rewind nylon line, take a piece of line to hardware store to get the right size
Jan 03, 2016 | Garden
How to replace pull cord on mtd yard machine cultivator 31cc
-Remove the cord or rope assembly. then rewind the unit and then attach the new rope to. After install the new rope. Try to pulls out to see it will rewind back or not. If not rewind more.
Good luck
Mai
Jun 19, 2014 | Garden
How to load new film
push the rewind button on the bottom of the camera, then turn the rewind knob to the right to rewind any film that may be in the camera. Lift the rewind knob up to open the back door. remove the film canister if there.
on the new film canister pull enough film to reach the take up spool. attach the leader to the spool and close the back door, advance the film to counter number 1. enjoy.
Oct 07, 2009 | Minolta XG-A 35mm SLR Camera
Pull cord came undone
sounds like the spring might have broken. Sometimes they are a pain to rewind. Might want to see about a new pull assembly. But first take off the shroud to see if the little pieces of metal or plastic that engages the assembly on top of the fly wheel are ok. If so untie the cord to the hand hold and remove rope from the pulley inside. Then turn the pulley a couple of times and let it go(but watch your fingers). If it spins pretty fast then turn it again till you get some tension and I put a screwdriver through the fins so it doesn't unwind (but line up the hole where the line goes through first) then put the line through the holes and tie a knot. Then pull out the screwdriver and slowly let the line rewind. If it rewinds reassemble and it should work fine for you.
Let me know if this helped.
Thanks
roundo4
Aug 01, 2009 | Toro Lawn Mower With Toro Power Tools
Replacing line and owners manual
Look at the bottom of the head that you wind and it will tell you the direction to rewind the new line. You can download a copy of the owners manual from www.managemyhome.com
Jun 14, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do I repair a broken pull cord on a yardman push mower?
Easier than you might think. You need a screwdriver along with the sockets to remove the housing over the rewind assembly. Once you have the housing off and access to the assembly, remove the old cord by using it to wind the spring all the way out. Before you take the cord out slip a screwdriver in the slots to keep it from winding back up. If it does, it's not a concern. Just wind the spring back out by turning the rewind until it stops, then turn it back one turn until the holes line up for the cord. Stick the new cord through and tie it off, and let the spring pull the new cord in. If you need any help with it, hit me up.
May 12, 2009 | Garden
How do I wind trimmer line on double spoools for ryobi
Okay, so the good news is that YOU are probably not stupid. If you have a Ryobi trimmer like I do, it might have taken you a while to figure out the "secret" on how to rewind the line. If you only had to learn the lesson once, you are smarter than I am. (I'm leaving myself a note for next time).
If you wind the line the wrong way, you go through line really fast until it clogs up inside the bump head and you are forced to try again. The trimmer has an arrow on the spool for the direction to re-wind the line. Think of it this way, TURN THE SPOOL IN THE DIRECTION OF THE ARROW! Don't do what I did and rewind the line in the direction of the arrow, that would be wrong.
Whether this is a "mistake", a way to sell more trimmers/parts/line, or simply bad tranlation from Japanese to Engrish, it really doesn't matter. You don't need to buy anything with the exception of new line.
Good Ruck,
Mark
Apr 09, 2009 | Garden
Can't find manual for instructions Nikon N55
If you want to rewind manually, you need to press two buttons simultanously. Turn the power on. First, hold "BKT" button just above lens release knob then press the button "+/1" just next to the shutter release. Both button will have red rewind sign next to them. -James
Apr 05, 2009 | Nikon N55 35mm SLR Camera
Film Rewind
check the mechanism inside the film compartment, it may have a broken rewinding gear, if there's nothing broken clean the contact point inside the film compartment, use cotton buds and alcohol or fluid.
Aug 26, 2007 | Canon EOS-30 35mm SLR Camera
Craftsman 25cc Gas Line Trimmer Logo
65 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
