Question about Craftsman Garden
It wont change gears the shifter is stuck - Craftsman Garden
  • 472 Answers
Sounds like the trans may be dry tell me what ya have
Posted on Oct 04, 2009
Can only select 1st neutral an 2nd gear
Hi Meihana and the usual suspects are:
1. Clutch dragging slightly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. Shift lever is loose on the shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
http://pnwriders.com/threads/r1-wont-shift-past-2nd-gear.169723
Can shift above 2nd gear
Wont shift past 2nd gear
Shifting stuck won go past 2nd gear
Apr 06, 2016 | Motorcycles
Why wont 1994 1100 shadow shift out of third gear
Change the gear shifter 2 teeth UP or DOWN.
Otherwise, these models are known for problems with third gear (gear dogs and shifting fork get worn out, hard laser welding is a solution)
Mar 13, 2013 | Honda VT 500 C Shadow Motorcycles
1994 1100 honda shadow is stuck in 3 gear shifter feel stuck
change the outer gear shifter for 1-3 teeth up or down.
Mar 10, 2013 | Honda VT 1100 C Shadow Motorcycles
2003 ford transit turbo manual gearbox, stuck in 2nd gear, cant start
does the clutch push normally or is the linkage broken not disengaging clutch, and then does shifter move around or locked and wont move, loose linkage in shifter or gears are jammed inside transmission and something went, if shifter wont move at all then trans is jammed inside and needs repair.
Jun 09, 2012 | Ford Transit Cars & Trucks
Alternator froze up while driving causing the serpintine belt to brake now transmission wont go into any gear, i havn`t replaced the alt. or belt yet. any idea what happened to the trans? it was working...
You mean the shifter is stuck?, in park?or the shifter goes to each gear but the car wont move? If the shifter is stuck, check all fuses and be sure the brake lights operate.
Sep 07, 2010 | 2003 Kia Rio
Vehicle stuck in park will not change gears. Will start fine
does the gear shifter move? if the gear shifter moves and it wont shift then you have broken linkage, if it wont move you may have ignition linkage problems or the button may not be pushing in all the way, also the brake pedal is tied in too
Jul 01, 2010 | 2006 Chrysler 300
My pt is stuck in the reverse gear an wont come
look on the base of the shifter near the indicator there is a little cover remove it and poke down on it with a screwdriver or anything that will fit then move it out of gear
Feb 12, 2010 | 2001 Chrysler PT Cruiser
4.2l. Why is shifter stuck?
With the car started press on the brake pedal. Listen carefully for a "Click" sound coming from under the gear shift cover. If you do not hear one you will need to test the brake pedal switch, if you hear a click then most likely the lock somehow became disconnected from the solenoid. Remove the shifter cover and the assemble is can be seen for troubleshooting and repair.
Aug 14, 2009 | 2005 Jaguar S-Type
Car stuck in gear
Is it an automatic or standard? If it's standard, check the shifter cable, automatic, I would do a fluid flush, change the tranny filter, and make sure the pan isn't bent. I know someone who had the same problem, they thought they needed a new tranny, but they just needed a new filter (cost a couple bucks at the auto parts store), and then they noticed the pan was bent, which wasn't allowing clearance for the larger gears to be engaged.
Mar 29, 2009 | 1994 Dodge Ram
Garden Logo
113 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
