Question about Acer Aspire™ T180 PC Desktop
I have an upgraded t180 to 6000+duel core chip and want to change the bios tried and it said that it could not because of hardware protection how do i solve this.
  • iancorner13 Oct 04, 2009
    I find that the computer does work well most of the time but now and again it freezes .
  • obwhon May 11, 2010
    Why do you need to change the BIOS. Upgrading the Bios is always a little scary and if the computer is working without issues, I'd leave the BIOS alone. The hardware protection is probably something on the motherboard that is stopping the bios upgrade.
  • 557 Answers
Take care of upgrading bios if somthing go rong you can not restore the old bios settings and you motherbord are not funktion anny more you have to buy a new one
Posted on Oct 04, 2009
I installed the Windows Server 2012 R2 on this machine, and I-m trying to upgrade the bios since at the boot, it says that I need to upgrade to unleash it full power. Nevertheless, when I execute the Bios...
Run the Bios upgrade from a floppy also make sure that you don't have a write protect enabled for the the bios. you could also boot from a hbcd disk and run it from xp mode and put the floppy in a then run the program. good luck./
Mar 27, 2015 | ASUS RS100-X5-PI2 - RS100-X5-PI2 Barebone...
Installed pentium d 940 duel core. Will not boot. need solution
Assuming the new processor is compatible with your MB there are several things to check. Do you have jumpers on your MB to identify different processors? Can you get to the BIOS with the new chip installed. There are several settings in there that could affect your boot process. Lastly, is your BIOS compatible with the new processor?
Feb 20, 2013 | Intel Pentium D 940 32GHz 800MHz 2x2MB...
When looking into setup, dell precision 690 not showing secondary processor
using my noggin i would say bios does not support the processor you are trying to use, and you will have to change the bios.
link below has useful info bios chip compatibility and so on.
http://www.tomshardware.com/forum/261984-28-upgrade-dell-precision
Sep 17, 2012 | Dell Precision Workstation 690 -1KW Dual...
Greetings. I currently own this board with an AM2 dual/core processor installed. I was just wondering, if I were to upgrade, would this board support the newer AM2+ and AM3 chips, and if so, would a BIOS...
It looks like it will accept certain chips. Check this site and purchase one of the ones listed. As for the BIOS upgrade, the site also lists "since BIOS version xx", so just check your bios version (you should be able to hit pause/break key during the bios boot and see the version on that screen, instructions here), and if it's not xx or greater, go ahead and grab a bios update by clicking the "go" arrow on the CPU listing, it will take you to a download for the most recent bios. BIOS flashing is pretty dangerous, if you need help with that you can search online and find a bunch of tutorials, or just comment back and I can try to walk you through it.
Tj
Jul 19, 2011 | ASUS M3N72-D Motherboard
I want to upgrade my current processor (Pentium 4 531 3.0Ghz Prescott with Hyper-Threading) from my ASRock ConRoe865GV motherboard to Core 2 Duo E4xxx series or Pentium dual core E2xxx series. But I want...
hello velayojoel
my name is ausi.
if the asrock web site says 2gig is the max then that is it. the only other thing to check on their web site is the bios version. see what version is your bios and if a bios upgrade can help. otherwise the only thing to do is to replace the board if you want higher processor speed.
hope this has helped somehow.
good luck
Feb 01, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I have also the same problem and after firmware upgrade i found that my drive does not detected by my pc's bios setup. is there any solution for backup the process or repair the drive.I edited the...
did u upgrade ur BIOS firmware ?
if so it's gone corrupt...if u have the backup of the original firmware...then FLASH the BIOS with that...else u may have to change the BIOS chipset....but that may be a tricky issue as the chip is fixed in the motherboard....
Cardinal Rule 1
NEVER UPGRADE / NEVER MAKE ANY CHANGES TO UR FIRMWARE ON ANY HARDWARE.....THE HARDWARES ARE MFG TO AND FIRMWARES ARE INSTALLED TO WORK THE WAY THEY ARE MADE...99.99% of the people who made changes to the firmware on any of their hardwares....have always faced issues later with the hardware...
Rule 2,
Always take a backup of the original Firmware if u can else dont venture into this complicated issue...
Dec 20, 2009 | LG (gce-8525bb) CD-RW Burner
Want to upgrade my proccesor
OMG!! doogie812, quit giving people bad advice. From what you have suggested, you know nothing about computer hardware. You can upgrade the processor in this system and it will not effect the OS one bit, except make it process the data a little quicker. With this system, if you had done any research at all, it only comes with 1GB of memory, you should of suggested to this person to add more memory.
Jan 11, 2009 | Acer Aspire AM1640-U1401A Desktop PC
Upgrade from Pentium 3 to Pentium 4
what socket is the Pentium 3? Socket A. The sockets have to be compatible for example you can't upgrade a Dual Core for a Core 2 Duo because although the chipsets look the same the motherboard may not support the new instruction set. I had this problem recently as i wanted to upgrade my Intel Celeron D 3.02ghz to the Pentium Dual Core 1.8ghz and although the chips were identical and fitted perfectly in my mobo, the actual mobo i was using (foxconn) wouldnt work with it forcing me to buy an ASRock mobo and replace the entire system.
May 27, 2008 | Dell 2.8 GHz Second Processor for...
Compatibility
A8V-MXs are built for AMD processors. You will need a board made for Intel processors if you want to purchase the above processor. If you want to stick with Intel and Asus check out the P5 series of boards. If not, buy an AMD chip...I've had AMD in almost every one of my computers, laptops and desktops.
Good luck.
Dec 20, 2007 | ASUS A8V-MX Motherboard
HD Audio Hardware Problem
just try to go in the bios and load default setting ,,,if issue persist then update the bios
Aug 12, 2007 | Intel D945GNT Motherboard
Acer Aspire™ T180 PC Desktop Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
