I removed the used-up batteries and replaced with new ones. I tried to re-conect using the standard procedure mentioned at the back of the keyboard. It worked earlier, but this time it simply wouldn't budge. The mouse is working fine.It connects and disconnects using the same procedure. The green LED continues to blink even after pressing the "connect" button on the transmitter stand followed by another "connect" button at the back of the key board.
Battery replacement and conection using the connection procedure worked earlier. This time the keyboard didn't respond. What could be the problem ? Keed a soultion for this.
Comments:
Dec 24, 2007
- No this option was tried. Unplugging from the USB port didn't work. Operating platform is Windows XP. There is one more option which I'm yet to try. Hitting "Backspace" at the time of booting the PC. Maybe that can get the wireless connectivity through.
-   my mx3200 key board is not connecting and when it does teh mouse doesnt connect -   Guest
Aug 31, 2008
-   My batteries went dead in my keyboard. After I switched out the old batteries the keyboard would not connect. Also the mouse stopped responding. I tried unplugging then plugging in the connections, restarting the pc but, I can not get the keyboard and mouse to work again. how can I fix this problem.-   adamsmd
Jun 08, 2008
-   Same problem here, but I'm running vista 32-bit.
-   Guest
I have wireless Gateway Keyboard Model#: KR-0401 and mouse and am getting intermittant connection....
(More)
I have wireless Gateway Keyboard Model#: KR-0401 and mouse and am getting intermittant connection. What can I do??
I have a Logitech Cordless Wave/mouse bundle. I'm using Logitech softwate v 2.7.0 and Mac OS 10.5.7....
(More)
I have a Logitech Cordless Wave/mouse bundle. I'm using Logitech softwate v 2.7.0 and Mac OS 10.5.7. In the system preferences, I have selected Keyboard layout = mac, however, the keyboard still functions as a pc keyboard. I also cannot configure the mouse.
My key board stop working, after replacing the battery and reset the key board, now it's asking for...
(More)
My key board stop working, after replacing the battery and reset the key board, now it's asking for a code. There isn't any way to enter that code when the key board is not responding
I've had this keyboard for over a year. After a few months it started malfunctioning. When I press a...
(More)
I've had this keyboard for over a year. After a few months it started malfunctioning. When I press a key, it will continuously type the same letter/number/symbol over and over again. The only way to make it stop is to turn it off and reconnect it, but half the time THAT doesn't work either. This has resulted in the loss of a lot of work, because the backspace button is the worst culprit. It erases everything I've typed, and continues to backspace, so i can't type anything without it getting messed up. I've been using the on-screen keyboard for everything, which obviously takes a long time. I've tried everything I can think of, the batteries are new, and no matter what it's still going crazy. Is it fixable, or should i just chuck it out the window and buy a new one?
I reccently purchased a keyboard model MX 3200 but i am having trouble getting it to work propperly....
(More)
I reccently purchased a keyboard model MX 3200 but i am having trouble getting it to work propperly. The keys are not responding when they are pressed. I know that the keyboard is connected because the scroll bar on the left side of the keyboard functions perfectly. I have tried installing the keyboard on different machines and the problem persists. What can I do so the keys will function propperly?
