Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Re/Kenmore fridge (Model #59676519500): Icemaker making ice, but apparently leaking. Water drips (from somewhere) onto the side of the ice bin and top sliding drawer, freezes and you can't pull the drawer out, much less the ice bin. What can I try before purchasing a $10,000 part? Thanks
  • 1122 Answers
SOURCE: Something is wrong with my icemaker
check supply tube behind ice maker,make sure it is lined up to feed icemaker,also you can pull it out look inside to make sure it;s not frozen inside tube or frig. wall,thanks-mike
Posted on May 28, 2008
ginko
  • 19396 Answers
SOURCE: Kitchenaid Icemaker leaking in big drips on front of freezer bins
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
Maytag317
  • 1136 Answers
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
Posted on May 30, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
Maytag317
  • 1136 Answers
SOURCE: Water is dripping from the freezer into the refrigerator
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Posted on Jul 11, 2009
My Kenmore ice and water in the door refrigerator has the ice in the storage bin freezing into big clumps of cubes and the dispenser forces the bin out of position. It acts like the icemaker is getti
There may be ice forming in the water chute causing water to spill out of the chute and pour onto the ice in the bucket. Sometimes the water valve has a slow drip or is slow to shut off. the valve may need replacing. I doubt it is the icemaker but it could be.
Oct 04, 2014 | Refrigerators
An ice cube gets stuck in the icemaker as it empties.
The ice making unit needs to be cleaned with a mild acid such as citric acide like commercially available Ice Machine Cleaner. minerals have built up and make the ice stick to where they will not harvest properly.
Jun 03, 2010 | Whirlpool ED2FHEXN Side by Side...
Water leaking along back interior to bottom under & over veggie bins
Sounds like the drain to the drip pan is clogged -- maybe with ice.
Defrost water runs down to a drain in the bottom of the fridge and into a pan underneath where it evaporates.
Sounds like the defrost water is not reaching its final destination.
Here's the way the same problem was solved earlier today:
For those who have this problem with this model: The drip pan is in an open space on the back side of the refrigerator. There is a rubber spout that empties into it. But to clear clogs...you must take out the shelves from the freezer, unscrew and remove the back panel on the inside of the freezer. There you will see the water exit. Boiling water cleared it out.
May 29, 2009 | GE Refrigerators
Whirlpool ET1CHMXK09 top freezer with icemaker: Has leaked almost daily. At installation, Lowe's employees had trouble with gasket provided in the icemaker installation kit and had to get something else...
I decided maybe we were fixated on the ice maker because it's the obvious culprit/source of water input. However, thought more broadly and then fixated on the frost-free aspect and the drip pan. In case ice was building up and defrosting within the refrigerator back, even though the pan was bone dry, I removed 1/3 of the freezer contents to another freezer to maximize air circulation in the freezer compartment. At the 24-hr mark, after this change, there was an approximate 2 tablespoon drip downstairs so I don't consider the problem fixed necessarily. The next 24-hour period is late this afternoon. However, I still empty the ice cube bin so it will never stop making ice in case it is the pressure of the water in the line which, when no ice is made because the bin is full, it leaks where the line comes into the back of the fridge, but out of sight, until it pools on the floor enough to run through to the floor below, downstairs.
Thank you for contacting me. I'm telling others about your site.
May 04, 2009 | Refrigerators
Water leaking inside of refrigerator from freezer
IT SEEMS LIKE YOU HAVE A CLOGGED DRAIN . CHECK YOUR CONDECER COILS BEHIND KICK PLATE .. AFTER THAT YOU CAN UNPLUG FRIDGE FOR 24 HRS WITH DOORS OPEN AND SOULD DEFROST ENOUGH TO CLEAR DRAIN . IF NOT . DEPENDING ON MODEL YOU SOULD BE ABLE TO GET THROUGH DRAIN THROUGH MOST FREEZERS .
Feb 03, 2009 | Kenmore Refrigerators
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator leaking water
There is normally a small shutoff valve installed in the water line servicing the ice maker; you might shut off the flow of water until you locate the problem.
Most drip pans can be slid out but it would be wise to lower the level with sponges or similar to avoid any more spillage than you already have.
If the 'knob' is centered it is probably the release knob for the grill, behind which is of course the drip pan.
Before damning the ice maker (although they are among the most unreliable devices known to man), I would pull the fridge out and examine the fitting where the water line is attached.
Any lime buildup or green corrosion around the fitting would imply that the leak is external to the cabinet and the leaked water is only accidentally making it to the drip pan.
If you haven't been getting blocks of ice in the cube storage bin, the shutoff valve is apparently working so you may get lucky locating the source of the leak.
Jul 07, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Refrigerator is making a loid noise
** the y do sound directly related. water is dripping down your ice maker falling on to bucket? well a small amount of water is also falling onto the evaporator fan assy, freezing and the **ise you hear is that fan blade "cutting" through the ice.you can lift the arm turning the Ice maker to the off position, itll stop calling for water,and your **ise should stop as well
Mar 10, 2008 | Refrigerators
Icemaker - Plastic
If the pieces of plastic are smaller than the inner diameter of the water tube then you should be looking at the filter washers on the tap and where the water line fits onto the valve assembly behind the fridge. If the filters are clear, the problem is within the ice dispenser. Remove the ice bin and inspect the shroud where the motor coupling pushes onto the auger behind the bin. The auger could be off centre and chaffing the plastic away. Otherwise, check the ice maker fingers for damage.
Sep 15, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
