Question about Garden
I have a John Deere GX255 Garden Tractor with a 20 HP Kawasaki engine. The engine sputters like it is running out of gas but never dies. I have changed the fuel and air filters and replaced the gas but it makes no difference. Also, how often should the valves be adjusted and how do you adjust them. The engine has 180 hours on it.
  • 472 Answers
Its over due for a valve adjustment its not to hard try cleaning your carb out if that dont fix it let me know and ill tell you how to do the valves
Posted on Oct 04, 2009
Jd gx345 20 hp kawasaki water cooled. turns over will not start Both coils have juice to bath termals at the same time with the key on or off.
Drain fuel completely from tank, fuel line, and carburetor... Change fuel filter, change spark plug(s) add FRESH gas... Not 1 week, month or year old gas... (Can't be contaminated, or mixed with old fuel) there will be a drain screw on the carburetor (at the side of the bowl) You may need some quick start to get the engine to initially start up and keep it running with the spray until the fuel system fills up with fresh fuel and stays started.
Sep 16, 2013 | John Deere 420,1020,2010,2020,2510,2520...
John deere gx255 shuts down when brake released.
For sure the seat switch is the likely problem. The logic is if the brake is set the engine will start and run. If the brake is released and no driver in seat a saftey situation is possible and the engine turns off. Check seat switch, Bi pass to troubleshoot.
Hope this helps?
Jun 28, 2017 | Garden
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
A,b,g Tractor Carburetor Float Dltx10: i had my john deere riding mower running then shut...
My John Deere only starts with a hammer. I have the Kawasaki engine and it is famous for bad starters, so I carry a hammer and tap on the bolt when I want to start it. So, you either have a bad solenoid in your starter, or the contacts are dirty, battery connections are dirty. Or the battery is dieing. Check it out. Hope this helps.
May 07, 2010 | John Deere A,b,g Tractor Carburetor Float...
I have a John Deere GX 255 Garden Tractor with a 20 horse power Kawasaki Engine. The engine will sputter under load like it is running out of gas. I have changed the fuel filter and air filter and replaced...
You most likely have a gummed up carbeurator. Go to any auto parts store and get a bottle of a product called SeaFoam which is a fuel additive. Follow the directions on the bottle and it will most likely clear up your problem in just a few minutes of operation.
Oct 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My John Deere 345 dies for no apparent reason
You have dirt in the fuel tank and it sucks the dirt up on the filter that is attached to the pump. After the machine stalls, the dirt falls off and it will restart and run for a few min.
Oct 02, 2009 | Garden
Older model john deere garden tractor model 160
Remove the flywheel and physically look at the key
Sep 14, 2009 | Garden
20 Hp (kawasaki) John Deere GX255 tractor over revs when cold.
the engine is icing up. Kawasaki may have a winter kit available. I have solved the problem it the past on other engines by partial blocking the air intake screen with cardboard. Cut a piece of heavy card board the same size as the intake screen cut a few pizza slice shapes out and zip tie it to screen. remove in the spring. refer to owners manual if you are unsure what the air intake screen is.
Dec 18, 2008 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
696 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
