Question about Apple iMac G4 Desktop
When i power on all i get is a flashing folder
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Apple Master
  • 1,099 Answers
It sounds like the system is corrupted. What I would do is get your instal disk boot up holding down the c key on your keyboard. Once you have booted up go to the file menu and run disk utility to verify and repair the hard drive. Then go to the instal menu and instal a fresh system remembering to preserve the users data so you do not wipe anything. Hopefully this will work
Posted on Oct 13, 2009
How to reset Sylvania notebook synet07526
Download your version of CE for smartbooks at http://netbook.poodwaddle.com/ unzip to to blank FAT32 formatted SD card: in root (dont put in folder, just put it on card) unzip CE package and copy script folder contents to root (no folder) so when device looks at SD card, it sees contents of script folder first. Use power supply when flashing. insert card, then power on. You should see device reading and updating itself.
Jan 03, 2015 | Sylvania Computers & Internet
I Keep Receiving Error 80029C77 When I Try The Latest Update For MyPS3
I received this today and first I downloaded the update via the web on your computer to a USB flash drive. Once downloaded create the folders PS3 and the folder UPDATE within PS3. PS3\UPDATE. Move downloaded file into the UPDATE folder. (folders must be in CAPS). Then when the unit is off press and hold the power button until it beeps 3 times. A menu should come up on the screen. Select the option that states update system software (I believe its 6). The unit will update via the flash drive. After that the unit will restart and should be updated and working.
Jul 27, 2010 | Sony Playstation 3 (PS3) Console
MY ACER ASPIRE ONE ZG5 DOES NOT BOOT UP. THE GREEN LIGHT ON THE POWER BUTTON IS ON. IT WAS FINE AND AFTER AN AUTOMATED UPDATE IT STOPPED
The BIOS most likely needs to be flashed and can only be performed with a flash drive. Follow the guide below to properly format a flash drive and flash the BIOS file on the Acer one....takes about 10-15 minutes total.
Acer One Black Screen of Death Repair…..
In most cases the black screen of death for the Acer One is due to a bad update or corrupt BIOS. In 90% of the cases, this black screen can be cured by flashing the BIOS of the Acer One.
The first thing you will need besides the netbook is a flash drive, preferably a 1 GB version so you have plenty of room. Make sure it a flash drive and not a reader or mp3 player.
Go to the Acer support site and go to service and support and go to the drivers download section. Navigate to the exact model of your Acer One, it will be labeled on the bottom of the case. It will be something like AOA150 etc….
Once you choose the model, choose BIOS and download the latest that is listed. Save it to a folder on the desktop so you can find it later. Now find the file and unzip it to that folder. When the files are unzipped they will all be listed.
Now go to “My Computer” in the control panel and find the flash drive listed. Right click on the flash drive and scroll down to “Format”. Choose “FAT” as the format….not fat32 and not ntfs. Run the format, hit apply and accept and the flash drive will be formatted to the “FAT” file system, this will allow it to boot your computer and flash the new BIOS.
Now go to the folder that has the unzipped BIOS files. Now find the folder named…. “Dos_Flash…open this folder and you will find the file that has the version number of the BIOS files needed to flash the BIOS. Right click on this file and scroll down to “Rename”, choose rename. You have to change this file name to the following…..zg5ia32.fd
Now, copy this renamed file to the flash drive that you previously formatted and also copy the file, Flashit.exe to the drive as well. This file is in the same folder as the one you previously renamed.
Now make sure the netbook is off and is fully charged. Now connect the flash drive to any of the available USB slots. Now, press the “Fn” key and hold it as well as the “Escape” key and hold it. Hold these two down together and do not let go of them. While you are holding these two keys down, press the power button and hold it down until you see the green power indicator light comes on and starts blinking…once this happens, let go of the other buttons and observe the indicator light on the flash drive. It should also start blinking indicating files being read on the flash drive. Now, just wait up to 1-10 minutes for the BIOS to be written and flashed. If it all goes well…..the system should boot up without incident and without any data loss.
Apr 17, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One Notebook ZG5
Try this guide for flashing the BIOS which is a common cause for this problem. You will need a flash drive and the bios files from Acer support downloads, takes about 10-15 minutes total for this repair.
Apr 15, 2010 | Acer Aspire One PC Notebook
Acer Loading problem
Your BIOS may need to be flashed.....follow the guideline below and good luck.....
Try this fix….all you need is a flash drive, the BIOS files from Acer support Downloads and 10 minutes of your time.
Feb 14, 2010 | Acer Aspire One PC Notebook
SCREEN BLANK POWER BUTTON ON
Oct 18, 2009 | Acer Aspire One PC Notebook
I have Acer Aspire One A150 laptop & once i on the power its keep black screen and no HDD activity led flashing, what's actualy problem?is it my board faulty or what?
Oct 14, 2009 | Acer Aspire One A150-1006 Notebook
I want to download pictures from my computer to a flash drive.
Open [My Computer]
You will see the flash drive, probably "Removeable Disk" and probably labeled Drive E
Click on the flash drive icon and the main folder on the flash drive will appear.
Create a folder (right-click, [New] [Folder]) and name it something like "photos"
Find the pictures on your computer and copy (drag & drop) them onto the folder on the flash drive.
No, you don't have to make a folder on the flash drive, just a suggestion.
Oct 01, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
At power on, screen begins to cycle through different colors,
Aug 25, 2009 | Acer Aspire One AOA150-1504 Netbook
How do i transfer photos from my hp photosmart m537 camera to sandisk cruzer micro usb 2.0 flash drive 2gb.
Connect the HP camera to your windows pc using the usb cable provided. Open My Computer to ensure that the camera is being properly enumerated (given a hard disk letter). make note of the drive letter assigned.
If you have more than one USB port, insert your cruzer micro 2.0 stick into another USB port. Look in my computer again to determine what drive letter was assigned to the flash stick. Open a windows explorer window for each of the locations. One for the camera, the other for the flash stick. Its likely that the picture files are in a subfolder of a folder called DCIM.
Once you locate the files you want to transfer, you can highlight them using the mouse (click/drag a box around the files you want) and drag them to the other open window (flash stick folder)
If you don't have another available USB slot on the compter, you'll need to copy the files from the camera to a temporary location on your computer and then move them to the flash drive. In this case, make a new folder on the desktop and name it temporaryfiles. open that folder. open the drive letter assigned to the camera and copy whatever files you want from the camera to 'temporaryfiles'...
Then power off the camera and remove the usb cord from the computer. attach the flash disk to the newly free'd up usb port and open a windows explorer window to it. drag whatever files you want from 'temporaryfiles' folder into the folder for the flash stick.
I hope this helps!
-Ray
Mar 02, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Apple iMac G4 Desktop Logo
93 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
