Question about Kenwood KDC-W7537U CD Player
KDC-W7537U model number Code for bluetooth
What is the default code to connect your mobile phone to the car via bluetooth?
I was able to connect my phone to the car via bluetooth in the past but now i cannot connect it.
What can i do?
    Sniper:
  • 69 Answers
Most of the default codes are 1234, 0000, 1111 unless changed by the user. if this doesn't work, you can always do a hard rest of your radio by pressing the small pin hole button on the face of the radio.
hope this helps
Posted on Oct 05, 2009
How/where do I enter pairing code?
When you want a bluetooth device to connect to your computer's bluetooth receiver, you have to set up the 'password' (which you decide) on both your PC/laptop AND your external device (e.g. BT enabled mobile phone). Generally on the PC/laptop this will be via the drop down menus got by right clicking the BT symbol on your desktop and selecting 'properties' (or via the start menu listing for BT device etc). Then for example your mobile phone's BT menu, via its settings. Do this for each external device. Sometimes devices come with a preset passkey/pairing code which can be a default of 0000. Consult device documents. If the device has no preset then set it up to be the same as the one you set for your PC BT receiver. Test the link by sending (TX) a file to the external device & vice versa (receiving device must be set to receive FIRST)
Dec 15, 2014 | VIA Computers & Internet
Tip
How can I reset a Bluetooth?
<p>Using a Bluetooth device for mobile phone or computer, it asks for a PIN or security code. The connection between two Bluetooth devices is based on this code. If you're not interested in connecting both devices in the future, you need the code again. On reset the Bluetooth devices to remove the existing code and will prompt you to enter in case you decide to return to be switched. <br /> <p><br /> <p>1. Go to the menu on your mobile phone. Find the connection options and select the "Bluetooth" option. In the Bluetooth menu, you can see the devices currently associated with the phone. <br /> <p><br /> <p>2. Use the arrow keys of the phone to disconnect the device you want to select. You will see a number of options from the context menu. Choose "Remove / Reset PIN." This will switch back to the default security code, usually '0000 '. <br /> <p><br /> <p>3. Disconnect the connection of Bluetooth devices; simply select the 'Delete' / 'Remove' option on your mobile phone. When you pair the devices in the future you will be writing a new code. <br />
on Jun 26, 2011 | Cell Phones
I have a bluetooth plug-in handsfree car kit model#bthf0082 it asks for 4 digit pin on mobile when i try to connect device?
HI, TRY CODE 8888 ON YOUR MOBILE PHONE TO CONNECT THIS BLUETOOTH DEVICE BTHF0082. HABIB
Mar 09, 2011 | Cell Phones
What is the bluetooth passkey code for lg gt505 mobile phone to pair with other devices
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Jul 02, 2010 | LG GT505 Cell Phone
Problem in transfering file via bluetooth
Take care.
Jun 17, 2010 | Sony Ericsson K750
Cant get car kit to pair with my mobile asking for code
the bluetooth default code is often a 4 digit number 0000 or 1234 if that does not work - post back the exact make and models of the phone and earpiece and I will try and find the user manual where it may mention the default code used
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | Motorola Mobility Bluetooth Hands Free...
Car battery was disconnected now CD player doesn't work
Try disconnecting the power again for a minute and try again.
Jan 13, 2010 | Kenwood KDC-W7537U CD Player
Security code Kenwood KDC 3028
svp je veux le code kenwood kdc-w7537u
Apr 04, 2008 | Kenwood KDC-3028 CD Player
Connect to the internet via
Once the Socketcom Bluetooth card is inserted in the Toshiba Pocket e570 PC and the software has been loaded, the following instructions will set up the Toshiba PDA & Ericsson T39 mobile phone to connect to the Internet. Click on the Bluetooth icon in the bottom right hand corner. Click on Get Connected! Select the device under My Bluetooth phone is: In this case the Ericsson T39. The following information gives details on how to change the name of the Mobile device. Once this has been read, click on Next. The phone now has to be made discoverable so that the PDA will detect it. To do this, use the down arrow on the phone to select Extras and then click on Yes. Scroll down to Bluetooth and Click on Yes. Select Make Discoverable and a message on the phone will appear saying that the phone is discoverable for the next 3 minutes. Click on Next on the PDA. The PDA will now look for a Bluetooth device(s). Once the mobile is detected the PDA will search for the Device Name of the mobile. Click on Select and the devices will not connect and create a partnership. The following Device Bonding window should appear to create a bond between the PDA and phone. Click on Next. To create the bond a passkey must be entered on the PDA. This may be a between a 4-16 digit code. N.B. We would advise that the code be kept to a numeric sequence as the keys contain more than one letter on them, i.e. for the letter L, the number 5 key will need to be depressed 3 times. Once the passkey is entered, click on the Reply button. On the mobile, click on Yes to accept the incoming pass and then enter the same passkey. Click on Yes again to confirm. If the two values are correct, a message will appear on the phone telling you that the devices are bonded. The PDA should now congratulate you on your connection. For Internet access via Bluetooth, please follow the steps outlined below. The above instructions only need to be carried out each time a connection is required. However, the instructions below only need to be setup once. Click on Start, then Settings from the drop down menu. Click on the Connections tab at the bottom of the screen followed by the Connections icon utility. In the first drop box labelled "When needed automatically connect to The Internet using these settings" select New. Under the General tab you will be prompted to give the new connection a name, e.g. Bluetooth. Select the modem "Bluetooth Phone" and click on Next Make sure that the fields for the boxes titled Country code and Area code, are empty. The next field requires the full telephone number, including STD code, you wish to dial, i.e. your ISP telephone number. Put this in and click on Next. The next page contains a time out clause if the PDA is unable to connect within a set time. By default this should be 120 seconds. Make sure the tick box for "Wait befo
Sep 07, 2005 | Toshiba e570
Kenwood KDC-W7537U CD Player Logo
240 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
