Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
How do you loosen bolt #33 or part #532 17 83 42
  • 389 Answers
Get a small block of wood such as a 2 x4 and put it inside your deck for the blade to catch on and hold from turning. Take a socket and long ratchet or breaker bar and loosen the nut until it comes off
Posted on Oct 04, 2009
How do you loosen a power steering tensioner on a 86 Chevy caprice?
I've got an 85 2.5 celebrity and am assuming that your 86 is similar. Most people might think this is a incorrect question, but I've spend hours trying to locate all the bolts to loosen. The alternator belt is straightforward. Loosen the alternator bolt in located in the slider portion and the pivot bolt (15mm on mine). The compressor belt is straightforward. Loosen the two compressor adjustment bolts in the slider slot and the loosen the pivot bolt. This belt will be hard to remove even with the compressor fully pushed down. Take some vitamins. The worse belt by far is the power steering belt. Loosen the pivot bolt on the bottom of the power steering "canister". There are two adjustment bolts to loosen from my memory. The one that is easy to find is on the engine side of the power steering canister. The other is hard to see but is located on the pulley side between two of the pulleys. It's also hard to get a wrench on. But, you've got to find and loosen this bolt. I cringe when this belt breaks. Good Luck!!
Jul 10, 2015 | Cars & Trucks
Is there a trick to loosening the power steering pump pulley to remove the belt? Thanks!
Loosen the pivot bolt. Most have an adjusting bolt and a pivot bolt where the PS pump can move back and forth a bit.
May 01, 2014 | 1999 Nissan Sentra
What do i do to get new belt on
FOR THE 3.0L ENGINE IF YOU REPLACE AC BELT LOOSEN TOP IDLER PULLEY CENTER BOLT. IF YOU REPLACING ALTERNATOR AND WATER PUMP BELT LOOSEN ALTERNATOR ADJUSTMENT BOLT AND PIVOT BOLT.IF REPLACING POWER STEERING PUMP BELT LOOSEN POWER STEERING PUMP ADJUSTMENT BOLT AND MOUNTING BOLTS.****** FOR THE 2.4L ENGINE TO REMOVE POWER STEERING BELT LOOSEN TOP IDLER PULLEY.FOR ALTERNATOR AND WATER PUMP BELT LOOSEN ALTERNATOR ADJUSTER BOLT, PIVOT AND MOUNTING BOLTS.FOR AC COMPRESSOR LOOSEN LOWER IDLER PULLEY.
Oct 07, 2010 | 1996 Nissan Pickup
Im trying to replace my water pump. i need to remove the pully first but its still turning even with the belt connected when i try to loosen the bolts
here is the trick. Use a long screwdriver to pry between 2 of the bolts to hold the pulley while you loosen another bolt with a box-end wrench. Only loosen the bolt--do not remove it, so that it can be used as leverage to loosen the rest of the bolts. Do this for each bolt until they are all loose. OK?
Oct 06, 2010 | 2002 Saturn Sl
How do you change alternator belt on 1997 mazada 626
heres a diagram to help you, loosen the bottom bolt a few turns then loosen the top bolt then loosen adjusting bolt to loosen belt, use the adjuster to tighten the new belt then tighten top and bottom bolts, hope this helps,8a841eb.gif
Oct 04, 2010 | 1997 Mazda 626
How do replace the alternator belt on a kia 2002 sportage
There is a log bolt that needs to be loosened,but the bolt on the back ,top of the alternator has to be loosened first,then turn the long adjusting bolt counter clock wise,to loosen the alternator to get the belt off,after loosening the long bolt you can pull on the belt itself,and this will pull the alternator towards the engine,then you can remove the bolt.
Apr 17, 2010 | 2002 Kia Sportage
WHAT BOLTS DO I LOOSEN TO GET FAN BELT ON 1992 JEEP CHEROKEE 6 CYLINDER. I HAVE THE BELT ON PRPERLY AROUND THE 1ST 5 PULLEYS. BUT THE UPPER RIGHT PULLEY HAS TO BE LOOSENED IN SOME WAY TO GET BELT ON. HOW...
the power steering pump has a seperate adjuster bolt ont the bottom left of the pump if you loosen this off then loosen the pulley bolt it iwill move in to allow for the belt then tighten the adjuster bolt till the tension on the belt only allows for a 1/2 inch movement up or down then tighten pulley bolt
not the pump may be stiff to move at first
Feb 08, 2010 | 1992 Jeep Cherokee Sport
How do you change an alternator belt on a 2001 mazda protege
1.6L (Zm) Engine Refer to the illustration for component location.
  1. Loosen mounting bolts A, B and C.
  2. Loosen the adjusting bolt D and remove the belt.
To install:
  1. Installation is the reverse of removal.
  2. Tighten mounting bolts A, B and C.
Location of the alternator mounting bolts and adjuster bolt D–Protégé 1.6L (ZM) engine
2.0L (Fs) Engine Refer to the illustration for component location.
  1. Loosen mounting bolt A and B.
  2. Loosen the adjusting bolt C and remove the belt.
To install:
  2. Adjust the belt deflection or tension by turning the adjusting bolt C.
  3. Tighten mounting bolt A and B.
Alternator belt tension adjuster bolt (C)–Protégé 2.0 L (FS) engine
Nov 01, 2009 | 2001 Mazda Protege
2001 kia sportage need to get info on how to change the timing belt, 2.0 motor forward facing motor, needs power steering replaced, timing belt.
Below are the steps..
Disconnect the negative battery cable. Remove the two fresh air duct mounting bolts on the radiator. Loosen the fresh air duct clamp at the intake housing. Remove the hose at the resonance chamber. Remove the frech air duct. 2bea4d1.jpg Remove the five cooling fan shroud bolts. ab00c68.jpg Remove the four thermo-modulated fan nuts. Remove the four thermo-modulated fan cooling fan shroud at the same time. 289c5ca.jpg Loosen the two generator mounting bolts(A and B). 2a96c03.jpg Loosen the generator drive belt from the generator by loosening the adjusting bolt(C). Remove the generator drive belt. Remove the fan pulley. Remove the four splash guard mounting bolts and splash guard. f912ce0.jpg Loosen the A/C idler puller nut(A). c0690b5.jpg Remove the A/C drive belt by loosening the adjusting bolt. Loosen the power steering pump lock bolt and mounting bolt. 843d3b3.jpg Remove the power steering belt. Remove five bolts and the upper timing belt cover. Refer to Timing Belt. Remove two bolts and the lower timing cover. Refer to Timing Belt. Loosen the tensioner lock bolt and pivot the tensionder pulley outward to remove the tension from the timing belt, then re-tighten the tensioner lock bolt. 7ca4ca0.jpg NOTE: Tightening Torque : 27-38ft·lbs(37-52N·m) Mark the timing belt rotation for proper reinstallation if it reused. Remove the timing belt. Be careful not to allow oil grease on the belt. c5d4c02.jpg Regards, Jeep Brainy
Sep 16, 2009 | 2001 Kia Sportage
Trying to loosen the alternator belt on my mazda potege
if you have an adjusting bolt to loosen, check that the pivot bolt has been loosened as well, also see if you have a bolt operated tensioning device on the adjusting bolt, will look like a bolt screwed into the adjusting bolt, let me know
May 26, 2009 | 1999 Mazda 626
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
55 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
