Question about Jenn-Air JFC2087HRS Side by Side Refrigerator
We have a jenn-air jfc2087hrs (french door model) and the water pressure from the internal water dispenser is very low. the line has plenty of pressure.
    President:
  • 1,218 Answers
If your ice maker is making full size cubes then it should one of 2 problems.
The water valve on the bottom back of the machine is a dual valve. One side feeds the ice maker, the other side feeds the water supply.
1. The dual water valve. is going bad. The water side is malfunctioning.
The dual valve must be replaced.
2. Your model should have filters for the water dispenser, and need replaced.
Try changing the filters first.
Posted on Oct 24, 2009
Mine gets low pressure when filter needs replacing.
Posted on Nov 25, 2012
Jenn air french door water dispenser broken
You have two sides to your 67006531 Dual Water Inlet Valve, so it is very possible the side that controls the water flow for the dispenser is defective. Replace the 67006531 Dual Water Control Valve and I believe your fridge water will work fine.
I will be here should you have more questions, Thanks Sea Breeze
May 20, 2012 | Jenn-Air JFC2070KRS Bottom Freezer French...
Tip
New Jenn-air refrigerator, Model #JFC2087HRS, water filters do not work...
The new Jenn-air refrigerator, model #JFC2087HRS, water filters (UKF8001) do not work correctly. Water flow is slow. I have called the manufacturer but cannot get any help from them. They insist they work fine. I have tried several of the new ones. The problem seems to be that the small ramps on the new water filters are not tall enough to push the small plungers sufficiently into the water dispenser. I have added a small piece of plastic (glued) to the ramps on the water filter in order for them to work better, but not as good as old ones worked (UKF8001AXX). The next best thing is to buy the old filters if you can find them.
on Feb 24, 2014 | Jenn-Air JFC2087HRS Side by Side...
Jenn Air French/with freezer in bottom Model #JFC2087HRS, top part isn't cooling. Freezer is fine.
You may have a defrost problem check the freezer inside at the back and see if there is frost build up if so you need to check the DTS and element to see if they are good.Let me know and I will guide you through it.
Sep 18, 2011 | Jenn-Air JFC2087HRS Side by Side...
Problem with the water dispenser in the Jenn Air Refrigerator
Did you find a solutioin to this problem? I have the same exact one?? Thanks
May 29, 2010 | Jenn-Air JFC2089HE French Door...
I bought a used Jenn Air french door refrigerator model #JFC2089HES, but water will not dispense nor will it make ice. It's hooked up to a cold water supply under the sink which is working.
It sounds to me like you're going to have to do some serious electrical checking. There are two electrical solenoid water control valves right behind of the fiber cover where your water line connects to the refrigerator. One solenoid valve is for the water dispenser and the other is for the ice maker. They are mounted together, side by side, on the same metal mounting plate. You two sets of terminals on each solenoid. one set on each solenoid should be hot (register line voltage) when tested between the terminal and ground. the other set of terminals connect two the switches in the water dispenser and ice maker. If have someone push the dispenser switch while you have your ear close to the solenoids, you should hear a clicking sound. I have never seen both of the solenoid valves go bad at the same time. I believe you have a power supply problem to the solenoid assembly itself.
Mar 16, 2010 | Jenn-Air JFC2089HE French Door...
Inside water dispencer drips continually. Valves at back of unit were replaced but problem not solved
Unless you have another valve somewhere else, that is the only thing that could cause the problem. Have someone try the dispenser while you listen at the back and verify that the valve you replaced is the one the noise comes from when the dispenser is used. If it is, disconnect the line and watch to see if it is dripping. There could be sediment in the supply water that can stop the valve from closing. Low water pressure will also cause it to leak.
Aug 02, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Jenn air French door refrigerator model JFC2087HRS not cooling- making clicking noises
The compressor is bad....
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 06, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Water dispenser not dispensing
water line or water tank is frozen intermittantly
Jun 30, 2008 | Jenn-Air JFC2089H Bottom Freezer French...
Jenn-Air JFC2087HRS Side by Side Refrigerator Logo
530 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
