Question about Generac Guardian 065795 - battery charger rectifier
Over charging? blew up battery - Generac Guardian 065795 - battery charger rectifier
  • 37 Answers
Battery charger should be putting out between 12.5 to 14.5 VDC...Battery blowing up is typical in that generator because it is on a constant trickle charge and the battery will go dry faster than normal. Make sure you check battery level every 6 months and replace every 2 years.
Posted on Nov 22, 2009
Pass lock problems now newbattery blew our NEW RADIO'S Receiver on 2001 IMpala WHY?
You have some sort of wiring issue most likely. The fact that it blew your receiver could mean that you have a short in a wire where the new radio was installed, and possibly a wire that is bare and grounding out against some of the metal components inside the dash. The only other this I have ever seen do that to a radio is if the antenna wire has somehow shorting out to the body of the car and grounding out the radio.
Jul 16, 2014 | 2001 Chevrolet Impala
2000 dodge ram check guage light comes on. have a new battery and new alternator. also blew a 50 amp fuse.
Hi Les, I;m glad to help. There is an fusible link that runs off the battery cable pull on it and see if it comes apart, if it does replace it and see if everything is working properly. Hope this helps and have an awesome day Les.
Apr 20, 2014 | 2000 Dodge Ram 1500 Truck
Battery won't keep charge
sounds to me you have a faulty power steering unit, if it blown the fuse you must have electric power steering. I suspect your power steering is draining the battery. (internal short in power steering unit) If your battery won't hold or take a charge, replace it. check your alternator as well as that charges the battery.
Dec 16, 2013 | 2009 Chevrolet HHR
Motor run fine just died yesterday so I took seat off and the battery had blew off to caps were the acid is I replaced the battery rode it for about 15 miles then cut it off got a Gatorade and went to...
It's time to do a full check on your charging system; that's probably why it blew the caps off in the first place.
Odds are that new battery you put in is completely flat (lost charge).
Oct 11, 2013 | Honda Motorcycles
Battery light will not operate
Check all fuses and verify no melted/damaged wires. You may have damaged something on the charging circuit by reversing the current. The battery light comes on when the alternator is not charging so I would double check the alternator at a different location as it sometimes will show good at one place and bad at another...Also have the battery checked to make sure there was no damage to it in the process and pray that the main fuse blew before any severe damage was caused.
Nov 11, 2011 | 2001 Mercury Sable
My radio will not play or charge a batterie while plugged in. I put in a new fuse because the original one blew and as soon as i plugged it back in it blew the new one. It will run with a charged batterie....
Hello,,,
my name is Falco, are you ready to take the unit apart ? do you have the necessary screwdriver ? do you have a volt meter ohm meter ? and do you know anything about electronics ?
May 05, 2011 | Dewalt DC011 AM/FM Radio
My new charger blew when plugged in and wont work again
charger is disposable, so if it blew, you need to rplace it with a new one.
Mar 29, 2010 | Compaq Presario CQ60-220US PC Laptop
1996 VW Jetta electrical problem
the battery was charged backwards,or the battery is hooked up backwards.
Oct 28, 2009 | Cars & Trucks
Sidekick 3
You Blew A Circut In the Charger Port Depending On the wattage of that wrong charger. Now HeresWhat you do. you Need to find out if you blew all the circuts in the phone or just the one for the charger port, Find Some One With A Sidekick Test the battery in your phone make sure its fully charged, If your Phone Comes on the rest of the circuts are fine, if it doesnt you need a new mother board. If It Does U Need To Have the Phone Repaired. Call Me 347.845.7151
PLz Be Sure To Mark The Problem Solved
Nov 26, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Generac Guardian 065795 -  battery charger rectifier Logo
577 people viewed this question
Top Generac Guardian Electrical Supplies Experts
Craig Butler
Craig Butler
jdthefixer
epangan29
Are you a Generac Guardian Electrical Supply Expert? Answer questions, earn points and help others
