Question about Westinghouse L1928NV Monitor
I have a Westinghouse L1928NV computer monitor that appears to be no longer working. It was fine yesterday but last night the power went out and now it is completely unresponsive. Suggestions? Thanks
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
Charla186, I think that you will need to have it evaluated by a TECH type of person. If unit will not turn on it could have a 'switch-mode-power-supply" failure and / or "backlight" inverter supply failure. You didn't state the AGE and or approximate "ON" hours this unit has. I don't quite know what you mean with "the power went out"?? Power to the whole house or office? or did you mean just the LCD monitor? Here are some options you might try. Warranty??? or Check with Westinghouse about a CASH + old monitor swapout for a fully refurbished same model. Have a local TECH at a TV/ monitor repair shop evaluate it's condition. I will also suggest you visit YOUTUBE and view some short video clips of LCD monitor disassembly just so you know what is inside a typical LCD and then know what the top 2 causes of monitor failure are. In any case get back to me and let me know what you think you will be your plan of action. I'm louie12fix on fixya or lmistyrel@aol.com Bye for now
Posted on Oct 05, 2009
My computer monitor shows a message "out of range". I can't get rid of the message or show anything from my computer.
The resolution your computer is sending is greater than the maximum support resolution of your monitor that isn't working or is a resolution not supported. Connect one of the monitors that works and turn down the resolution to something small (800x600 or 1024,768) and then switch to the original monitor back, you should see a picture and can adjust the resolution to something larger that the monitor supports.
Aug 08, 2014 | Westinghouse L1928NV Monitor
Westinghouse monitor drivers
What good are drivers going to do when you can not get it to power on
Jul 28, 2014 | Westinghouse L1928NV Monitor
Re: L1928NV has gone black yet light is still green. could it be a fuse and how easy is that to replace?
It can be power supply for the inverter circuits has failed (bad DC filter caps), failed backlights inverter circuits, and worst case will be bad lamp assembly.
You need to open it up and do in-depth trubleshooting, you will need proper tools to do the repair.
You may want to read my guide first to see if you will want to buy new monitor or DIY repair.
Example of failed WESTINGHOUSE: http://s807.photobucket.com/albums/yy352/budm/WESTINGHOUSE/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 22, 2011 | Westinghouse L1928NV Monitor
After a couple of minutes operation the screen goes blank. Switch the power off for 30 seconds and it refreshes and works ok for a couple of minutes tahen repeats all over
the problem of ur monitor is the power supply board,it is located in the inner part of ur monitor,technician is allowed for that problem.you need to call a technician for repair.
Oct 03, 2010 | Westinghouse L1928NV Monitor
Lcd model L1928NV takes 2 to 3 dozen times turning on and off to get image stays on momentarily or stays on at times get message "no signal input" any ideas
doug_karr, Well, Why don't you get inside the monitor and find the "thermally sensitive/intermittant, cold, frosty looking" solder joint on the "switch-mode-power-supply"/"CCFL inverter supply" and do a nice touch-up job of resoldering it. Also look for FAILED, SWOLLEN, looking electrolytic filter capacitors and replace them with new ones if required. Read my fixya profile for all your options. Good luck guy.
12fixlouie aka louie12fix
Jan 10, 2010 | Westinghouse L1928NV Monitor
Westinghouse L1928NV Monitor won't turn on
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. You may also have to replace 2 transisters and a fuse, if they were damaged by the blown capacitors. If you don't want to try the repair yourself we offer a repair service for $45 plus shipping. I hope this helps, if so please rate my solution.
We sell a kit with the capacitors, transistors and fuse for $10.00 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jun 27, 2009 | Westinghouse L1928NV Monitor
Audio and picture quit working on white westinghouse lcm-17v8
If you haven't figured it out yet through a web search, Westinghouse monitoris have problems with blown caps on the power supply board. If you are lucky the problem is minimal and won't require more than replacement of the caps. You won't know until/unless you open the case and inspect the power supply board.
Dec 23, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
Screen works for awhile but then goes blank.
if u have a problem wih your Westinghouse Monitor LCM-17V8 email me for solution or if you want to dispose of it; email me at
ekwhoward@yahoo.com.
Thanks
Ekow
Nov 04, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
Westinghouse L1928NV Monitor Logo
269 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
