Question about Epson Stylus DX6050 All-In-One InkJet Printer
Got an E-90 and 3 cogs on small screen - Epson Stylus DX6050 All-In-One InkJet Printer
How do I "reset" the brake?
If the chain brake is on and the sprocket cover is off the saw, they are a pain. You need to grip the clutch housing while turning backwards the tri-star \'cog\' in the inside of the sprocket cover. Ive done it in the past by holding it in place over the chain brake handle so the cog\'s line up and pulling the handle back in the off position. Failing that you might be successful using a pair of 90 degree circlip pliers.
Jul 01, 2013 | Husqvarna 450 e-series 18" Chain Saw
My 10 spd rear derailleur does not shift into small cog. With chain off I can manually move der. to small cog position then using the shift lever shift to large cob posision (9 clicks). But when shifting...
Sounds like you need to check you cable tension. If the limits are set correctly and the derailleur spans the cassette range, then the cable tension is incorrect to make all the necessary click stops. If the cable tension is correct then you may have problem with the shifter or you are routing the cable through the rear derailleur incorrectly.
Without knowing what specific components you are using it is impossible to be of more help, sorry.
Mar 25, 2011 | Cycling
Cannot get rear derailer to work properly 24 inch girls evolution
Don't start messing with the derailleur yet! Make sure your shifting trouble isn't due to something else, such as a warped, dirty, or stretched chain, gummed-up pulleys, crud in the cable housing, trapped cable, or a bent derailleur hanger
Clean the chain and the rear derailleur pulleys. Pull the chain away from each pulley, and turn the pulley to make sure it can move freely. A pulley that offers resistance to turning must be replaced.
Now check the cable to be sure it slides freely. Mud and grit within the cable housing, or on a cable-guide, can keep the derailleur from moving a "full gear" during downshifts. If the cable doesn't slide freely in the housing, you may be able to clean or lube it to restore smooth shifting.
Let the high-gear limit screw. In your highest gear on the shifter, and with the chain on the smallest cog, position the derailleur so the upper pulley exactly matches the teeth of the small cog. Run the chain a bit with the front derailleur in the large ring, adjusting the limit screw until the pulley and the cog seem to match perfectly.
Setting the high-gear (small cog) limiting screw.
Once you're sure the derailleur matches the cog, move it just a whisker (1/8 to 1/4 turn) towards the other cogs. (You may need to readjust a bit if you get chain-skip.)
Closeup of setting the limiting screw.
Now adjust the low-gear limit screw. Shift into the lowest gear (largest cog). If it won't go, loosen the limit screw. With the chain on the largest cog (and the front derailleur in the small chainring), adjust the derailleur so the upper pulley exactly matches the teeth of the large cog.Once it's perfect, turn the limit screw so it moves the derailleur a tiny amount towards the other cogs (1/8 to 1/4 turn usually works).
Setting the low-gear (largest cog) limiting screw.
Now shift to the highest gear (smallest cog). Push the shift lever to downshift one gear (go from the smallest cog to the next-smallest). If it doesn't shift, tighten the cable with the barrel adjuster, 1/2 turn counter-clockwise. Backshift and try again. Continue tightening until it shifts. If it overshifts, going from the smallest cog to the third-smallest, loosen the cable by turning 1/2 turn clockwise. Backshift and repeat until it shifts exactly from the small to the next-smallest cog.
Fine adjustment of tension in the derailleur cable.
Now go to the second-smallest ring. Tighten or loosen the cable slightly, until the outer side plates of the chain are just clearing the third-smallest cog. Shift up and down, fine-tuning until you're satisfied.
Checking the position of the chain on the cogs.
Mar 04, 2011 | Pacific International Pacific Evolution 24...
The tailblade has stopped spinning. It won't go forward or backward, just up and down.
ok take all screws out and seethe three cogs? a small one has unmeshed from the top cog. place the cog back together and then turn it on. try moving the helicopter up a bit. now it should work
Jan 21, 2011 | SYMA Toys industrial 2 Tail Rotor Blade...
I have an Epson Stylus photo R245 and have got error code E-90 with 3 cogs showing on display
epson stylus photo r245 fault E-90 WITH 3 COGS
HOW DO I RECTIFY THIS PROBLEM
Aug 16, 2010 | Epson Office Equipment & Supplies
When the screen is tilt back more than 90 degrees shuts off
Look closely at the area where the computer "folds";
there's a small sensor that should trigger when you *CLOSE* the lid -- perhaps, something is triggering that sensor (a small pin) when you're exceeding 90 degrees, putting the computer to "sleep".
Apr 05, 2010 | Compaq CQ60-215DX Notebook
I have a 1998 Gt Aggressor 26" bicycle. When shifting in the large gears, it hesitates before shifting or does not shift at all and just clicks. Can you help?
sound like the shift adjustment need moving or the cable to be adjusted from gear shift to the cogs there are a couple of ways to do this first select the low gear so the cable is slack and then look where the cable connects to the cog shift if you loosen the nust holding the cable and pull a little cable through retighten and try shifting.. if this doesnt work look at the way the guide moves the chain across if you see the guide stopping before the chain goes onto the cog look closely and you will see two small screws on the arm one is to stop the guide going to far to the right and one to the left look at the one on the right that shlould be the one for the transit to the large gear cog if you undo the screw half a turn then try the gear shift again see of it move far enough to put the chanin on the cog if not undo a little more.. these screws work for both the small and large cog shifting so the same can be done for the small cog if the chain keeps coming off.. Good Luck A
Aug 04, 2009 | GT Bicycles Cycling
I need to know how to place the chain back on the gears
shift onto your smallest cog on the rear and shift to your biggest cog at the front then place part of the chain onto the small cog at the back and then do the same with the big cog at the front then simply pedal forwards and the chain should go back on by itself
Aug 03, 2009 | Huffy Cycling
Driving back from Dorset to London today the screen froze around 90 miles from London. it's displaying waiting for valid GPS signal. Any ideas on a solution.
yep, possibly slipped a cog ( metaphorically)
try resetting the BAUD rate and the PORT in settings. can happen if some electrical interference was experienced ( UFO?)
Jun 29, 2009 | Tomtom ONE GPS Receiver
Gears slip
I am a salesman from www.joyguy.com We mainly trade flashlight and other electronics. Feel free to contact us if you ar einterested in it, thanks.
Apr 19, 2009 | Schwinn Mesa Gs Mountain Bike
Epson Stylus DX6050 All-In-One InkJet Printer Logo
20 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
