Question about Cuisinart Brew Central 12-cup Coffee Maker
Discolorization(orange) inside coffee maker.
My Cuisinart coffee maker has orange on the inside walls for the water.How should I remvove it?
  • 523 Answers
Try mixing in some vinegar with your water (about a cup) and run it through a cycle, this may clean it out.
Tom
Posted on Oct 04, 2009
When brewing it makes a loud noise
I have 2 Cuisinart Coffee makers. Both make loud humming noises during the pump cycle. In my units, the water reservoir vibrates when the pump is active. Test by hand pressure on the water reservoir when brewing.
I experimented with adhesive foam pads and they worked well but...they eventually fell off. I often just push the unit against the wall behind it.
Oct 14, 2013 | Cuisinart SS-700 5-Cup Coffee Maker
Cuisinart 12-cup grinder coffemaker all gummed up
It is endemic to this unit - condensation builds up in the grind chute, which makes the grinds stick to the walls of the chute. Decalcifying with vinegar/water helps, but only in an indirect way - by keeping the inside tubing clean, decalcifying generally allows the water to flow through the machine without obstruction. Inside tubing that has calcium, lime deposits built up obstructs water, and makes it flow through the machine slower - when water flows more slowly through the machine, the machine steams off the water at a higher rate, hence more condensation builds up in the grind chute walls.
Generally, i have found all Cuisinart coffee and espresso makers to be high maintenance to a greater or lesser extent, but the Grind-n-Brews have the highest cleaning/maintenance requirement.
Mar 26, 2009 | Cuisinart Coffee Makers & Espresso...
Thermal carafe has liquid in cavity and coffee does not stay hot
Call Cuisinart and see if they consider it an in-warranty issue (it has a 3-year warranty). If it were just the liquid issue that would be one thing, but since it's not keeping the coffee hot, then you have a hidden crack somewhere. Mine has the sloshy liquid issue, but I just live with it since it still keeps the heat inside. Otherwise, it's been a great coffeemaker that has lasted for over 6 years. As far as the coffee spilling everywhere - I would switch to paper filters (don't use the paper in conjunction with the gold tone filter). The filter basket door latch may be worn - as many problems as you're having, this may be a warranty issue that Cuisinart can solve.
Dec 18, 2008 | Cuisinart 12 Cup Digital Thermal Coffee...
Won't brew all the water comes out the bottom of the maker
Cuisinart – leaking from bottom
There is a tube inside that is melted, damaged - cannot get this part from manufacturer. I would call Cuisinart to see if you are still in warranty.
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Oct 20, 2008 | Cuisinart DCC-1200 Coffee Maker
Where do I purchase replacement charcoal water filters for my coffee maker?
Cuisinart DGB-600 replacement charcoal water filters is Cuisinart DCC-RWF 6 pack charcoal water filters, 12 filters.
Oct 17, 2008 | Cuisinart DGB-600 Coffee Maker
Cuisinart Grind and Brew 10 cup coffee maker warm water leaks from bottom during brewing.
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Oct 12, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Problem with coffee maker cuisinart
Use a Torx T-9 tamper resistant tool to remove the screws on the bottom and access the inside of the machine.
Sep 01, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Coffee Maker DCC 2200
The user manual is a free pdf download from the cuisinart web site.
Dec 26, 2007 | Cuisinart DCC-1200 Coffee Maker
Open Questions:
See all Cuisinart Brew Central 12-cup Coffee Maker Questions
Cuisinart Brew Central 12-cup Coffee Maker Logo
55 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
