Question about Biostar P4M890-M7 Motherboard
Booting problem I've asus M2N-VMX mother board . In my m/b I didn't get signal for moniter & keyboard , Its not booting(no beep sound), wt can I do for it?
  • jeroooo Dec 25, 2007
    I got a solution for this . The problem is due to missmatch of Ram freq and processor freq. So I changed my moterboard.
  • lbrennen Mar 16, 2008
    we have an asus 266 motherboard we are trying to build from, it powers on but nnothing appears on the monitor. what should we try?
My PC wont boot properly..It makes thi continuos beep for 5 seconds then silent for a second then starts again. I tried removing the RAM and the processor and re-insreting them but it wont work.The monitor wont turn on but its ok.
CPU:
Core 2 duo processor E4600
DDR 2 RAM
BIOS Motherboard
Please help
Posted on Oct 14, 2008
    Problem Solver:
  • 4 Answers
Try these two alternatives:
1.try to clean or change the slot of the memory
2. check on th power supply you put on your motherboard for the new board there are the socket for the power to be placed on the otherboard
Posted on Dec 23, 2007
  • 95 Answers
Sounds very much like a power supply issue
No monitor signal on my m2n-vm dvi after installing my new graphics card asus en210.The graphics card was tested on my other pc and works fine..any help?
First boot the computer without connecting Graphic Card, then go to BIOS and find for VGA option change the option to compatible mood, save the setting and come out of it. now off the computer re connect your graphic card and start the computer.
Aug 15, 2012 | ASUS M2N-VM DVI - Motherboard - micro ATX...
No beeps or monitor signal
Sure, a motherboard can be a dud out of the box like any other part. If you have a known good power supply, processor and memory installed, and the machine doesn't boot and you have no video, the only thing left is a non-working motherboard. Return it to the vendor and get it exchanged as defective.
Jun 20, 2009 | ASUS M2N-VM DVI - Motherboard - micro ATX...
My system won't boot after installing a new 2 GB DDR2 RAM
Try cleaning it edge connector with soft eraser both side and dont try to touch the pin. If it doesn't help you got a defective one.
Apr 28, 2009 | ASUS M2N-MX Motherboard
ASUS M2N-MX SE Plus mother board windows 2003 audio drivers
It is better to install   windows xp..  because   2003  is not supportting  latest mother boards.
only windows xp  will solve that problem
thank u.....
Nov 19, 2008 | ASUS M2N-MX Motherboard
Asus m2n sli motherboard
That single beep is most likely POST. Power on self test. You're board, Asus M2N-E SLI uses an Award bios. The beep error codes can be found at this link: http://www.bioscentral.com/beepcodes/awardbeep.htm
If you are using a single PCI-E card, check that you have the bios set correctly. Shown on page 4.4.6. Do you have you're memory in slot A-1 & A-2? Check that you have PCI-E set for primary display adapter, pg 4.4.4
For windows XP Pro with out SP2, please disale ACPI in you're bios. After SP2 & updates, you can turn it back on. It's realy odd that you're high power PSU did not come with an ATX 4-pin_12v connector for the board. (Needed for CPU).
This is a standard feature for current PSU's. Can you swap the PSU? Considering what devices you are running. You can easely run a 350w PSU? This swap would only be used as a test. Next test, go into the bios & go to Advanced, CPU configuration, check hardware monitor. Stay here a bit & watch temp settings.
Go over these suggestions. Let me know if any one of these suggestions has helped? Can you see the drive in you're bios?
Luck!
M
Jun 06, 2008 | ASUS M2N-E SLi Motherboard
No signal to monitor when booting.
(1) Remove memory from mother board and start the system if you happen to listen long beep then RAM is not working properly.
(2) Clean RAM conducting area on mother board with clean cotton cloth, put one peice of RAM and test and check the othe peice also, if working you could any sign display . Before doing all these check mother board any LED is glowing if so your SMPS is working after you turn on UPS.
(3) Check for all proper connection for all cables. Have you connected video cable of monitor to mother board VGA (it will not work because it is disabled as soon as you installed XFX GeForce 8800 GT), your viedo output only will come through XFX GeForce 8800 GT VGA port.
(4) If propelm persits Deassmble complete the system and reassmble & do n't connect HDD, DVD, floppy. Cehck with bare mother baord, processor, RAM (put one picese at a time) by connecting viedo cable of monitor
Apr 19, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
No signal on moniter
are you using an add-on video card? If so, then go to BIOS and enable it.
Jan 14, 2008 | ASUS VIA KT133 Chipset A7V133 Motherboard
Bootup Problem
As you were re-seating the memory you must have some issue with the memory.
if you have 2 stick try using only one.
if you have one the switch to another slot.
Dec 21, 2007 | Intel Motherboard
Biostar P4M890-M7 Motherboard Logo
212 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Alun Cox
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
