Question about Toshiba Tecra S1 Notebook
Display freaks out
My display will start to show lines in three columns at the center like someone is running a vacuum cleaner in front of an old tv. It causes the background to become discolored.
It also seems to not turn off when display is closed. This can be resolved if i press firmly near the right speaker but comes back intermittently. Sometimes with power fluxes or if the display is jiglled and recently when the screen saver kicks in.
I have taken it apart and checked the board out and all seems normal. It's like there is a short somewhere. This problem started after i began using an external mouse.
It's a nice computer for what i need and it seems like everything is still working.
  • 466 Answers
There is probably a false or intermittent contact at the display end. If the problem were in the generated signals, the whole display would be affected. A problem always in the same area of a LCD display usually means either the Berg strip or (if you're lucky) the driver cable has come slightly loose.
Since you've already opened the thing, I guess warranty considerations no longer apply. In the case of the Berg strip, perhaps the best home-made remedy is to get a strip of soft silicon foam or adhesive soundproofing, and place it against the strip so the non-adhesive area, once the screen has been reassembled, presses DELICATELY the strip against the display, preventing it from losing contact again.
Another, sadder possibility is that the driver lines inside the monitor went awry (this would explay why the screen reacts to power surges). In such a case there's unfortunately no solution, not even the "display massage" that sometimes fixes "stuck" pixels.
I'd rule out the external mouse as a coincidence.
Posted on Oct 04, 2009
How i rest developer in machine
Did you run the F8 procedure? Counters are to be cleared before doing the developer. Hope you conducted the F8 before making any copies or prints. Or the new developer will need to be replaced. Service mode is Utility, Stop 00 stop 01. Counters. Clear all three counter for the developer. Under function is the F8. Remember clear counters first change the developer, then run f8, also good time to run F5 (Checks the drum density). HOPE YOU DID NOT USE a vacuum cleaner to remove old developer the static electric from the vacuum cleaner can destroy the sensor attached below the developer unit, with ribbon wire
May 07, 2015 | Konica Minolta Minolta DI-450 550 Toner...
BISSLL 7700 NOT RELEASING WATER
Make sure the hose solution line is connected, wet clean button is pressed, look for two small o-rings on the end of the fitted end of the hose solution line, and run the machine for 5 minutes with all three buttons engaged to dislodge any clogs from the heater.
Here's a link to one of our BISSELL Authorized Service Center if you continue to have difficulty.
http://www.bissell.com/service-centers/?cid=ccsocial
Nov 13, 2012 | Bissell 7700 Big Green Complete Vacuum,...
1990 f150 truck cranks up but got to press gas pedal tokeep running replace spark plugs ,wires ,ditributor cap rotor button throttle position sensor fuelfilter idle air control
Well,check for a vacuum leak,by starting it cold,and have someone keep it running while you spray some brake cleaner aT VARIOUS SPOTS WHERE VACUUM LINES MEET,or toward back of intake manifold,but not near air cleaner.
Any change in rpm down or up indicates a leak. don-ohio
Oct 09, 2011 | 1990 Ford F150
I have a 1987 s10. I need to figure out where the three vacuum line coming out of the transmission are supose to go. I bought the truck with just the vacuum lines hanging from underneith the truck.My 4...
The three lines hanging under the truck connect to a valve on top of the 4x4 transfer case, this is why the 4wd does not work. As for the throttle body lines there should be a diagram on the radiator support that explains that. You should have one large line that goes to the PCV valve, a small line going to the air cleaner, a small line connected to the MAP sensor and possibly another connected to a valve that controls the EGR valve. Your fifth line should connect to a port on the manifold that supplies vacuum to a tank that is the vacuum source for the HVAC control doors and the front axle engagement system. The axle engagement system is what the line hanging by the transmission under the truck is for.
Jun 03, 2017 | 1987 Chevrolet S-10 Pickup
I let someone use the cleaner, and it came back dirty. How to I clean the front plastic where the water pulls the dirty water through. It is day and filthy. Help
There are three screws that hold the clear plastic cover in place. Turn the machine over and remove the two silver colored screws at the outer edges of the cover. To remove the third screw, remove the dirty water tank, and you will see a screw at the top center. After the screws are out it should be easy to pull the cover off for cleaning.
Apr 09, 2011 | Hoover SteamVac F5914-900 SpinScrub...
My Sony KP-57WS500 TV has curved horizontal white lines. You only see them when there is something dark on the screen. Any ideas?
You have 3 CRTs inside of your TV that create image. Blue, Green and Red. Looks like one of them need adjustment due aging.
Remove front grille. Than remove center "shielding" piece held by 4-5 screws. Behind this cover you will find little black plastic box that have 6 rotating buttons on it. Take you time to study them. There is three columns and two rows. Columns represent color, rows - "Focus" or "Screen". You need to locate "Screen" row of three rotating buttons. They will be marked "B', "G", and "R" for colors accordingly. Turn on TV let it warm up and try to figure out witch color is dominating others on your screen. Then carefully turn rotating adjuster counterclockwise using Philips screwdriver. Try to muscle-remember original position of screwdriver so you can turn it back to it.
Eventually you will find the right one, you will see lines dissapear when you reduce voltage and reappear when you turn rotating shaft back. Sometimes more than one have to be adjusted.
Try to have all three color to be present and visible but with no over saturating and no horizontal lines.
Put cover and grill back - and that's should do it!
Regards.
Russ.
Apr 06, 2010 | Sony KP-57WS500 57" Rear Projection...
My car sounds like a vacuum line is not connected because when my rpm,s go up or my car drops a gear to pass someone i don't have as much power and i can hear a whistling from the front right (passenger)...
There are actually a few lines in your car. On the hood there should be a diagram of the vacuum system pointing out the different start & end locations. You can take a can of carburetor cleaner from your local autoparts store, attach the long nozzle and just spray a short squirt at a time near the beginning and ending locations of your hoses to see if anything is loose. The engine will slow somewhat for a second or two when the spray is sucked through any vacuum leak. Be careful & only use short bursts of spray along the lines you are testing. Give the spray a few seconds to dissipate/evaporate between sprays to prevent any potential fire hazard. Spray around the throttle body, injectors & the intake also, any leak at all will show with this method. good luck.
Jan 30, 2010 | 2001 Nissan Maxima
Vertical Lines on Sony Bravia TV.
I'm afraid, its problem of LCD Panel (screen).
LCD Panel replacement is only solution for this problem and will cost you 70% of TV price, please contact nearest Sony service center for LCD Panel replacement.
Dec 13, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Toshiba Tecra S1 Notebook Logo
255 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
