Question about LG CU500 Cellular Phone
I cant even chosse my own ring tone
I am trying to choose my tone for my fone and it does not work at all why.....
Nokia 1661 my phone not ringing why ?
I had the same problem with mine. when I would go to tone settings every time I tried to hit ring tone it would turn off the phone and restart, by the way in ring tone it was blank. No matter what I did it wouldn't work. So I went to settings then restore factory settings entered the code. It reset the factory settings, then when I went back to tone settings the ring tone said Nokia Tune so I hit enter and it gave a list of all other ring tones, then it worked so my phone finally rings.... Hope it works for you.
Mar 22, 2010 | Nokia 1661 Cell Phone
My Black Jack II ring tone files are corrupted and will not play
check out this thread. near the bottom is an explanation to reset your phone back to default settings. you will lose all programs d/l so I suggest you sync your phone with your comp to save all your contacts first.
http://forums.wireless.att.com/cng/board/message?board.id=samsung&thread.id=68502
Mar 07, 2009 | Samsung Blackjack SGH-I607 Smartphone
Text message tone volume, LG KP500, Cookie
Go to Profiles, and choose a Customized Profile. Rename it to whatever you prefer. In this profile you can select your ring tone, message tone, volume, etc. I only had to do this once, and everything worked perfectly!
Feb 11, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
No message tone
doesit work with a standard msg tone if not ur phones its ready to get urself a new 1 i had same problem with an old phone
Sep 11, 2008 | Nokia N70 Cellular Phone
NEED TO CHANGE RINTONE AND HAVE LOST BOOK
not sure if this will work but go into downloaded ring tones pick one see the options and see if it says set as ringtone or message tone it should work also try going into profiles and perzonlize and go to ringing tone and pick downloaded tones hope that helps
Jun 30, 2008 | Palm Treo 500 Centro
How do i yurn my fone off silent
go to tone setting-alert function-select ring only.
Jun 10, 2008 | Samsung SGH-D600 Cellular Phone
LG Chocolate Ringer problem
Go to tools, phone settings, voice commands, call alert then do not select name repeat, the other 2 selections have a ring.
Mar 28, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Cant get ring tone or phones to work
This question was posted on the troubleshooting page for the VT-9118. This answer is specific to this model; other models have slightly different sequences.
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
  1. Remove the handset from the base.
  2. Press PROG. You should hear a single short beep.
  3. Press #.  You should hear a single short beep.
  4. Press a number 1 through 4. You should hear a long "ring" tone (it might be startling!). You can try other numbers from 1 to 4 to hear them all.
  5. Press MEM to confirm your ring. You will hear a medium beep.
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from http://www.vtechphones.com/docMgt/public/art/313/vt9118.pdf
Mar 13, 2008 | Vtech VT-9118 Cordless Phone
Keypad tones - D900i
Change the dialing font style to Normal and then set off keypad tones on setting menu.
Oct 07, 2007 | Samsung SGH-D900 Cellular Phone
Why won't it ring?!
The same happened with my phone and it was a faulty soundcard. i took the fone back and they sent it off to find that it was a faulty soundcard and replaced it for me. Now the fone works fine.
Nov 15, 2006 | Motorola Mobility RAZR V3i SLVR L7 L8 OEM...
LG CU500 Cellular Phone Logo
14 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
