Question about Microsoft Office Outlook 2003 for PC
When i open outlook 2003 i get the detect and repair pop up i run it and the next time i open the application the pop appears again, why?
  • 107 Answers
Please upgrade you microsoft office to Service Pack.
You can do this from here: http://www.microsoft.com/downloads/details.aspx?familyid=e25b7049-3e13-433b-b9d2-5e3c1132f206&displaylang=en
Posted on Mar 06, 2010
HOW DO I FIX LOST MAILS TOTALLY AFTER USING REPAIR TOOL?
It seems that the dbx file size is reduced either because: 1. The repair tool modify and reduce its size, remove the emails. or 2. The last time when you restart Outlook Express, it reduce the dbx file size and remove the emails. If you still have the original large dbx file, then you can recover all the emails inside it with OE-Mail Recovery at http://www.oemailrecovery.com/inbox-repair.html
This tool will never modify the original dbx file, instead, it will output the recovered emails into an output folder so that you can either open or import it back to Outlook Express. If you do not have the original large dbx file, then it is still possible to recover your emails. As long as you have stored the .dbx file on your local disk or drive, the email data may still exist on your disk/drive. You can you can search Google utility to scan the whole disk/drive and recover the emails for you.
Feb 15, 2016 | Computers & Internet
Hi. How do i repair my Microsoft outlook?
Hi, from the "Start Menu" go to the Conrol Panel, select the "Add a Program ? Uninstall a program, open the window, next find the "Microsoft OutLook," select to ("Repair") a program, the "Wizard" will Run! Next, restart the computer after the application finish. "If the solution helped? Rating it is appreciated, thanks."
Feb 28, 2010 | Microsoft Office Outlook 2007: Windows
Outlook 2003 won't open "Unable to open the Outlook window"
Hi, i would recommend this, if you have not tried it already to go to this site hp site and search for the driver there, by entering the relevant information. I have a HP laptop and there where I get my drivers.
Oct 25, 2009 | Microsoft Windows XP Professional
Outlook 2003 hangs at startup.
1st run a complete virus and spyware scan
Clear all internet cache
if outlook will not restart, I would back up any pst/ost files and deinstall office reboot and reinstall.
Hope this helps.
Jul 28, 2009 | Microsoft Outlook 2003 for PC
Microsoft Office Outlook often fails to open. I
Make sure you have all of the critical and important patches for both your operating system and MS Office/Outlook. If you continue having these problems after being fully patched, go to the Add/Remove Programs (XP and earlier) or Programs and Features (Vista) applet. Select MS Office (if you have the full Office installation) or MS Outlook (if you have the standalone Outlook installation). In Vista, select Change otherwise select Uninstall (which should open a dialog offering to Repair or Uninstall the application(s)). Select Repair and click Next to let it do its thing. A reboot may be required when it has completed its work. You also may need to reapply service packs and patches so make sure you visit Windows Update, Microsoft Update, and/or the Office Update websites as soon as possible.
Apr 09, 2009 | Microsoft Office Outlook 2003 for PC
Sometimes when I try to open Outlook 2003 in the morning after shutting it off the night before (but leaving the machine in sleep mode), it looks as though it is opening but never shows up and all I see is...
Outlook is actually running in your system.Do following steps.
Press Shift+Ctrl+Esc -> You will see the windows task manager.
In application tab you can see Outlook task.If its status is showing 'Running'. Then select that outlook task and click on Switch o.Outlook should open now.
And is Status of the task is showing 'Not Responding' or you cant see the outlook task then go in 'processes' tab.In this you will see a process named 'Outlook.exe',select that process and click on ' end process' and then reopen the outlook.It will work.You dont have to restart your machine every time.
And also do repair outlook.for this open outlook and click on help tab and select detect and repair' option.this will repair your outlook.
Mar 31, 2009 | Microsoft Outlook 2003 for PC
Outlook problem
Close outlook
delete the follwing registry keys
Start > Run > Regedit
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Outlook\Addins
HKEY_CURRENT_USER\Software\Microsoft\Office\Outlook\Addins
Sep 03, 2008 | Microsoft Outlook 2003 for PC
Microsoft Office Detect and Repair
If you go to microsoft's website you can somtimes download the individual files, if you go into c:\\ (or what ever your hdd is called) then program's files, find microsoft office, click Ctrl F and then type in the name of the file.
If this dosnt work go to http://pcwindowshelp.com/software.htm?gclid=CK_4oKmswJUCFQ6T1Qodb18fRA
they can somtimes fix the problem. Guy
Aug 21, 2008 | Microsoft Office 2003 Basic Edition...
Run Outlook from a command line with the /cleanprofile switch appended to the command.
To find the correct command line, right click on a shortcut for Outlook and go to Properties. Copy the information in the Target field and Paste it to the command line. If there is already a command option, remove it and add /cleanprofile after the closing quotation mark. (Add a space before /cleanprofile)
For example, go to Start: Run. . and enter something like "C:\Program Files\Microsoft Office\OFFICE11\OUTLOOK.EXE" /cleanprofile .
Then add a new profile. Be sure to check the check box for "Set as default profile". Note: You cannot see this option unless you click on the "Options >>" button.
This should fix the problem.
Jul 02, 2008 | Microsoft Windows XP Professional
HOW DO I FIX THESE ERROR MESSAGES?
you need to run a inbox repair tool.
Make sure you close outlook
Start > My computer > Tools > Folder options > General tab click on show hidden files and folders > Apply ok
Go to the follow wing location to find scanpst.exe
if you are using Outlook 2007
C:\Program Files\Microsoft Office\Office12
If you using Outlook 2003
C:\Program Files\Microsoft Office\Office11
Double click on SCANPST.EXE
Click on browse go to following locaiton where your pst file as been save
C:\Documents and Settings\Robyn M. Drothler\Local Settings\Application Data\Microsoft\Outlook\outlook.pst
Click on start > then click on repair
Sep 11, 2005 | Palm Treo 600 Handheld
Microsoft Office Outlook 2003 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
