Question about Garden
Toro gas leaf blower erratic engine performance
Toro leaf blower gas 20 years old runs great for about 20 minutes then engine performance becomes erratic. let rest for 10 minutes and runs great again for 20 minutes.
  • 211 Answers
Hi
change the sparkplug or seals.
bye
Posted on Oct 07, 2009
Brushes on the motor are bad. where can I buy them
Sounds like the brushes are worn out and in need of replacement, if available.
Nov 04, 2011 | RTO Weed Eater Electric Barracuda 2595...
Need oil to gas mix for toro 41 cc back pack blower
I run a 40:1 ratio in all my 2-stroke equipment, regardless of factory reccomendations. If you run a 32:1, you get excess heat and carbon build-up. 50:1, is too light of lubrication. 40:1 is just right! About 3.6 oz. per gallon of gas. I've had great luck with it for years! One of my blowers has been used commercialy for almost 15 years!
Oct 07, 2011 | Toro Lawn Mower With Toro Power Tools
My mower is four or five years old and has done well, but now when it is used it runs great for about fifteen minutes and then sputters and dies. When it does this it will not restart until it cools
The oil level is low. when the oil drains from the engine it fills the base to the level of the sensor. When it runs it takes a little time for the oil level to drop below the sensor..........Hope this helps.
May 20, 2011 | Toro Lawn Mower With Toro Power Tools
My Toro CCR 2450 GTS Snowthrower loses power after it gets warmed up. New spark plug and fresh gas with proper oil mix.Why?
Mine does same. Wait a half hour, restart, runs good for 20 minutes and slows again. Just had it in for a tune up. Machine is only three years old.
Dec 31, 2010 | Toro Lawn Mower With Toro Power Tools
I have a Toro 20332 that stopped running after 20 minutes and would not restart. Tried several days later and it would start for a few seconds and stop again. Took it to the Tor dealer twice last year...
Just take off your carb and give it a good cleaning. Be careful and watch how everything comes apart so you can put it back together with little or no trouble.
Jun 07, 2010 | Toro Lawn Mower With Toro Power Tools
Toro 521 snowblower..nn replace gas line to carb, it runs inside the engine cover..removed all bolts but the back cover doesnt seem williing to be removed
Or, you can try the easy approach. Take a 1/4" bolt about 2" long and cutoff the head. Force the bolt into the old fuel line on the fuel tank side (after removing fuel tank), push other end into new fuel line, tape the lines together well with electrical tape. Gently pull from one side and push from the other until new section of line comes through. Just did this and it too all of 5 minutes.
Oct 29, 2009 | Toro Blowers Rake and Vac - Electric...
Mower starts fine, however have to keep priming every minute to keep running, we had this same problem last year, and sent out for repair at retailer we purchased from, new gas, filter, gas and oil. please...
You will need to check the fuel lines for cracks/breaks.
You will need to disassemble the carburetor and spraywith carb.cleaner. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals and/or jet in carb. These portals can become blocked. you may need to replace the diaphragm. Reassemble and start.
(NOTE:If the carburetor parts are more than four years old, and depending onthe use, you will need a new carb. kit if the cleaning doesn't work.)
If you need further assistance, just let me know.
Jim
Jun 14, 2009 | Toro Lawn Mower With Toro Power Tools
I have a toro-recycler. it is about four years old and has always run great-until now..it shut off in the middle of the yard and wont re-start. i put in fresh gas/sea-foam, new plug, and air cleaner..it is...
It sounds as if the gas cap may be clogged. It must be able to breathe so that the carburetor gets the proper gas flow. Does it run for about 10-15 minutes? If so, this is more than likely your problem.
Jim
Jun 08, 2009 | Toro Lawn Mower With Toro Power Tools
Toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 6.5 hp 9 year old mower. Starts Ok; surges
Sounds like your carburetor needs to be cleaned out. The surging is usually a sign of running to lean (not getting enough gas) because of possible water, rust, gum, varnish or trash in your carb. Hope that helps.....
May 17, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
