Question about Microwave Ovens
Lost power to the house yesterday for about 15 seconds, was enough that I had to reset the clocks on all the appliances. When I went to reset my Sharp microwave drawer clock everything went according to directions. My problen is that now my microwave is stuck in the Demo mode and won't heat any food. Followed directions for correcting the problem, it says it is fixed, when I try to use it is still in Demo on, I need it in demo off to heat food. Am I missing some part of the directions to correct this problem. Please help, Sandy
    President:
  • Microwave Ovens Master
  • 1,922 Answers
Have you held the "cancel" key on the pad for 5+ secs or more?
Posted on Oct 06, 2009
  • daniel  hendrickson
    daniel hendrickson Oct 06, 2009
    re check your owners manual there are different ways to clear the demo mode and manufacturers steps to do so vary
Oven Control Panel "OFF" or ignitor is broken?
need model number and brand name,i've seen the power go out and when the power comes back on the power surge takes out the computer board or clock assy.but if she touched the panel she might have locked the board,on some models if you hold the clockbutton in for 5 seconds,some you hold the start button for 3 to 5 seconds or it has a lock button on it so if you send the model number i can check that for you,you can try unplugging it for like 15 minutes and see if that resets it or the power surge took out the board if it's not locked out
Mar 10, 2014 | Microwave Ovens
Our home lost power yesterday, now microwave will not work. Clock is working but it's like the panel is locked. Turned off breaker to try to reset and now on display it indicates 8-:44. Suggestions?
You should be sure that you leave the breaker off for about 15-30 seconds when doing a reset.
If it still won't work right, you either have a defective board or a shorting keypad.
Try the rest several times and note whether the display comes up that same way every time or what.
We can help you with a repair either way.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
Oct 11, 2011 | Whirlpool GH7145XF Microwave Oven
My electric power supply went off yesterday now i can't get the microwave off demo mode
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
May 27, 2010 | Panasonic Microwave Ovens
Spacesaver powers off 2 seconds after resetting clock and time...
The clue is that you have to reset the clock. You are losing power somehow. the Main Board thinks it is being unplugged and it resets the clock and you have to start all over. The fact that after so many times it will finally work tells me that whatever bad connection you have is finally getting hot enough to expand and make a good enough connection to keep working. Intermittant connections are the worse to find. A lot of trial and error to find the problem. can be bad fuse and fuse holder ( in the unit), bad outlet, loose wire at circuit breaker, loose wire at outlet. Even a loose breaker where it snaps onto the buss bar in the Breaker Box. Etc, it an really drive you nuts trying to find it. Try the unit in a totally different area making sure it is on a compleately different circuit breaker and see what it does, if the problem follows the unit, the problems is in the unit. If not, electrical problems, outlet, breaker, panel,
Aug 18, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
GE MicroWave JES1136WL01 died while defrosting.
Mine has the same problems. After removing top cover, check fuse on power supply board (mine was OK). Then check thermo fuse located to the far left under the top cover( 2 black wires going to it) using a meter. I then jumped this fuse to see if this was the only problem. I hope to find a replacement thermofuse at the local hardware store.
Nov 17, 2008 | Microwave Ovens
Problem with electrical source
Does your manuel also tell you to use a DEDICATED 20amp circuit to plug your Microwave in to? More that likely you used a 15 amp circuit that other appliances were also plugged into. A refrigerator or other cooling item needs its own 15 amp circuit but can tolerate small amp draw items like a clock. The new, higher wattage microwaves need a 20 amp circuit for itself. Have your line checked , have your microwave fixed. Start new
Aug 26, 2008 | Microwave Ovens
I have lost instruction book for Sharp Compact R250A microwave oven-how do I reset the clock?
May be a little late, but... 1. Press Power Level button for approx 5 seconds - you get the 12 hour clock 2. Press again for 24 hour clock 3. Set hours using the 10 min and 1 min buttons 4. Press Power level button 5. Set minutes using the 10 min and 1 min buttons 6. Press Power level button And you are done
Gert
Aug 05, 2008 | Sharp Microwave Ovens
NO POWER, POPPED CIRCUIT
Two possible causes.
First (and most likely) the circuit is being overloaded. This kitchen circuit may be shared with another appliance (like the refrigerator) which is drawing enough power when both are running to trip the breaker. A Typical kitchen circuit is 20 amp with #12 wiring. So an 1800 watt microwave might draw 13 or 14 amps while a fridge compressor kicking in can surpass 7 amps before it levels off. If this is an older home the kitchen may have a 15 amp circuit with #14 wiring. If the circuit is a 20 amp you will have to split the appliances onto separate circuits. (Under code a kitchen must have a minimum of 2 separate appliance circuits). If it is a 15 amp you might be able to split them as well or may be looking up upgrading the breaker and the wiring from 15amp #14 to 20 amp #12 (but you could still have the same problem).
The other possibility is a short or loose connection. If splitting appliances onto their own circuits doesn't fix this you would probably want an electrician to come in and check for other underlying causes which could represent a fire hazard.
Hope this helps.
Apr 01, 2008 | Whirlpool GH6177XP Microwave Oven
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
181 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
