Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
Standby light keeps blinking and set will no longer turn on.
Call a service tech
Posted on Oct 06, 2009
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
My tv whe I turn it on will only stay on for 4 seconds and then turns off, and the stand by light is on and blinking.
Have you when set turns off and standby or power light flash to count here the blinks if in a sequence like seven blinks, pause etc? This se should have the error buffer.
Dec 09, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony trinitron tv wont turn on and standby light keeps blinking
Hi
Blinking of standby light in Sony sets are fault indication. The number of blinks occurs at one instance must be counted. With that bumber I can reach to the fault section inside its circuit; sometimes to the exact fault point too. Just turn OFF the set, and turn it ON, and count the number of blinks at a time [do this atleast 3times and make it sure]; and inform me by Fixya. OK.
Jul 07, 2011 | Televison & Video
My Samsung LCD TV won't turn on. The red standby light keeps blinking and I can hear a clicking sound like it wants to turn on, but will not.
Unplug from the wall the longer the better, then hold the power button while pluging back in to try and reset.
Mar 15, 2010 | Televison & Video
Sony wega tv won't turn on. The standby light blinks six times..
sorry, 6 blinks is a bad board!!!will cost around 1000 bucks,just by a new set
Oct 09, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Standby light stays on
When attempting to turn on the set, the standby light should blink for a a while then stop once the picture comes on. If a problem is detected internally, the standby light should blink in a repeated pattern. Please count the number of blinks that are repeating and we should be able to help.
Thanks,
Dan
Aug 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby light blinking
Set has problem in one of the circuits, possibly sweep or video. All modern sets have a diagnostic mode when turned on, such as flashing standby LED. If there is a malfunction, such as a voltage loss or short in one of the circuit boards, the power supply will prevent further damage or fire hazard. Take unit to pro/tech for repair.
Apr 22, 2008 | Sony KP-57WS520 57" Rear Projection...
Problem turning On
Same exact problem started 01-08. Any suggestions yet>?
Dec 07, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Sony 32XBR400 Wont Power On
I do not believe the set is too far gone. The standby light blinks codes up to 7. If the standby light blinks more than 7 times it usually means that there is a short on the clock or data line. There are several small zener diodes connected to the clock and data lines in a couple of different places on the main board. Many times I have seen one of the zener diodes become very leaky, usually along the back of the board, loading down the clock or data line which produces the symptoms you are seeing. If you have no experience locating shorted zener diodes and unsoldering and soldering small parts, allow a qualified tech to service the set for you.
Aug 27, 2007 | Sony KV-36XBR400 36" TV
Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
321 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
