Question about HP Officejet 5610 All-In-One InkJet Printer
Squeals and then activates printer
Comuter squeals and then activates printer.
2 Suggested Answers
aroracaty2
  • 503 Answers
SOURCE: My printer squeaks/squeals when its printing. Any
Sometimes squeaking can be caused by the toner cartridge. Try reinstalling the cartridge or installing another. This cartridge's yield is 2500 pages. When is very used, it could make rare sounds. Always use genuine HP cartridge.
The arm of the pick-up roller is loose... is normal.
If the pick-up roller have a very smooth surface, replace it. Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Sep 24, 2010
Canon mf8380cdw squeals when starting up
Squeals are often a lubrication issue. Can you tell where the squeal is. Front, back, side. sometimes it's hard to tell because sound bounces and could be from anywhere. Does it go away right after first print or after warm up cycle?. Delicate equipment does operate better in the proper environment. The manual will usually tell you what room temp machine will work better in.Try to get a better idea of where noise starts Depending on how long you have had it and the print count it may need to be checked out by tech..
Feb 25, 2014 | Canon imageClass MF8380Cdw Wireless Color...
My Rheem powervent2 water heater squeals while running
The power vent motor squeals when burner is activated?
See if you can oil the power vent motor.
http://waterheatertimer.org/images/Anode-under-blower-200.jpg
If the water heater squeals when water is turned on, then remove heat trap nipples and inserts and install di-electric nipples from water heater department local home store.
Copy following link illustrations.
http://waterheatertimer.org/Low-hot-water-pressure.html#trap
Additional link:
Troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Oct 08, 2012 | Rheem Water Heaters
Connex 4300-300 squeals in talk back mode
turn rf gain up and the mic gain down until it stops squealing.
Jul 14, 2012 | Connex Cb Faceplate Sticker-fits 4300-300
Printer squeaks or squeal when moving paper
If your printer squeaks or squeals then i would stop using it and call HP 800-474-6836 provide them your serial number so they can check to see if it's still under warranty this printer needs service
Mar 01, 2011 | HP Hewlett Packard LaserJet 2605dn Printer
1997 Saturn SC2 squeals very loud the first 3-5miles
Try replacing the belt tensioner. Comes out easily, once you figure out access to it. Remove inspection panel inside front passenger side wheel well. Tensioner is right there, two bolts. If the spring gets weak, the belt will squeak.
Feb 15, 2010 | 1997 Saturn SL
Whirlpool Dryer squeals
Either the drum is rubbing against something or more likely the belt pulley is cause the noise. Oil the pulley wheel and the drum rollers and it should stop squealing.
Dec 14, 2009 | Dryers
Car squeals only in reverse
Beveled the pads in the reverse direction around 45 degree angle
Oct 29, 2009 | Infiniti J30 Cars & Trucks
Xerox WorkCentre M15i squeals when printing and copying.
Do not only lubricate metal shafts, but promptly lubricate the "pulleys" on the right and left side.  the will look very similar to a wheek and pulley mechanism.  The squeal happens when one "bar" connects two "wheels" and one side moves faster than the other.
Jan 23, 2009 | Xerox WorkCentre M15i Laser Printer
Squealing when not watching HD channel
replace or Resolder LL0377 then Glue it with gule from Glue gun.
Jan 19, 2009 | RCA D52W23 52" HDTV CRT TV
Squealing noise
possible causes are:
bra wire stuck in tub and rubs against the drum and squeals when on spin.
lip seal at front of bearings squealing - this is a difficult repair
Sep 02, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
HP Officejet 5610 All-In-One InkJet Printer Logo
37 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
