Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Tv worked fine last night. tried to turn on today
Tv worked fine last night. tried to turn on today and green light started flashing and would not turn on. tried the reset button and to unplug and no luck
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
ONLY 1 or 2 things can cause this problem----First thing to do is remove front speaker grill--it pulls out and secured with plastic pegs--behind it you will find an inspection plate---Notice the one or two pairs of wires coming from the front keyboardtv worked fine last night.  tried to turn on today - 2.gif of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---these sets have a Receiver(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up.
If disconnecting the keyboard2.gif allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---you can call them and get a quote for repairing the receiver.
SD Tech
Posted on Oct 04, 2009
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Mar 05, 2011 | Toshiba REGZA 47HL167 TV
WD57732 purchased 12/06 and has worked fine. Turned off at 11 pm last night. No indication of trouble. Tried to turn on this morning and nothing. Did TV Reset, green light flashed for a minute like it...
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2 years and tv been on each day like 4 or 5 hours a day in used.The lamp life are over.Should replace another lamp.
Dec 10, 2010 | Mitsubishi WD-57732 Projection Television
I have a Samsung plasma over 5 years old. power
The x-sus or y-sus panel wil be the fault.Check the fuses on these panels ,if one of the fuses is open then that panel must be replaced.Not verry cheap to replace.
Nov 02, 2009 | Samsung HPN4239 42 in. Plasma HDTV
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Power Issue 42" plasma flat HDTV Pixel Plus
you ip board is bad go t0 this site partstore.com typ in the modle of tv and buy it . works like brand new .trust mr it did and saved a lot
Apr 07, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
279 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
