Question about Refrigerators
Cooler does not cool
I have a coleman 12volt cooler with the ac adapter.
the cooler get really hot .It does not cool.
Bud
    President:
  • Refrigerators Master
  • 1,922 Answers
Is this one of those units that if you reverse the 12 volts it will heat the food instead of cool it,if so did you possibly get the power reversed,i know its an a.c. adapter,but it still needs to be rectified to d.c. to operate the unit after the adapter
Posted on Oct 05, 2009
How to change the battery for my 4345 coleman lanterne
There are two adapters for that lantern; one for the house and one for 12volt. You simply connect one of the adapters and it will power the lamp and also charge it. Those two adapters came with the lamp; if you don't have them you can contact Coleman to purchase replacements.
Jul 29, 2014 | Coleman 8D Family Size LED Lantern -...
Coleman thermoelectric cooler not cooling
Sounds like the Peltier effect elements have failed.
http://www.tetech.com/Peltier-Thermoelectric-Cooler-Modules.html
Depending on your handyman skills, you can change them yourself or have someone troubleshoot and change them.
Sep 12, 2012 | Coleman 40 Quart Powerchill...
The AC Adapter Unit is getting very hot. The laptop is a Toshiba Satellite L505D-GS6000. Is there a solution or is it recalled?
They're designed to run really hot.
If you hold your hand around it and it feels like a hot cup of coffee - this is normal. even if it is almost too hot to hold on to.
One thing to check;
Look on the bottom of your laptop for something like 19V 6.3A
make sure it is the same rating as your adapter, if it isn't you're using the wrong one.
You could buy another one to be on the safe side, they're not to expensive, but chances are it will run just as hot. (the more quality the adapter is though, the cooler it will run, but it will always get hot when plugged in)
Toshiba Satellite L505D AC Adapter
P.s. If i've grossly misinterpreted your adapters hotness and its actually starting to melt in spaces or smell like burnt electronics- buy a new one straight away!!!
This answers if copied from answers.yahoo.com, hope this will be useful.
Jul 07, 2011 | Toshiba Computers & Internet
Coleman Electric Cooler doesn't stay cold
the most common problem is that one or both cooling fans has failed. If you have the newer version, you can get replacement fans anywhere computer parts are sold
Jul 03, 2009 | Coleman Electric Cooler 40 Beverage Cooler
Coleman 12-volt cooler stoped working/fan burned out
Sound like you have the newer version. These fans can be found at Radio Shack or anywhere computer parts are sold. It doesnt have to be an exact replacement. Just big enough to fit over the Cooling fins. Also make sure it's a 12 volt motor
Jun 25, 2009 | Coleman Electric Cooler 40 Beverage Cooler
The 5640 Coleman cooler motor runs, but unit does not cool.
This is a thermoelectric (TE) cooler. There is no gas' to replace in it's cooling system. It is possible the thermoelectric coupler has gone bad. Unfortunately Coleman does not seem to offer a replacement part. If you Google thermoelectric couplers, maybe you can find something on the web. Good Luck.
May 25, 2009 | Coleman (100076) Compact Refrigerator
My coleman cooler is not cooling!
does it work with 12v and 110v and lp gas if it does it take up to 1 day to be very cold
May 14, 2009 | Coleman (100076) Compact Refrigerator
AC Power Adapter Replacement
the specs for the 4100 require a 12volt 2.5amp adapter with a 5.5mm OD amd 2.5mm ID tip with positive in the center. I have a some 12volt 4.0amp adapters withy the proper tip and polarity. This would be far superior to the spec one and will run much cooler. I can let you have one for $15. If interested email me.
Jan 04, 2009 | RCA MSN TV 2 Digital Media Streamer...
WE HAVE A COLEMAN 5640 PORTABLE FRIDGE. WE HAVE ONLY USED IT TWICE, AND JUST GOT IT OUT FOR A WEEKEND TRIP(TO PUT INSULIN IN)BUT IT ONLY HEATS UP, NOT COOL. ANY IDEAS? wE HAVE BOTH THE CAR ADAPTER AND...
I bought one but it was missing the cord, so I hooked it to the benchtop supply. I found out if you place positive to the red terminal/grey wires under the outside cover and negative to the blue/black wires it cools. With a DPDT switch and a couple of LEDs you could wire it so you dont need that special coleman cord, any lighter cord will work provided it can handle about 6 amps, I recommend 12 to 14 gauge wire and a 6 amp fuse.
Jul 18, 2008 | Coleman Refrigerators
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
