Question about Toshiba Televison & Video
Control changes volume but not channel or off on
  • 2,200 Answers
Hi
Whilst ii is possible there is a problem with the remote control itself or even the receiver on the TV - these problems are often associated with failing batteries in the remote.
Change the batteries for new ones and make sure the contacts are clean and good inside the remote. This may well resolve the issue.
Hope this helps. Thanks for using FixYa.
Posted on Oct 04, 2009
I also have a Sony STR-D365. Volume control works intermittently as well as right channel. Works if I "wind" the volume control up and down a bit and then goes out again. I reset it and no change. Any
There is a wiper on the back of the volume control that varies the resistance through the switch to control the volume. When you move it back and forth you are scraping the oxides off the switch and making it work again. I suggest you either get some contact cleaner and spray the control from inside (where the wiper is) or just change out the switch.
Jan 10, 2013 | Audio Players & Recorders
MKS Steering Wheel Audio controls
My MKS had this exact problem earlier this year. I took it in and they ordered and replaced the buttons. It worked fine for about three months and now is starting to act up again. Have you gotten any definitive answers?
Apr 02, 2012 | 2009 Lincoln MKS
Controller will only turn equipment on and off. Can't do anything else, ie: adjust volume, change channel, etc. Universal MX-900 Remote
Hello, Reset the remote control and use with the equipment . If it does adjust volume, change channel. then use have to get another one of different model
May 20, 2010 | Universal MX-900 Remote Control
Will not change channels, but volume works.
try numeric keypad, if unsuccessful then try reloading TV code in remote
Mar 19, 2010 | Philips Magnavox Learning Universal Remote
Panasonic plasma won't change channel or volume
Also had the same problem with our Panasonic 50" Plasma...could not change the channel or the volume (with the remote control nor with the actual TV controls). Before I called for repair, I UNPLUGGED the TV and then plugged it back after a minute. I was surprised....the TV started working again. (Switching the TV on and off is not sufficient). I could change channels and volume, etc. So this saved me a repair this time. Might be worth trying this solution. Wouldn't hurt one bit, but rather save you a repair fee.
Aug 26, 2009 | Televison & Video
I was able to program my Comcast remote to control the volume of my tv, but was unable to get it to change channels. Is there something else that I should do?
Controlling the TV power and volume is probably all you'll be able to do with that control. The Comcast remotes are meant to be used with their converter boxes, and normally people want to change channels on the box while the TV stays on the box output channel (usually 3, sometimes 4). The remote's channel up and down buttons and number keypad only send out the codes recognized by the converter box. You'll need to fall back to the TV remote if you want to control more than power and volume.
May 04, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Volume and channel control on TV not working
The control board is defective. Is in warranty so call Sharp to have it fixed.
Dec 29, 2007 | Sharp LC 37D62U 37 in. LCD HDTV
Remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Oct 02, 2007 | Toshiba 20AF44 20" TV
Televison & Video Logo
217 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
