Question about Karcher 2500 PSI Pressure Washer
No water pressure.
I have a Honda gvc 160 is almost new and seen to turn on goob but i do not get any water pressure.
2 Suggested Answers
  • 56 Answers
SOURCE: Honda GVC 160
The small black valve is called a thermal relief valve. If it is open you will have no pressure. If the water is getting hot enough to pop that valve, there might be internal problems with the pump.
Posted on Nov 30, 2009
Grade of oil for honda gvc powerwasher
30 weight high detergent evry fifty hours due to the fact that it has a plastic camshaft
Dec 05, 2013 | Honda Garden
NEED PART NUMBER FOR HONDA DRIVE BELT GVC 160
The drive belt will not be a Honda part but a Husqvarna part. 532408031 You can also get the same belt as an AYP part by dropping the "532" and using 408031. Hope this helps.
Feb 26, 2011 | Husqvarna 7021RH 21Inch 160cc Honda GCV160...
Have a honda gvc 160 power washer. It works ok for a while then loses all pressure. It seems as though when it is not running and the water is attached there is not as much water coming through. Is there a...
Sounds like the machine is not getting enough water.
Please check your water pressure to the machine and also the water inlet filter in case its a little dirty.
Jun 16, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
Honda GVC 160 lost pressure - noticed small black valve (back - rear) after pressure builds up , short spray then nothing - hot water comes shooting out the black valve - did something pop off?
Nov 22, 2009 | Karcher 2500 PSI Pressure Washer
Honda, self propelled lawn mover. GVC 160. Used
Could be Flywheel Key, Coil and Do buy a New Spark Plug. Make sure Head bolts are tight.
Jun 26, 2009 | Garden
Honda gvc 160 not starting. cleaned the ventui & plug
Check the fuel.
Drain some of the fuel into a white contain...I use a paint can lid. If it yellow to orange in color it's bad. You can pour the fuel into your car to get rid of it. A car has electronics that will compensate for poor fuel quality, small engines don't.
Check spark.
Remove the spark plug and reinstall the wire. Lay plug on the engine block where it can contact it. Pull over the engine. You should see spark. If not change the plug. If still no, I give you further instructions.
Mar 31, 2009 | Campbell Hausfeld PW2102 Gas Pressure...
I cannot get the gas powered honda gvc 160 press wash to start
Pull float bowel and check carb may need to clean it. Drain any water from tank through fuel line.
Mar 18, 2009 | Honda 8 HP Engine
I can't find an oil drain plug on a honda 5.5hp engine.gvc 160.
The engine drain plug is on the main (square) base part of the cylinder block. I think it is 10mm. There is a compression washer to seal it aswell so it might need a bit of extra pressure to start it undoing. This should drain your block almost completely.
For diagrams go here, you will need the engine serial number and prefix.
http://www.honda-engines-eu.com/en/welcome.html
For manuals go here,
http://www.honda-engines.com/Engines_owners_manuals/own.htm
Nov 13, 2008 | Garden
Karcher 2500 PSI Pressure Washer Logo
182 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
