Question about Philips Magnavox 51MP392H Rear Projection Television
Hitachi chirps, will not turn on.
My Hitachi will not turn on unless I unplug it from the wall for 5 or moe minutes. When I plug it back in I hear a "dong" noise like the capasitor is charging just for a second though. The tv will ten turn on. If I turn it off with the remote It chirps, and will not turn back on. I opened it up and it was very dusty, so I blew it out with 35 psi compressed air. I left it for a while to let any moisture dry and plugged it back in. No joy with the original problem. model number C50FD2000. I suspect it is the HOT. not the Convergence IC's. Since it will power on and have great picture if unplgged for a while. I might be wrong though. I would like to do the repair myself, I work on aviation electronics, so my skill level it a bit higher than the norm. Any sugesstion and/or ideas are appreciated. Also, where might I find a schematic and/or service manual for this model TV? Thanks in advance.
    Top Expert:
  • Philips Master
  • 14,553 Answers
I fix a lot of Hitachi sets but have never seen this model--if you GOOGLE the model number--( I just did this) there is a site where you can download the service manual (not allowed to post it here) for free.
I would from your description guess maybe a bad solder connection in or around the hot transistor, driver circuit or at the HV transformer.
Good hunting
SD TECH
Posted on Oct 04, 2009
Hitachi 51F520 keeps turning off and on
hi, the tv is not set on sleep timer is it. the other fault could be a dry joint or a swollen capacitor a loose board with the power off you will need to do a visual check make sure you've got a good light hope it helps
regards
shaun
Dec 06, 2011 | Hitachi 51F510 51" Rear Projection...
Hitachi 53UDX10B power button flashes, chirping noise, LEDs flash
The convergence issue might not affect the TV to the point of not turning ON.
The chirping noise you hear, it means there is a short circuit in the circuitry, possible the HOT or power supply assembly.
Apr 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Can't turn wii back on
Did you unplug it from the Wii, or from the Wall Outlet? You need to unplug it from the wall outlet, not the Wii. If you haven't unplugged it from the wall outlet and left it unplugged for 5 to 10 minutes, then unplug it from the wall outlet and leave unplugged for a good 5 to 10 minutes.
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself, so power to the AC adapter needs to be cut off.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up.
Dec 08, 2009 | Nintendo Wii Console
Will not come on
Good Day, codysdad0331;
Before calling an Authorized Service Center, try unplugging TV from wall for 3 to 5 minutes plug TV back into A/C outlet (reset). If no fix call "ACS". Average cost for you TV is about $650.00 depending on shop, location; always get a written estimate. Good Luck, big IRISH.
Sep 08, 2008 | Hitachi 53UDX10B 53" Rear Projection...
TV repair
Good Day;
Try resetting the TV by unplugging it from the wall. Plug back in after 5 minutes. If, no fix; call for An Authorized Service Center and have come out and give you an written estimate B4 repairs, most repairs on PJTV's avg $525.00. Good Luck, big IRISH.
Aug 25, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi 50EX12BX
Sounds like something is overheating causing the thermal protection to trip.
Jul 25, 2008 | Hitachi 50UX57B 50" Rear Projection...
No picture
Good Day;
Try resetting the TV by unplugging from the wall A/C outlet for 3 to 5 minutes, plug back in. No fix? Your TV's LAMP needs to be replaced. Part number; UX21516, for Model 55VG825.
Jul 06, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 60" picture flashes on and off.
I've had the same issue although I don't unplug everything. I turn it off and then unplug it from the wall for 10 seconds then plug it back in. Seems ok after that. Has happened 4 or 5 times over the 10 years I've owned it.
Dec 20, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Hitachi 60FX20B
If you hear the unit comming on and theres no sound or Picture, then theres a fault in the horizontal sweep/HI Voltage circuit. This should not be fooled with unless you know the safty issues with HI voltage as theres voltage in these sets even after they are unplgged for a while. Good Luck
Jul 06, 2006 | Hitachi 60FX20B 60" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
73 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
