Question about Cameras
SAND IN LENS
Samsung ES15 - I have sand in and around the zoom lens which prevent the cmaera from operating. I was told it was cheaper to buy a new camera then to fax this one. Is there a trick to cleaning around the len?
sangita
  • 32 Answers
SOURCE: zoom error too
No I don think piece of sand got in lens.you need to chek the zook button if it is faulty then i think this error should diplay sangita
Posted on Jul 08, 2007
Agent Allan
  • 480 Answers
SOURCE: Zoom lens not working
Hey cjk1234,
You can replace the lens on the camera through a authorized service technician, but often with digital camera repairs the cost of the repair exceeds the price of the camera. I would have the camera looked at by an authorized service tech.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Apr 25, 2008
arclight1217
  • 208 Answers
SOURCE: Digital camera got dropped into
THIS SOUNDS TERMINAL, BUT YOU MIGHT TRY USING CANNED AIR LIKE YOU USE TO BLOW DUST OUT OF YOUR COMPUTER, AND SEE IF IT HELPS ANY. MOST OF THESE CAMERAS ARE MADE WITH THE IDEA THAT THEY WILL NEVER BE TAKEN APART OR OPENED FOR CLEANING ETC. SO, THAT IS THE ONE PROBLEM YOU ARE FACING. I DOUBT IF IT WOULD BE WORTH SPENDING THE MONEY TO SEND IT IN TO BE CLEANED. THAT CAN GET VERY EXPENSIVE IN A HURRY, PLUS TAKE A GOOD MONTH OR MORE FOR THE REPAIR. SORRY, I CAN'T HAVE MORE CHEERY NEWS, BUT THINGS LIKE THIS JUST AREN'T TAKEN INTO ACCORD WHEN THEY MAKE THESE CAMERAS. IF I CAN HELP MORE JUST REPLY TO:
ARCLIGHT1217
Posted on Nov 04, 2008
  • 11967 Answers
SOURCE: lens is stuck in full zoom position Olympus 7010 camera
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 10, 2009
  • 11967 Answers
SOURCE: Zoom Error with Fuij FinePix - looking for "telephone trick"
Posted on Dec 28, 2009
How do I zoom in and out on a photo?
This camera has a 9mm lens, and while shooting, you can't zoom. For that you need a zoom lens. You can buy one from Samsung.
I checked the manual, and it also does not show how to zoom in on a picture when it is on the display. So I guess, you should view it on a computer, or tablet ant use the picture viewer on that device to zoom in.
Be aware you have a great camera and the result with a prime (one focal length) is superior to the results make with a zoom lens.
But if you don't like to move around, to farm the picture, a zoom lens can be convenient.
Oct 07, 2014 | Samsung Nx Mini Smart Camera With 9mm Lens...
I've tried this method of banging on the knee/hand etc quite a few times and it fixed it, but not for long, after about 8 months of doing this every so often i've done this banging or rather tapping method...
Yep, if you're experiencing a "lens error", "system error", or "zoom error" it's likely because of the dust or sand. This problem is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 21, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Broke the lens gear. How to change them and where to get them ?
With a Kodak such as this it will just be cheaper to buy a new camera outright. The C503 is only a 5MP camera and should only be around $40 now-a-days. You can even get a much better camera (12-14MP) for cheaper than you would find replacement parts, especially the lens. If you truly want to stick with this camera, the only place you would be able to buy parts is straight from Kodak themselves. Here's the link:
http://store.kodak.com/store/ekconsus/en_US/pd/C503_Zoom_Digital_Camera/productID.146588000
It doesn't list hardware to buy but you should be able to contact their Customer Support by Email or Phone.
Dec 02, 2010 | Kodak EASYSHARE C503 Zoom Digital Camera
No lens lock on a Sigma 135-400DG, falls to full extension.
buy the glass that does not zoom via push pull - When they get old and sometimes right off the shelf new the push pull zooms get loose - the only fix is for you to have it serviced and even then it is a temporary fix as the very nature of what you do to use the zoom will ultimately cause the same problem to occur.
Apr 21, 2010 | Sigma Zoom Telephoto 135-400mm f/4.5-5.6...
Zoom will not return in camra. indecation on screen . fault in lens .The battery is full.
Could be that a gear in the lens is broken. Try PhotoTech repair in NYC. They are reputable and are authorized by the manufacturer to do repairs.
website:
www.phototech.com
Mar 29, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Camera lens will not come out all the way, and the screen says to turn camera on and off again. and absolutely nothing happens.
I brought my cybershot 7.2 to the beach, and stupid me did not have it in a proper camera case, and I am sure that a grain or two of sand got into the zoom lens. I used a sewing needle to no avail to try to probe this out, and in the end all I did was use my fingernail to help pull the zoom lens out, when turning the camera on, this worked perfectly after a few try's and the camera is now functioning as good as new.
The grain(s) of sand were obviously preventing the motor from opening the zoom lens.
Hope this helps.
Steve
Oct 10, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
The lens focas is messed up until i zoom it in it wasnt doing this until we took it to the beqach and it was still fine but now you hav e to zoom in to 2.4 to get the screen to not be fuzzy
Zoom lenses are very complex mechanisms with some lenses moving outward, while others are moving the opposite direction inside where you can't see them moving- the trip to the beach sounds like sand in part of the mechanism which isn't affected when zoomed out. Needs repair, but it's probably cheaper to buy another one as the repaiir will be higher than the price of a used one at around $75, and probably more than the price of a new one. Even if they do repair, you can never get all the sand out of the camera and lens.
Aug 06, 2009 | Sony Cyber-Shot DSC-S60 Digital Camera
I switch the camera on. I get 3 beeps and it shuts down.
The problem is of zoom lens motor which operates lens cover along with zoom, and it needs replacement with new part, and camera will start working fine again.
Thanks for using fixya
Jul 26, 2009 | Samsung Digimax S600 Digital Camera
Lens Error
Sand is a killer to cameras. If sand becomes lodged in the lens bellows it will jam. I have never after thousands of repairs had any lasting success in trying to repair. When taking a camera around water and sand buy some sandwich bags to place camera into protects against water and sand.
Jul 01, 2009 | Nikon Coolpix S550 10 Megapixel Digital...
Zoom Error
I think a grain of sand was blocking the zoom tubes. This will not work if the camera has been dropped & the zoom apparatus is bent. It is entirely at your own risk & may invalidate any guarantee but they may charge anyway if you have got sand in. I cut a finger of 80gm computer paper 1cm X 5cm. Inserted this first  around outer zoom tube & worked it all around. It goes in quite deep so be gentle. I switched on to open zoom & tipped out batteries before it had time to close & repeated procedure. When I put batteries back in it worked OK. I repeated procedure with lens fully extended. I found a thin bit of plastic packing worked better as it did not kink so easily. It is still working today having failed 100% before.
Chris
Jul 02, 2008 | Cameras
Cameras Logo
115 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
