Question about Casio FX-115ES Scientific Calculator
How to get a standard deviation - Casio FX-115ES Scientific Calculator
  • Casio Master
  • 8,073 Answers
I assume you know the theory. I will only show you the key strokes for 1-Var statistics.
Press [MODE] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to the variable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
The key stokes are similar for 2-Var statistics, except that you will have more statistical variables to choose from whwn you press [SHIFT][STAT][5:Var]. As I assumed above, you should be able to recognize what each variable means.
Hope it helps.
Posted on Oct 04, 2009
  • k24674 Oct 04, 2009
    To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
What is deviation standard
The standard deviation is a measure of how "tight" the samples are distributed around your mean.
In layman's terms, a small standard deviation indicates that most of your measurements are in the vicinity of the means; a large standard deviation corresponds to readings that are all over the place.
You could also say that the smaller the SD, the more your mean is representative of the data set.
For a better explanation, just look up Standard deviation on Wikipedia!
May 03, 2014 | Audio Players & Recorders
Where is s on the ti-30xa calculator
If you mean the standard deviation, there are two shifted keys on the third row marked with a lower-case Greek sigma. sigma_xn is the population standard deviation and sigma_xn-1 is the sample standard deviation.
Nov 12, 2013 | Texas Instruments TI-30XA Calculator
Does this calculator comes with a standard deviation or population standard deviation button
Yes. The sample standard deviation is 2nd [sigma x n-1] and the population standard deviation is 2nd [sigma x n].
Apr 02, 2010 | Texas Instruments TI-30XA Calculator
If both tests are graed on a curve, who did better and why?
Jill. She scored two standard deviations above the mean, while he only scored one-and-a-half standard deviations above the mean.
Sep 11, 2009 | Texas Instruments TI-86 Calculator
Standard Deviation
Press 2ND [CSR] to clear the stat data.
For each data point, enter the number followed by SIGMA+
If you have grouped data, enter the number followed by 2ND [FRQ] followed by the frequency then SIGMA+
Press 2ND [sigma x n] for the population standard deviation or 2ND [sigma x n-1] for the sample standard deviation.
May 25, 2009 | Texas Instruments TI-30X-IISTK Scientific...
Standard Deviation
I want to calculate a standard deviation on BA II plus
Apr 23, 2008 | Texas Instruments BA-II Plus Calculator
Maths & statistic
Standard deviation is the average root mean squared deviation from the average of the numbers.
Familiarize yourself with the wikipedia page on standard deviation: http://en.wikipedia.org/wiki/Standard_deviation
In this case, your question is easy. The standard deviation is 0, so this means the boys ages are all the same.
So they're all 24/3 = 8 years old.
Proof:
8 + 8 + 8 = 24 <-- satisfies the constraint that the boys ages must total to 24.
Get the standard deviation of these numbers;
8+8+8 / 3 = 8 <-- the average value is 8
The deviation of each boy's age from the average is:
boy 1
8 years old, which deviates from 8 by 0
boy 2
boy 3
So the deviations are 0, 0 and 0.
To get the standard deviation, you sum the squares of the deviations of each boy, get the average, and square root. So:
0² + 0² + 0² = 0
Average is 0 / 3 = 0
Square root of 0 = 0
So the standard deviation is 0. Which shouldn't be much of a surprise to you. We just had to actually DO the work to show that it was in fact 0.
Feb 08, 2008 | Audio Players & Recorders
Standard Deviation
Texas Instruments TI-86 Statistics How-To Information The following instructions should allow you to calculate the mean and standard deviation using a TI-86 calculator.
  1. Press STAT
  2. Select EDIT
  3. Enter data into a list: [2.32 ENTER 2.43 ENTER 2.39 ENTER, etc.] Continue until all data have been entered. (use arrows keys to go to the y value, if any)
  4. EXIT until you reach the main ("blank") screen. (If you try to calculate while you're in the data menu, it thinks you're still trying to enter data!)
  5. Press STAT
  6. Select CALC
  7. Select OneVa
  8. Select LIST, NAMES, xStat(F2), Press ENTER
  9. The calculator provides Max, Min, Mean, Standard Deviation, Sum, Sigma, etc. You will be primarily interested in the Mean and Standard Deviation (sx).
Nov 15, 2007 | Texas Instruments TI-86 Calculator
Standard deviation
StdDev( {1,2,3,4,5,6,7,8,9,10} )
with your list inside the curly braces.
Nov 10, 2007 | Texas Instruments TI-30 XIIS Calculator
Standard Deviations
This calc will do standard deviations. In the manual it is on page 2 and also on page 40.
Sep 07, 2006 | Casio FX-7400G Plus Calculator
Casio FX-115ES Scientific Calculator Logo
530 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
