Question about Clarion SRV303 Car Subwoofer
No power in my clarion i check the fuse and the wires is ok
  • bxmx42 May 11, 2010
    did you check to make sure your "remote" wire is connected properly? or that your ground is at a good location? if your grounded to a point that has paint where the wire meets the chassis you need to sand it to bare metal for a better connection.
  • 38 Answers
Check your remote wire. (should be a small blue one in between power and ground) You can also take a voltage meter to check that your CD player is sending the remote signal down the wire when it powers on. Make sure your ground wire is securely grounded to a good source. Make sure its not on a painted area, etc. Find a good bolt on the frame or body. If none of this helps, you can open the amp and look for bulged capacitors on the circuit board.
Posted on Oct 10, 2009
Temporary wired a clarion px 3310 for car installation, all was ok so turned off @ the head-unit and proceeded to install stereo with permanent wiring. Now...stereo installed, switch power on...nothing,try...
Here is the breakdown of the steps that you should take to pinpoint the issue.
  1. The first thing you should do is check the fuse for the radio. then you want to check the ground wire. Most people would think that if its not powering up then it must be the power wire. Not always the case.
  2. After you ensure that there is a solid ground between the chassis and the stereo you are going to want to check your Battery positive wire (power). Best way to do this is to use a test light. one end is clipped to a ground and the other end is a needle like probe, remove the harness from the radio and find where the power wire is fed into on the harness and probe it and see if you get the bulb to light.
  3. If the bulb does not light up, the next step is would be to check over the wires and see if there are any bare wires or any shorts. If there are wire connections that are made by electrical tape, take them apart and use actual wire connectors.
  4. Have the ignition in ACC on while probing.
  5. The last thing I could tell you and not stress enough. Be very careful when you are in there, people just don't understand just how tied into a vehicles electrical system a stereo is.
  6. Good Luck.
Sep 19, 2011 | Clarion Car Audio & Video
Matching wires from Seaworthy Marine Radio to Clarion M109
yes you dont need the orange but the yellow in the main power red is the iginition.
Jul 23, 2009 | Car Audio & Video
Amp doesn't come on
Hello rheabarb,
You did not say whether or not you checked the wiring going to your subs. Many times, a shorted or grounded speaker wire will cause an amp to fail. And if the amp powers up OK with the subs disconnected, I'd suspect one or more of the wires.
Hope this helps.
May 19, 2009 | Clarion APX1300 Subwoofer Mono Amp - 300W...
Clarion M5675 won't turn on
Take the stereo all the way out and hook the black wire to the negative terminal and the yellow and the red wire to the positive terminal on a charged car battey. If it still does not turn on you may have fuse in the back of the deck. If not it's probably fried.
Apr 19, 2009 | Clarion M5675-RET CD Player
CD PLAYER IN boat says ACCS and does not work, i have power and i checked the fuse's all working but the screen reads ACCS and i cannot remember how i fixed it the first time this went wrong,
OK, so I spoke with a Claion reseller and they were very nice and helpful. ACCS mode is accesory mode. This can happen if the brown wire in the back touches ground or the case on the radio. If it is not, tap the brown wire on the yellow(hot) wire and that takes it out of that mode. I tried it and it worked. Good luck! And thanks Clarion for your support on my 3 year old radio!
Apr 10, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Clarion stereo
Honestly I'm not sure - there may be, as some aftermarket decks have the secondary fuse. It's not too tough to pull it out and check so I'd do that - you won't have to disconnect any wiring or anything. While you do that, check the yellow wire and the red wire in the harnesses, as there may be an inline fuse on one of those wires as well.
Aug 31, 2008 | Clarion VRX935VD Car DVD Player
Clarion M335 display and CD work - suddenly no sound
Maybe it is a boat anchor. Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
Aug 14, 2017 | Clarion M335 CD Player
Antenna Power supply
First order of business is to check and see if the antenna is operating properly. If the wire in your harness is intended to power the antenna, connect 12 volts to this lead, and the antenna should go up (this needs to be done with the key in the ON or ACCY position). If the antenna does not go up, check the fusebox for a blown fuse. If the antenna does indeed go up, then you can scratch that off the list of possible problems and move on to the next step.
The Clarion should have a power input wire to keep the clock alive, and a power wire (normally of heavier guage) to actually power the radio. Make sure the radio operates when the key is in the ON or ACCY position. If the radio is operating, so far so good.
I'm kind of confused when you say there are two wires on the clarion... "power antenna turn-on" and "auto antenna". Are these both on the clarion? There should be a wire that constantly feeds the antenna with power (I would cal this one auto antenna). It should always be powered to 12 volts. The antenna should operate when the "antenna turn on" lead becomes 12 volts. Normally this ONLY happens when the clarion RADIO is on (ie: if you're listening to a CD, the antenna probably won't get activated).
After checking all this, if you're still having problems and if you haven't already done so, grab a DC volt meter and verify that the clarion power antenna turn on lead goes to 12 volts when you turn on the radio. If it does not, then there is an internal problem within the radio. If this lead IS going to 12 volts when it is supposed to and the antenna still isn't working, then my guess is that the antenna is malfunctioning.
Let me know what you find out... I'll keep looking at stuff from this end. Good luck.
Apr 19, 2008 | Clarion DB175MP CD Player
Clarion SRV303 Car Subwoofer Logo
115 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
