Question about RCA DRC8320 DVD Recorder/VCR
Dvd tray door will not open.unplug ang plug 100 times tray will not open and release dvd inside
This happened to me, heres what i did to fix it;
un plug the unit, remove the 7 screws holding on the cover, you can manually push the disc drawer out now, remove your disc, position the drawer so the center of the disc indentation is even with the front (bezel)
Now below the drawer you should see a black rectangular plastic piece with a small rectangular hole and on the right side a circular hole with a white nylon piece showing through, the rectangular piece snaps off (be careful its fragile) now you can see the two pullies the the old rubber belt went between(the old belt should be there also) find a rubber band approximately the same size or a hint smaller install it
, then plug the unit in and try it out (keeping your hands and tools out of the player) if the test works reasemble the unit and revel in your accomplishment. (I find the rubber bands last about 18 months)
Posted on Oct 04, 2009
  • booboo64 Oct 21, 2010
    Thanks for the info. I have searched but am at a dead end trying to find a drive belt for my recorder. I will try the rubberband trick.
Cd is stuck inside i have unplugged & plugged and pressed eject & power at the same time
Some CD players have a tiny hole on the door or tray that slides out. Stick a paperclip in the hole and it will release the tray. Yours may not have this, but it has to have some manual way of opening.
May 20, 2014 | Cambridge Soundworks CD-740 Clock Radio
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
Does not want to open door - shows "Blocked on the display. And Remote control does not communicate to DVD Recorder - new batteries fitted.
This will happen if you close the tray by pushing instead of using the insert/eject button. the BLOCKED error means the the rack and pinion can't be moved by the motor which takes too much current and stalls hence the error
The guide pin can jump is dogleg and cause the tray to bow slightly this can also cause UNKNOWN DISC as the head tries to read the DVD at an angle.
The best option is to free the tray UNPLUG and remove the cover the you will have to remove the inner cover on the top of the DVD mechanism you maybe able to see the tray bowed look underneath you should see the dogleg guide and the pin should be inside this track yours might be outside, try to re-seat don't force it or pull the tray out you may not get it back inside the unit.
With the cover back on test the eject if this still wont work there is a manual release on the underside of the unit which is clearly visible place a screwdriver into the hole and slide across to release the DVD
Nov 29, 2009 | Philips DVDR3380/05 DVD Recorder
In Philips DVDR3380/7 I need open for put DVD it say "blocked" permanently, which is the solution?
With the cover back on test the eject if this still wont work there is a manual release on the underside of the unit which is clearly visible place a screwdriver into the hole and slide across to release the DVD. This model has not release hole at the front as kladdaugh suggested this paperclips type of release is normally put onto ATAPI DVD-ROMs on your PC
Oct 22, 2009 | Philips DVDR3380/05 DVD Recorder
The DVD will not stop spinning. The door will not open either. When I took the cover of the players and plugged it in, the DVD just keeps spinning even when I hit STOP, OPEN, and turn the player OFF. ...
I've had this problem twice now.
The first time, I unplugged the unit for about a minute, plugged it back in and pressed the Open button. The disc was ejected and ran fine for about a week.
Then it happened again, but the unplugging didn't fix it this time.
Try this;
Unplug the unit and let it sit for a few mins to let the disc stop spinning. Then gently pull down on the DVD door. Look at the lower left side of the DVD tray and you should see a large slot. Shine a light into the slot and you will see a dime size white gear. I used a small flat head screwdriver to spin the gear to the right. After 2 small turns, the DVD tray opened enough so that I could pull it gently open. I took the DVD out, gently pushed the DVD tray back in and set the DVD player on my workbench to tinker with on a rainy day. Not sure what the root cause is, but I'll worry about that later!
Aug 14, 2009 | Samsung DVD-R135
My LG multi dvd writer lightscribe tray wont open. the green light is steady. no matter how many times i try to eject the tray ang it wont open. there is dvd+r inside.
use a unfolded paperclip and insert it into a small hole below the disc tray. This is the manual eject port. Stick it straight in and push, a little bit of pressure will be needed.
Apr 20, 2009 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
Samsung DVD-VR330: Disk Tray won't open
The solution is to unplug the machine and wait 10 secs. and plug it in again. I have to do this often. another part of the problem may be that some of the blank disks are bad. I got the DVD+R at Staples and about 4 out of 10 were able to be formatted. I am about to try the DVD-RWs.
Feb 01, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
DVD/CD door stuck on Bose 3 2 1
On the 321 systems turn off the power and unplug the power cord from the bass module. Wait 5 minutes and plug it back in. Then, simply hit the "stop/eject" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
Thanks to Matthew O;Neil for the the tip,...Italo
On a Lifestyle system with a tray that won't open, try this: Turn off the power to the system and unplug the power cord to the back of the media center itself. Wait 5 minutes and plug it back in. Then, simply hit the "open/close" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
If this does not work, then call Bose when you are home with the system at 800-367-4008.
Nov 05, 2008 | Bose (321GS) System
Hi I cannot get my d.v.d drive to open and close. What do I do?
  1. If the keyboard has a CD/DVD Eject key, press it. The Eject key is usually placed by the volume knob and is marked by a triangle pointing up with a line underneath.
  2. Double-click My Computer .
  3. Right-click the icon for the CD, CDRW, or DVD drive that is stuck, and then click Eject.
  4. If the CD or DVD drive door button is a long clear plastic bar on the front of the PC, press firmly on the right side of bar. Some models have a button on the front panel of the PC to the right of the hinged door. Press the button to eject the drive.
  5. If the drive door button is part of the PC case and is covering the actual drive door, open the door that is part of the PC case and press the Eject button on the faceplate of the drive.
  6. Restart the PC and press the Eject button on the front of the drive when the first screen appears (before Windows launches). If the drive door opens this way but does not open in Windows, another software program is taking control of the CD driver. Try shutting down or configuring any software programs that create discs or monitor the CD or DVD drive.
  7. If the door still does not open, do the following:
    1. Close all programs and shut down the PC.
    2. Unplug the power cord from the power outlet.
    3. Look for the small hole on the faceplate of the CD or DVD drive. This is the manual release. The location of the manual release hole will vary
  1. Straighten the paperclip and insert it into the manual release hole until resistance is felt.
  2. Once the resistance is felt, keep pushing the paper clip until the drawer opens a little.
  3. Remove the paper clip and gently pull out the drawer until the disc is accessible.
  4. Remove the CD and turn on the PC.
If the tray still does not open, do the following steps to check the power cable for the drive. Work on a hard flat surface over a non-carpeted floor:
  1. Turn off the PC.
  2. Unplug all power cords from the back of the PC.
  3. Press and release the Power button on the front of the computer.
  4. Remove the side panel.
  1. Unplug the power cable and wait five seconds.
  2. Find a different power cable that is not being used, plug the different power cable into the back of the drive, making sure that it fits firmly into the socket. If a different power cable is not available, replug the original power cable into the back of the drive, making sure that it fits firmly into the socket.
  3. Replace the side panel and plug in the power cord.
  1. Turn on the PC and press the eject button on the front of the drive.
If the optical drive does not have the manual eject feature and the CD tray will not open by using the steps in this document or if a disc has shattered inside the drive, the CD, CDRW, DVD drive may need to be replaced.
Thanks
Aug 18, 2008 | Computers & Internet
DVD stuck/jammed in tray
there may be two screws on the top of the tray that holds the rounded magnet, the one that is placed to hold the disc when spinning, remove it, you can then simply take the disc out.
May 19, 2007 | Pioneer DVR-810H DVD Recorder
RCA DRC8320 DVD Recorder/VCR Logo
200 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
