Question about Hobart Handler 140 Mig Welder
Hobart 135 wire feed sped control problem
The wire feed speed control runs at full speed regardless of the knob position. I checked the potenciometer and the ohms vary as the knob is turned but the feed motor still remains at full speed at all times regardless of the knob position.
  • paul wright May 11, 2010
    This definately sounds like pcb fault. Try replacing the pcb .
  • 92 Answers
You have a resistor down, first check the resistor on the centre pole then those going off to the two other pins
Posted on Oct 09, 2009
Hobart beta mig 170 wire feed wont adjust
The variable speed motor runs on 0-24VAC controlled by the speed control dial. The dial may be toast. Replace this part first. You may verify the part failure by using a bypass wire to see if the motor runs at maximum speed without the control dial (rheostat or potentiometer).
Sep 02, 2014 | Welding Tools
Wire feed is not stable on Hobart handler 135
is this a lower end machine ? the cheaper machines take the power from the welding transformer to power the feed motor and as a result the feed isn't stable, also is the wire liner and tip in good condition if not replace them, try blowing through the liner with compressed air to clear any dust from the wire
Sep 17, 2013 | Hobart Welding Tools
I have a Hobart 140 Handler, My Problem is the feed wire is feeding too fast. It can not be regulated with the speed control. I believe the problem is with the pc board but not a 100 percent sure.
Hi:
In order to check the wire speed control you will need to open the machine and test the wire speed control mechanism (rehostat, potentiometer) with the use a volt meter. If you see a a variation on it while moving the knob then your problem is the PC board.
Good luck and have a great day.
Aug 22, 2011 | Hobart Handler 140 Mig Welder
Have a Hobert handler 135 i can't control the wire feed speed it seems to run wide open.
Sounds like the restate that controls the wire speed is gone. Replace it.
Jan 05, 2011 | Hobart Handler 140 Mig Welder
Have a Hobart Beta-Mig 170 Wire will not feed
First make sure the nozzle tip is free of any debris and the wire will slide easily. Lift the case and go to the wire feed unit. Loosen the pressure nob then lift up to release the pressure wheel. Make sure the bottom wheel ( should have two grooves, one for .35 wire and the other for 025 wire.) Make sure the Wire Feed Tip is also free and it allows the wire to pass through. Pass the wire through the feeder across the drive wheel and into the hose. Allow the pressure wheel to drop, then lift the pressure know to the upright position. Turn clockwise to put tension on the wheel. Make sure the gas is OFF, turn power on, depress trigger switch. This should allow the wheel to turn and feed the wire.
Feb 25, 2010 | Hobart Welding Tools
I have a hobart handler 135 motor stops feeding
Take the drive motor off and blow out dust, chips, wire pieces, etc. and then rinse out with contact cleaner, blow dry, re-install. Had to do this every so often with mine. Hope that helps.
Jan 05, 2010 | Hobart Handler 140 Mig Welder
Hobart handler 135 feed motor for wire doesn't feed wire. motor is ok I tested it with seperate power source. No power to motor from main board or ??????
check the SCR ,looks like a big transistor mounted
to a heat sink or some of the older units had a relay
in-line with a fuse , I have a older Hobart and it is
a great little welder. If you snap a pic of the P.C.
board and email it ill rsheehan@northernsteeldesigns.com
point out what parts to check.and replace.
Rob
Dec 06, 2009 | Hobart Handler 140 Mig Welder
My welders wire speed control will not slow down wire feed speed, it goes full speed
how long have you had it? if it is still under warranty take it back. if not let me know and i will walk you through fixing it step by step. once you take the facing off, your warranty is invalid
Aug 21, 2009 | Hobart Handler 140 Mig Welder
Wire feeds too quickly
Some welders control wire speed with the amps control, some control amps with the wire speed control. You might try turning things up until it runs smoothly without pushing back. If you're new at welding, it does take some practice until it feels right.
Jan 15, 2009 | Hobart Handler 140 Mig Welder
Hobart Handler 140 Mig Welder Logo
976 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
oneStan
oneStan
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
