Convergence or image retention problem? Panasonic PT56TWD63G
I'm having a problem with my television, there is a blue shadow displayed by the screen, for example there is a subject on the news I can see the person in the middle, and off to the side there is a blue shadow.
After some research I read it could be convergence problems or image retention, I'm just not sure which one's the one causing the problem.
I've tried convergence reset, it didn't work.
I tried manually aligning the blue, but the crosses used to move that color around the screen until its on top of the main cross which is suppost to have all colors there to be aligned, doesn't move enough to meet up with the cross. The blue crosses just move a bit but never fall on top of the crosses its suppost to, it just stops. There is a series of crosses throughout the screen to do this adjustment individually, but the blue color doesn't seem to fall in place in any of them.
Is there another alternative could I try?
If I have to reach a tech, how expensive should I expect it to be?
4 Suggested Answers
  • 346 Answers
SOURCE: Convergence problem
replace the ics
Posted on Nov 24, 2007
premtech
  • 934 Answers
SOURCE: i have the mitsubishi 55711,i have a double image
This is a V-21 Chassis common, with these symptoms, for failure of the convergence amps. This set uses two STK 392-110 Sanyo amps mounted on a heat sink and hard to miss. They're a 40 pin ic about the size of a half pack of cigarettes.
It has also been my experience that two or more of the yoke return resistors need to be replaced, most commonly R8c21 and R8c22, both are 3.9 ohm 1w but test all of them for reliability.
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Posted on May 14, 2009
SD Tech
  • 14553 Answers
SOURCE: The power went out and came back on, then the TV's
If you have gone into the customer menu and CONVERGENCE is skewed and will not adjust:
One or both of the two STK-392-110 convergence chips that this set uses are bad.
The chips are about 2 1 /2 inches wide by 1 1/2 inches tall and are black in color. They are mounted on metal heat sinks2.gif with fins and are side by side--they will have the Stk-392-110 number printed on them in white letters.
If you locate them take a good look at all the light blue resistors in front of them--most are marked 2.2 ohms---look for any that are white or discolored in the middle---if you find one or more YOU HAVE FOUND YOUR PROBLEM.
BOTH chips and any bad resistors need to be replaced and the set adjusted. If you can do this repair you can save a lot of money as you can buy both chips (a pair) on Ebay for about 12 dollars plus shipping.
I have start to finish instructions for this repair on this type of set. Keep in mind, I am not allowed to post MY email address here for you.
If you cannot do this repair yourself, shop around your area--most shops charge 300-400 for this kind of repair--I do them here for 200-250 and have done hundreds of them.
If they say it has to go to the shop--keep looking as any good tech can do this repair in your home in about 1 hour.
If you have any questions or need advice reply to this posting here OR check out all my many solutions here for more information concerning what I have told you.
I am here to help people.
Regards, SD TECH
Posted on Nov 01, 2009
Testimonial: "SD TECH, THankyou for your quick and informative reply to my problem with my Panasonic PT-56TW53. "
Red, green and blue shadows
have you tried to run auto convergence
Mar 08, 2013 | Panasonic PT-47WX49 47" Rear Projection...
My Panasonic television has shadows on every image displayed. I have heard it could be something as minor as a tube, and they are not expensive to have replaced.
Ur tv is a DLP projection tv?Yes,than this tv have a problems known as a convergence pictures problems,it is dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board is it dead,to causes this problems.The tv convergence board must have it parts to be replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 10, 2011 | Panasonic TH50PZ80BCAB 50 in. HD-Ready...
The blue lense is off by 2 inches and can't adjust it. The picture has a blue shadow.
The tv have a problem known as a convergence problems,it dead.Any colors lines R,G,B mis alignment,have 3D pictures or colors shadows.The tv convergence board it dead.Require changing 2 STK convergence ICS and some or all it resistors to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 08, 2010 | Panasonic PT-47WXD63 47 in. Rear...
I have a Panasonic PT-53WX54J that will not Converge
you need to replace or have professional convergence amplifiiers. If know how to desolder and solder you could repair yourself or in home professional tv repairperson will cost you $275-$400. The convergence adjustments via remote are half the battle the IC's loose clarity over time.
Aug 23, 2009 | Panasonic Televison & Video
Blue Shadows
You need to install a convergence repair kit. The PT47WX42 Convergence repair kit at the following link is the correct one for your model. The kit contains both Convergence ICs and the six feed resistors, Plus the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Jul 20, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Shadows and text curved. Double images
The convergence IC's need to be replaced. The generic part # on them is STK392-110. This is not easily done by yourself.
Apr 09, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Red, Green, Blue curve upwards and cast shadows
that sounds like a typical Convergence IC problem..
http://i.ehow.com/images/GlobalPhoto/Articles/4575598/ConvergenceICs_Full.jpg
this is a picture of what typical convergence ics look like
Mar 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Blue shadow above writing and pictures on screen
it sounds to me like your convergence boarde is bad and needs replaced
Oct 23, 2008 | Televison & Video
Blue and yellow shadows on TV
dear friend,
the problem of your tv is a burnt image!
solution: replace blue crt
Jan 20, 2008 | Panasonic PT-47WX49 47" Rear Projection...
PANASONIC PT-51HX41E
The convergence amps have most likely failed. That unit takes two STK392-110 (Sanyo) amps. For more reliability I'd have them changed using an STK392-150. They have a greater amperage and higher heat tolerance.
It's clearly a job that you want a qualified shop to do.. Call around and get some off-the-cuff estimates on what they charge to change out the convergence amps and tell them that you would prefer they use the 150's instead of the 110's.. They'll probably wonder how qualified you are. :)
Bill
Nov 13, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
