Question about Nokia 1100
1100 SHORT POSITION TORCH LIGHT TAKING ON - Nokia 1100
    President:
  • 2,004 Answers
Hold on the C (cancel) key.
Posted on Oct 04, 2009
Posted on Dec 15, 2010
Hi i have a 2002 yamaha vstar 1100 classic and have lost lcd dash and brake lights all but main fuse checked it does start headlight works help please
Hi, Nelson if you have a dash or instrument light that is out and you have confirmed that the bulb is good then you need to do some quick diagnostics all you need is a test light and a wiring diagram usually found in the back of your service or owners manual.
1. Make sure your battery is fully charged with "CLEAN" and "TIGHT" connections and the instrument light fuse is not blown.
2. Inspect the bulb socket for corrosion and clean as necessary, a spray can of electrical contact cleaner and compressed air works the best.
3. Confirm your test light is working properly by connecting one end to the battery negative post and touching battery positive post with the sharp probe, the test light should illuminate.
4. With the ignition turned on to confirm you have power to the bulb socket by connecting your test light to battery negative or ground and probe the center contact, the test light should illuminate if not you need to check the integrity of the switch or sending unit the light represents, if that is ok then you have a short in the wiring between the component and the light bulb, if all is ok proceed to the next step.
5. Confirm you have a good ground to the light bulb socket by connecting the test light to battery positive and probe any metal part of the socket housing, the test light should illuminate, if not you need to find the short and repair as necessary.
6. Inspect the integrity of the spring loaded positive contact insulation tab by pushing against it with your test light to see if it goes down and springs back fully to it's operating position again contact cleaner and compressed air works best to restore proper function.
7. If your bike has a lot of mileage the vibration can cause bulbs to become loose in the socket by wearing down the soldered contact thus loosing spring pressure from the tab and eventually stop making contact this can be fixed by replacing the bulb or putting a drop of solder on the worn out end to ensure contact.
8. If all of your dash lights are out but are good then you most likely have a faulty connection to the dash wiring harness, inspect the connector for corroded, broken, or loose pins/sockets.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha Star Dragstar XVS 1100 dashboard backup fuse review
http://www.starbikeforums.com/forums/49-v-star/50018-brake-lights-not-working.html
Yamaha star 1100 Owner Manual
OEM parts for Yamaha
Yamaha XVS1100 Service Manual
Apr 30, 2017 | 2002 Yamaha V Star 1100 Classic
Tip
Flashlight Battery and Bulb Installation and...
FLASHLIGHT
BATTERY INSTALLATION FOR TORCH:
Open the Torch Battery Door located on the bottom of the Torch.
Insert 4 “A A” (1 .5V UM-3) (not included) batteries (alkaline
batteries are recommended) into the torch compartment. Be sure
the polarity (+ and
-) matches, as marked inside the battery
compartment.
FLASHLIGHT:
Slide the Torch Function Switch to the “FLASH” position, the Torch will light. To turn off, slide the Torch Function Switch to the “OFF’ position.
FLASH/BLINK FUNCTION:
Slide the Torch Function Switch to “FLASH/BLINK” position, tha Torch will light and thc bulbs on both sides of Torch will blink.
BULB REPLACEMENT:
Rotate the Torch Cover anticlockwise to hear “click”
then p
ull out the cover, remove the old bulb. Then pull
out the torch cup, remove the blinker’s
old bulbs and
reinstall new bulbs. Replace the torch cup, then reinstall
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
Pencil Torch flame is not powerful welding torch, its a lighter flames and flames come out the sides through the air holes. How can i fix this? Thank you
Try turning the valve down or towards the off position. It may take some fine adjusting to get it just right.
May 02, 2016 | Welding Tools
I have a 91rs automaic and when i drive it some times it backfirers why
Most of the time when an engine backfires it is due to the timing being off or there is a severe vacuum leak at the intake manifold. You can locate the leak (vacuum) by taking a propane torch (DO NOT LIGHT!!) Open torch valve (1/4 turn) And slowly take torch around intake manifold. Wherever torch is and causes increase in R P M's There is where your leak is. Hope this helps
Nov 13, 2013 | Cars & Trucks
My dell 1100 wont start lights flash, system shorted out through power cord, power cord was defective, and power and negative lines crossed
Separate the negative and positive lines of the power cord and make sure each cord is covered separately and then re-plug to power source supply.
VIDEO TECH,OPEN HERE- will be of very help/guide to you.
***** ACCESS THE SPEED UP YOUR PC TOOL NOW>
**** ERROR FIXING GUIDE+SPEED UP PC BLOG GUIDE BY REMOVING SPYWARES,ADWARES,TROJANS,COMPUTER WORMS & VIRUS********OPEN HERE
Dec 16, 2010 | Dell Inspiron 1100 Notebook
1983 Honda VF 1100 The idiot light for the tail light is on
Hi, Sherman884 nice novella before diagnosing your blown fuse issue check the bottom of your seat if it's metal and comes in close proximity to the positive battery post you need to take the necessary steps to ensure there is no contact (electrical tape, thick rubber insulation, hammer a dent in the seat bottom etc.) also you are going to need a wiring from your service manual a test light, an ohmmeter and plenty of extra fuses. If you turn on your ignition switch and immediately blow a fuse you have a hard/dead short and is usually easy to find. With a test light connected to the hot side of the blown fuse holder start stabbing the wire/s that leads away from the fuse holder and towards the ignition switch, you test light will illuminate validating the short. When the test light fails to illuminate you have passed the short and need to back up until the test light illuminates, then look in the immediate area for the short.
If you driving down the road for 30 minutes or 15 miles and blow a fuse you have soft/flying short and may take some time and patience to find.
If the main fuse/circuit breaker constantly blows/trips while riding you probably have a faulty battery terminal connection. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary. Any other fuses that constantly keep blowing while riding are usually caused by a loose or corroded ground wire in the circuit, which means you have to check, inspect, test each and everyone with and ohm meter set on a low ohm scale 100 ohms or less . Simply touch one lead to the ground source and the other lead to the battery negative terminal, a reading of zero indicates a clean solid ground. Any number reading or infinity indicates a poor ground and needs to be repaired. Poor or weak grounds require excessive additional amperage to complete the circuit which in turn blows the small amperage fuse. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Motorcycle Message Board Motorcycle USA
main fuse keeps blowing
Honda VF1000F 1985 Shop Manual Page 2
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-vf-owners-manuals
Mar 12, 2017 | 1984 Honda VF 1100 C
My mobiles backlight dont working, its work only when i taking pictures... what i must do?!!!
yup its not torch light if you want torch light start video and then you can use it as torch light...
Feb 03, 2010 | Nokia 6120
Nokia 1100 speed dial problem
hi,
1.Take your phone 2.Click menu 3.Go to contacts by scrolling down 4.Go to speed dial
There we can assign the number as speed dial.
May 21, 2009 | Nokia 1100
Eratic idle on a jeep grand cherokee 4.0 engine
my first choice is a throttle position sensor will check my books for the best check proceedure and get back to ya!
Nov 25, 2008 | 2000 Jeep Grand Cherokee
Nokia 1100
yap! it was damaged with moisture and was grounded.
Sep 18, 2007 | Nokia 6600
Nokia 1100 Logo
222 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
